08-31-2011, 03:54 PM | #177 |
Rep 13
Will this setup fit on Z4MC with stock suspension and later lowered 1/2" on KW Clubsport:
F: 19x8.5 ET35 on 245/35/19 R: 19x9.5 ET20 on either 255/35/19 (perfect diameter) or 265/35/19 (1% bigger)
Z4MC / ZR CDV / G-Power exhaust / RE X-Pipe / GruppeM / NGK Irridium plugs / Sport System ECU / RE RTABs & RSMs / Bilstein B12 / VMR VB3 Michelin PSS / M Strut / AP Racing 6x4
09-03-2011, 04:57 PM | #178 |
Rep 385
Yes.
09-05-2011, 05:22 PM | #179 |
MMA fighter and F1 test driver
18
Rep 362
19x8.5 30 +6mm inside + 18mm outside
19x9.5 22 + 2mm inside + 14mm outside will these fit stock without rubbing?
NOW:08 M.Coupe SMB #102/248 #1669/1815
:|MORRVS8|APEX8|SS.X-pipe|SS.PW.Loop|AFE.intake|Matte.grill|short.ant|Z HP.knob|interior.LED|bulletproof 09 Audi Q5 THEN:96Accord|98Camry|04TSX SC|06 M3|06A4|05Civic Si|05Imprezza|05S2000|08FJ |
09-06-2011, 01:57 PM | #181 |
18
Rep 362
lol sell me your wheels =P
09-06-2011, 07:28 PM | #182 |
///M-fanatic
193
Rep 3,885
09-23-2011, 10:20 PM | #183 |
Rep 308
Can anyone verify these fittings?
I've already paid for it and picked it up but didnt bother putting them in yet. they are out of 335d , miro type 111 hyper silver front is et35 19x9 with falken fk452 225/35/19 rear is et33 19x9.5 265/30/19 What do you think, I know rear would fit perfect, but the front? rub? It is stock suspension and do not intend to lower it. What y'all think? |
10-05-2011, 02:10 AM | #184 |
Rep 1,349
Not sure if you are trying to install the wheels on an M or non-M. The front should fit both M and non-M. For the rear to look good on an M you will need spacers (10 - 12mm). No spacers needed for non-M. |
10-16-2011, 12:12 PM | #185 |
Rep 2,882
Will this setup fit on Z4MC with stock suspension and stock camber settings:
F: 19x8.5 ET32 on 245/35/19 R: 19x10.5 ET25 on either 275/30/19 I don't want any other modification to make them fit. Been eyeing some BBS CH-R's. Tirerack list this fitment as compatible with the Z4M. I have not seen anyone having these fitted on a Z4M yet. |
10-16-2011, 07:08 PM | #186 |
///M-fanatic
193
Rep 3,885
The rears will require fender roll and not too low of a suspension drop in order to clear. Otherwise the 275s will rub. Other than that, the wheels fit. G'luck!
10-16-2011, 11:28 PM | #187 |
Rep 2,882
Thanks for the confirmation. I was hoping that no fender rolls would be required Guessed that's why I haven't seen an E85/E86 rockin these. I thought TireRack were pretty good with their fitment guide, that is, they wouldn't recommend anything that requires additional body modification to make them fit
10-17-2011, 03:02 PM | #188 | |
///M-fanatic
193
Rep 3,885
10.5" rear with low-20s offset is just too aggressive for the stock fenders. It's unfortunate that BMW didn't give the M models wider, more distinctive fenders |
10-20-2011, 02:59 PM | #189 |
Rep 380
edit... found the non m thread at http://www.zpost.com/forums/showthread.php?t=398990
10-26-2011, 01:26 PM | #190 |
Rep 1,031
Was test fitting some 17" x 8" rims for a winter setup. Not sure of the offset, square setup. Had no issues with the brakes. Decided to just use my stock wheels and get Blizzaks but wanted to share that 17's can fit.
10-30-2011, 07:13 PM | #192 |
M = Midlife Crisis
66
Rep 2,006
How about these?
18x9.5 ET25 18x10 ET20 Looks like a no...
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM Last edited by Caddyshk; 10-30-2011 at 07:35 PM.. |
10-30-2011, 07:35 PM | #193 |
#dubspec
6347
Rep 5,201
Too aggressive in front. It will stick out the fenders and rub unless you put a serious amount of camber, but then it will also look broken. The rears will fill, but need rolled fenders and some camber adjustment to avoid rubbing
10-30-2011, 10:52 PM | #194 |
instagram 997turbotom
286
Rep 7,377
I run 18 x 9 et 35 front, and thats pretty close to the strut towers but if the fenders are rolled I probably have 5mm more to go there
10-31-2011, 11:50 AM | #195 |
M = Midlife Crisis
66
Rep 2,006
Was a sweet deal on a set of used Advan's too.. Oh well.
11-08-2011, 11:07 PM | #196 |
Rep 2,824
18x8.5 +29 with 235/40/18
18x9.5 +23 with 265/35/18 ? Seems like they will be based on some posts in here. These are OEM E9x wheel dimensions, but a search for these wheels (limited results) says they are pretty damn aggressive .. |
11-08-2011, 11:48 PM | #197 |
///M-fanatic
193
Rep 3,885
These will fit easily. Both the fronts AND rears. Have fun
11-09-2011, 12:03 AM | #198 |
Rep 2,824
Thanks for the quick reply. I too thought they would fit comfortably based on specs in this thread. Just bizarre that in application, members said they were running -2.5 front camber to fit. Cheers
reference: http://www.zpost.com/forums/showthre...=e9x+m3+wheels Last edited by wyatth; 11-09-2011 at 12:10 AM.. |
