04-16-2019, 09:22 AM | #1849 | |
Rep 528
Drives: E86 Z4MC; E92 M3
I'd rather know I have a capable pad for each driving situation, rather than the feeling in the back of my head to be easy because my pad choice was a compromise.
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE E90 M3 Sedan 6MT Jerez Black/Fox Red GONE E86 Z4M Coupe Interlagos Blue/Black E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread |
04-16-2019, 09:45 AM | #1850 | |
Rep 912
04-20-2019, 12:29 PM | #1853 | |
Rep 12,570
PFC 08 really is the best enduro pad. I can easily get 8-10 events (mix of 1/2 day events). I do like the extra bite from the 11's but it's easily worth the trade-off. Last edited by 3002 tii; 04-20-2019 at 12:36 PM.. |
04-30-2019, 07:30 AM | #1855 |
Rep 12,318
HRE C20?
I've got the exact same wheels on my E92!
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
06-13-2019, 07:57 PM | #1857 |
Rep 528
Bought an ECS polished billet dipstick. Got the notification email that they have a limited qty sale on them so scored it for only $17. As of right now it's still listed at that price.
06-13-2019, 11:44 PM | #1858 |
Rep 202
Just make sure that it is of the correct length. They had a batch that were well too short.
2006 Z4 ///M, Interlagos Blue/Beige
06-14-2019, 07:44 AM | #1859 | |
Rep 528
I imagine since they found out about/corrected the issue they wouldn't be selling this defective units, but it'll be the first thing I check anyway.
06-16-2019, 11:42 AM | #1863 |
Rep 62
Drives: 2007 Z4 3.0si Convertible
It's a new supercharger from ESS, the G1. It's a kit. The install is cake if you have a fair amount of wrenching experience. I didn't think to take video or photos until I was mostly done. I may put together a supplement to the supplied install manual to clarify some of the more difficult parts though.
06-16-2019, 12:04 PM | #1864 | |
Rep 688
06-16-2019, 12:53 PM | #1865 |
Rep 62
06-16-2019, 02:31 PM | #1866 |
dances with roads
4763
Rep 4,101
Ooohh 3.0si with the 3-stage intake manifold. I hope you didn't have to give that up.
What kind of horsepower are you supposed to be getting? Any thoughts about putting in an LSD? That would be a seriously sweet combination. |
06-16-2019, 03:14 PM | #1867 | |
Rep 62
I'm at a high altitude (Denver, CO) so the air is a lot thinner. As such I'm running a smaller pulley to get more boost to compensate. I expect 300 or a little more at the wheels which is what the old version of their kit made. I can't really go full out yet, the supercharger needs to break-in and the ECU needs to adapt to all of the changes. I haven't really pushed it yet, need to log a couple hundred miles first. When just driving casually you barely notice it. The acceleration curve is so smooth. Depending on what gear you're in the the thing really wakes up around 2500-3000RPM. The power increase is very linear so when you're steadily accelerating you feel it but it's not a "wow" moment. When you're driving a little harder, down shift and stomp on it...well, you can't help but giggle a little. Naturally, the car is louder while driving, there's constantly more air moving through the engine. I'm going to use ISTA and delete all the adaptations for fuel quality/octane, Valvetronic, Vanos, DISA and throttle. After bringing it up with one of the guys at ESS I think it might be better to let it learn the new characteristics based solely on the base trim values versus trim values which are no longer remotely valid. The supercharger makes a lot of rattling/gear lash noise at idle. I'm told it's normal by both ESS and Vortech owners and that it should lessen a bit as it wears in but that there will always be some chatter at idle.it goes away at just under 1krpm. It makes me cringe and panic a little. I'm used to turbos and their quirks, I suppose I'll get used to this. Last edited by CRE; 06-16-2019 at 08:07 PM.. |
wdb4762.50 |
06-19-2019, 11:19 PM | #1868 |
Rep 62
I've switched to a 15% mix of E85 in order to raise the octane of my gas. The minimum octane for the ESS kit is 93 octane. I'm running a smaller pulley to make up for the difference so instead of the 91 that would be required with the standard pulley I need to bring my octane up to 93 at a minimum. Talking to the tuner at ESS, both the tune and the injectors have enough headroom to run with some E85. Should be the same for someone at sea level who wants to run a smaller pulley (115mm). The stock pulley is 120mm.
A friend asked if a different belt is needed for the different pulley size. No, it's not. The factory tensioner has plenty of room for a pulley a size larger or smaller. So, 110mm to 125mm... probably a bit more. I may switch to the 120mm pulley, lowering the boost, until I get comfortable that nothing is going to go boom. You know, until I stop doing compression tests after every drive and temporarily setup a boost gauge and wideband. I probably should I make a new thread for this, huh? |
06-21-2019, 10:21 AM | #1869 |
BMW Newb
Rep 4
Too much stuff
Hello all, 1st post after buying a new (to me) 2004 BMW Z4 3.0i. After a shop inspection and a thorough look over I have purchased the following items for my Z4 (yes in the last week)...
Cooling system -Stewart upgrade pump -Thermostat -Upper, lower, and return hoses -CSF street radiator -Hardware to replace existing bolts etc Brakes (all 4 corners) -Drilled/slotted rotors -Ceramic Pads -Replacement calipers (rebuilt and powder coated) -Stainless lines -Sensors Drivetrain -Valeo SMFW clutch conversion kit -Brass pivot pin -New pivot fork -Input/Output seal -"Delay valve" delete -Giubo bushing -Engine/trans mount bushings -New differential fluid/plugs Engine -eBay headers (we'll see on these) -New exhaust studs -Oil filter housing gasket kit -New spark plugs Suspension -New tie rods -New control arms (HD) -New CA bushings with poly bushings (hopefully increase longevity) -Front & Rear sway bar links -New dust boots -Adjustable rear trialing arms ---these turned out to be maxpeeding rod items, will be returning as they already show rust and binding at adjustment points Tools -low profile floor jack -jack stands -ball joint splitter -impact wrench & sockets -brake bleeder kit -creeper Looking forward to getting clutch/brakes/suspension done soon and getting it out on the road. Cooling system and engine work will likely wait until winter. Wish me luck. |
06-23-2019, 09:06 AM | #1870 |
Rep 80
New battery
The 2006 Z4MR I got last month had an old battery (2011, clearly visible in a round sticker on the battery as 5/11), so I went and bought a generic one from Autozone (Walmart was out of stock). Just to all the newbies here - you need H6 battery type, don't worry about anything else. Paid $139 with core replacement. Looks like a computer needs a reset as I already can't put down my top. Hope I can figure it out with the help of this forum :-)
