12-12-2010, 11:51 PM | #133 | |
Rep 701
Everything in life has limitations if you look hard enough. Still nobody has been able to answer me why the S54 HAD to be axed. Someone made a comment that it produced too much emissions. Well I ask you... compared to what?
12-12-2010, 11:53 PM | #134 | |
Rep 701
By that reasoning then it should be possible for BMW to still use the S54 if it wanted to. Correct?
12-13-2010, 12:02 AM | #135 | |
707
Now I'll agree there is some correlation between fuel consumption and emissions. But it's not a direct correlation. For example, run a bit on the lean side and NO goes up and while fuel economy goes up as well this will not get an engine past the emissions bureaucrats. How cleanly an engine burns fuel is not directly related to consumption rates. Again, CO2 is another story---but I'm talking about NO and CO and HC. CO2 has become an issue for regulators more in the past few years--and we're now seeing that too in the regulations. I don't know the emissions specs of the Merc engine. Do you? I do know that the S65 which is higher displacement is cleaner than the S54. And I know that some modern engines run so cleanly now that the air coming out is actually cleaner than the air going in (Toyota has a couple in production now; others may have these as well). So it's technically possible to have an engine that produces very little by way of CO, NO, and HC. Here are the US standards. You can see how they've become much more harsh over time--especially since the design date of the S54 to the Merc engine you're comparing it to. So, how do they get away with it? Technology and design. For example, the S65 is a much cleaner engine than the S54 due to, for example, advanced ionic current based knock detection and other design improvements. The other manufacturers have probably gone a similar route. I don't know that much about their powerplants but I suspect they weren't designed in the late 90s like the S54. They're more modern designs. The S54 was and still is a great engine, but it's well over 10 years old in terms of design. That doesn't make it any less magnificent in our eyes, but in the eyes of some soul-less bureaucrats it makes it "non-compliant". Last edited by Finnegan; 12-13-2010 at 12:20 AM.. |
12-13-2010, 12:09 AM | #136 | |
707
12-13-2010, 12:46 AM | #137 | |
Rep 2,128
Porsche 3.8L - 242g Porsche 3.4L - 223g Nissane 370z - 220g The S65 in the current M3 does 290g/km (yep, better than the S54!), while the E39's motor did 336g/km. Other current performance 8s: Ferrari 458 - 307g Corvette C6 - 316 Merc 6.8L AMG - 330 |
12-13-2010, 01:57 AM | #138 | |
Rep 701
Now we are finally making some progress, I appreciate your efforts. So from epbrown's post we can see that the above V8's produce more CO2 than the S54 but the 6 cylinder models produce less. Is there a separate rule for 4, 6, 8, 10 and 12 cylinder vehicles in regard to emission standards? I would have thought it would have been standardised.
12-13-2010, 02:33 AM | #139 |
707
But guys, CO2 isn't the only emission that counts. What about carbon monoxide (CO), nitric oxide (NO), and hydrocarbons (HC)? Emissions rules are very strict about these as well--CO2 is only part of it and only recently since the others have been increasingly regulated for years.
12-13-2010, 02:38 AM | #140 |
1M advocate
214
Rep 878
The s54 is way too heavy, fuel inefficient, costly, and emissions producing to be put in the newest BMW's. You have the choice of the s54 in any of 6 different cars, it really shouldn't be a complaint.
7 speed DCT gearboxes with a really tall overdrive highway gear helps alot, sadly the weight & relatively small displacement of modern BMW's doesn't allow them to use this as an advantage as the car would be completely gutless on the highway.
2012 BMW S1000RR
2011 BMW M3 |
12-13-2010, 04:23 AM | #141 | |
Rep 701
It is around the same weight as the S65. Fuel Inefficient? I would be surprised if it was less fuel efficient than the X5-M/X6-M engine. Costly? Can you provide the manufacture costs of the engines BMW produces to quantify your statement? High Emissions? It produces less emissions than many other engines still in current production. No sorry, I am not convinced that the S54 had to be axed for the reasons you stated. So far everyone is just posting hear-say and word-of-mouth speculation of the worst kind as to why BMW discontinued the S54. I require someone much wiser than me to please produce some factual environmental legislation or legal manufacturer requirements that would mandate the demise of the S54 in it's current form and thus exclude it from further production. I am not trying to provoke an argument and I appreciate the responses but I would like a factual answer from someone who actually knows, not that is guessing with evidence to support why the S54 production was axed.
12-13-2010, 05:27 AM | #142 |
BMW Fan
11
Rep 553
I don't have a factual answer. I do know that it was handbuilt and expensive to produce, it had an iron block and BMW moved on to aluminum or aluminum/magnesium blocks, and it was no longer a standard or optional engine for any of their current models. So those seem like valid reasons to discontinue it from a manufacturer's perspective.
12-13-2010, 05:49 AM | #143 | |
Rep 701
Maybe I am looking for an answer or a definitive reason that does not exist. It could have just been time for BMW to drop the S54. After all, manufacturers do change engine and development does continue. The S54 could have been discontinued not because of emissions, fuel economy, cost or weight as others have speculated but just because it was time. I am just disappointed that BMW have not made a replacement and upgraded the S54 with an engine that has the same character and design criteria. They are moving in a totally different direction and it is not to the satisfaction of many. At the same time Porsche, Lamborghini and Ferrari have not abandoned traditional naturally aspirated high revving engine design so even though I will pay more that is not the most important thing for me and when I have to upgrade my vehicle I will be voting with my money and leaving the BMW camp if they fail to deliver what I want.
12-13-2010, 05:55 AM | #144 | |
Rep 2,128
Both Car and Evo magazines have printed the S54 wasn't used in certain applications because of tighter emissions targets in Europe, which mandated a fleet average of 140g/km for CO2 by 2009 fo car manufacturers as early as 2005. Technology had also moved on in terms of weight, as the S65 is actually a bit lighter and the S85 is only slightly heavier, and neither of those engines require the periodic valve adjustments of the S54 as hydraulic valve adjustment technology had caught up with M-division's high rpm rates. |
12-13-2010, 10:36 AM | #145 | |
Rep 1,855
Fuel Inefficient: Again, you're comparing it to turbocharged V8's, producing 200+ more hp than the S54. High emissions: I don't know much about this, but I think you really have to compare it to current engines producing similar hp / tq figures. You'll probably find that most produce less emissions. Anyway, if it were up to me, I would have liked to see the S54 stay around just a bit longer, with some updates (perhaps with direct injection), but oh well...
12-13-2010, 10:48 AM | #146 | |
1M advocate
214
Rep 878
Even in the mz4 the s54 has roughly the same fuel efficiency as the s55 in the x6m. Yet it's in a car that is a full ton lighter and makes an additional 212bhp and DOUBLE the torque. As for cost, it isn't efficient for BMW to produce 3 completely different M engines. Should be fairly straight forward. The s54 may have less emissions than a few other engines but so what, that's like saying a scion xb is a fast car because it's faster that 3 kia's. While the modern BMW powerplants may lack character they are far more efficient. The other reason is that the m50 family of engines was at it's design limit, there was no room left for increased displacement due to cylinder spacing and maximum piston speed. BMW had massaged and squeezed the m50 block as tightly as they dared; the s54 is the result and it is the peak performance and absolute limit of what was possible... which is one reason why it is so highly revered among enthusiasts. It's time has come and gone though, from a purely engineering point of view it really is a dinosaur when compared with the modern BMW engines.
2012 BMW S1000RR
2011 BMW M3 |
12-13-2010, 01:59 PM | #147 |
Rep 1,739
Drives: 2008 Z4MC
So turf the S54 and move up to newer tech etc.
But BMW... DON'T call the car a 1M. It is only a 135is in reality. |
12-13-2010, 02:44 PM | #148 | |
Rep 514
"Not to mention having the S65 in the 1M would pretty MUCH be the final nail in the coffin for M3 sales, I agree they should have waited till after the end of the e92 production before producing the 1M with a S65. Then giving the next generation M3 a totally new motor. Regardless, I think the 1M will be fine in representing the M badge."
2007 /// M Coupe Alpine White / Light Sepang Bronze 6MT
2003 /// M3 Alpine White / Imola Red SMG II (Sunroof Delete) SOLD |
12-13-2010, 03:01 PM | #149 | |
1M advocate
214
Rep 878
Engines don't make M cars. M cars are about balancing power, control, handling, comfort, braking, and driving sensation into one harmonious package.If you want to just break an M car down to whether or not it's engine is up to snuff, well then maybe something more along the lines of a challenger srt8 is more up your alley.
2012 BMW S1000RR
2011 BMW M3 |
12-13-2010, 03:27 PM | #150 |
Skull Squadron Leader
307
Rep 2,031
The engine IS an integral part of the package. When BMW uses what is for all intents and purposes a 35is remapped engine, THEN slaps an M badge then it is tantamount to a 135i owner replacing non-engine parts with M parts, chips their car, and then calls their ride an M.
Looking at the big picture, my qualm is not the fact that they put an M54 engine in but that they didn't put an S65 engine instead. There's no such thing as too much power, and arguing cannibalism against M3 sales is rubbish. Combined sales and the option of having either car will blow the competition away which is what they should be thinking about anyway. They should have called it a tii... |
12-13-2010, 04:12 PM | #151 | |
Rep 1,739
Drives: 2008 Z4MC
But back on point... "Engines don't make M cars"??? I guess you're right. Not anymore they don't. Last edited by johanness; 12-13-2010 at 05:20 PM.. Reason: cooled down |
12-13-2010, 04:12 PM | #152 | |
1M advocate
214
Rep 878
Engines have never defined M cars, they have simply reflected the atmosphere at BMW... Hell you could argue the s14 isn't a real M engine because it was only a hacked up version of the M10 & M88. You are way underestimating the amount of change BMW performed on this car to turn it into an M car, I actually have taken a non-M car (an e36 325i) and tried to turn it into an M3... it's beyond belief how many small intricate things are changed to create an M3. It isn't just down to buying a software download and some different dampers. IMO the 1M deserves it's M badge more than even the upcoming m5 which will be a 7 series based 600hp 2.3 ton pig only available with an automatic box... tell me how that resembles an e21 or e34 m5 more so than the 1M relates to an e30 or e36 m3.
2012 BMW S1000RR
2011 BMW M3 |
12-13-2010, 04:14 PM | #153 |
Rep 1,855
The engine is pretty big part of it--that I agree, but the overall car is pretty bada**, and at a projected pricepoint that's not wholly unreasonable.
It's got different fenders and mirror---our M coupe didn't even get unique fenders and mirrors, and I would argue that it's still just as ///M as any other car. Sure, the z4m's got a screaming engine, but the N54 isn't too bad when it's making 335hp and more torque than the M3. Sure, it's a derivative engine, but so is the Z4m's. Just MHO.
12-13-2010, 04:22 PM | #154 | |
1M advocate
214
Rep 878
2012 BMW S1000RR
2011 BMW M3 |
