08-15-2013, 11:29 PM | #970 |
enthusiast
48
Rep 1,695
08-16-2013, 08:35 AM | #971 |
11116
Rep 4,930
Larger pulley is just like riding lower revs for the compressor.
Also the aircon pulley is straight foreward I think. No mass dampers etc. Just the clutch. I didn't know you could buy aircon compressor pulley's seperately and in different sizes. (it usually is set to the clutch coil inside) Larger crank pulley will spin the aircon compressor faster and that can maybe do damage/cause extra wear on high revs.
08-16-2013, 02:03 PM | #972 | |
enthusiast
48
Rep 1,695
Just remove the AC. |
08-16-2013, 07:27 PM | #973 |
11116
Rep 4,930
still, why mount a larger pulley on the aircon compressor?!?
Losing the aircon all toghether may be a point if you want to lighten your car (you can maybe save 10kg), but lowering the speed of the aircon compressor... I don't see the point. If you think it takes too much power when you think you need it, just turn it off. Then there is almost zero drag (it has a clutch, so you're just rotating a loose pulley)
08-16-2013, 07:37 PM | #974 | |
enthusiast
48
Rep 1,695
08-16-2013, 07:48 PM | #975 |
instagram 997turbotom
286
Rep 7,377
Whoa whoa whoa, no aircon removal. Im in south florida. The euro s50? 5.25" crank pulley has a larger aircon pulley built in, hence my apprehension. Indeed it would spin the air compressor slower, hopefully not too slow...
08-16-2013, 07:58 PM | #976 |
Rep 2,782
A larger crank pulley would spin it FASTER. The compressor pulley will have to make more rotations for each rotation of the larger crank pulley. The whole reason you're increasing the crank pulley diameter is to spin the supercharger faster, correct? It would spin your accessories faster too.
http://www.engineeringtoolbox.com/pu...ds-d_1620.html I would think the danger is in overspeeding the compressor. Figure out the max speed of the compressor off a spec sheet, and then use the formula to calculate the max speed it would see based on 8000 rpm and the pulley diameters.
08-16-2013, 08:09 PM | #977 | |
11116
Rep 4,930
How is the ESS VT2 system driven? The aircon pully uses a different belt (and part of the pulley) than the belt that drives the waterpump and alternator. With most systems that's the belt that is also used to drive a supercharger. The crankpulley has 2 seperate diameters, so obviously you have to change both diameters to change both belt speeds..... The alternator, waterpump and steeringpump are I think much less sensitive to max rpm as they are very simple mechanically speaking compared to an aircon compressor. So first you have to get the specs for the new crank pulley if you think of changing it.
08-16-2013, 10:13 PM | #978 |
Rep 2,782
Yes, I agree. If the second crank pulley ("air conditioning pulley") diameter is larger, then you will spin those accessories faster. This is what ZStig was suggesting with the Euro S50 pulley, correct?
If it's the same diameter as the current pulley, you'll spin it at the same speed. If it's smaller, you will spin it slower.
08-17-2013, 09:28 AM | #979 | |
11116
Rep 4,930
The difference in redline between s50b32 and s54b32 is significant (400rpm), but they also have a different aircon compressor. So they could have matched the revs just as easily in the pulley from the aircon compressor. Who knows. Measuring the diameters between both crank pulleys (the ac part that is) is the only way to know. I haven't seen that data here... (or have I overlooked that?)
08-17-2013, 10:13 AM | #980 |
Rep 2,782
08-17-2013, 11:03 AM | #981 | |
11116
Rep 4,930
And by how much?
How did he get that information? If he has measured it he also knows what the effects will be and he wouldn't have asked his questions in the way he did. I've seen lots of information on this forum which turned out to be wrong or not accurate. (you know, read of 'some forum' written by 'some guy') That's why I wrote Quote:
08-17-2013, 12:05 PM | #982 | ||
Rep 2,782
08-17-2013, 12:26 PM | #983 |
11116
Rep 4,930
No, a larger diameter pulley on the aircon wil slow down the aircon compressor.....
There will be no overspeeding.... That only happens if you put a larger diameter pulley on the crank. So the answer you're displaying is wrong
08-17-2013, 12:33 PM | #984 |
Rep 2,782
If you're talking about the air conditioner compressor itself, then yes, a larger pulley on it will slow it down. If the diameter of the crank pulley that drives the air conditioner is increased, it will speed up the compressor.
It doesn't really matter, because I think we're saying the same thing. You need the diameters and plug them in the formula. r1*n1 = r2*n2
08-17-2013, 09:46 PM | #985 |
286
Rep 7,377
Ugh. No. Im not changing the pulley on the aircon compressor. I want to upgrade the CRANK pulley to 5.25" oem euro, and from just pictures i've seen, the second (aircon belt connected) pulley also looks bigger then stock. I will dig up pics, i dont have the measurements of the second pulley on the crank euro pulley
08-25-2013, 01:06 PM | #986 |
286
Rep 7,377
I'm seriously considering staying with my original 5.11" crank pulley, and just getting a 2.87" supercharged pulley which I'll get coated so it won't slip. I'm worried that at 51,278rpm impeller speed, I might make over 11psi of boost, and push the stock engine too far even after a re-tune
plus, the max impeller speed on a vortech v3si is 52k RPM, and ESS used 16psi to get to 600rwhp on a low compression engine. Which is what is scary to me, considering that I'd be near max impeller speed on stock internals Also, I realized that going catless in section one DECREASED my peak boost. After some research, it appears that the more efficient your engine is at breathing, the less boost you'll read on your gauge because your engine will be using that up, versus being backed up in the gauge. If that makes sense..http://www.928motorsports.com/servic...tingpulley.php
08-25-2013, 03:40 PM | #987 | |
enthusiast
48
Rep 1,695
Also, since its more efficient, you should be able to safely run more boost. |
08-25-2013, 09:17 PM | #988 | |
286
Rep 7,377
or 5.11" crank with a 2.87" crank for 51,278rpm I have no idea what combo ESS used for their VT3 prototype
08-25-2013, 10:06 PM | #989 |
286
Rep 7,377
Vortech doesn't make a 2.5" pulley for the V3, in 6 rib...
08-25-2013, 10:23 PM | #990 |
Rep 892
Just ordered a second one from here; this time coated:
http://www.928motorsports.com/parts/6ribpulley.php
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i |
