08-04-2010, 11:31 AM | #45 |
Rep 9,160
dth656, I ride a lot of both road and off road and knee pain is usually due to poor fit or a change in setup. I'd venture to guess that your change in pedals and cleats probably moved the cleat away from the ball of your foot, and that combined with less float works against you. If the soles of your new shoes are a different thickness than the old ones, and if the spindle height on the new pedals is different, it's possible that you're overextending your knee.
A proper fit is priceless, road or mountain, and a good fitter will be able to adjust things for your needs. It's best to take as much of your own stuff as possible; saddle, shoes, pedals, riding shorts, gloves, and if possible, bar and grips. The distance from the top of your saddle to the spindle of the pedal should be the same for all riding, on all bikes. Some folks will lower the saddle position a centimeter or a little more for a cyclocross or downhill bike, but big adjustments from the ideal position are generally bad. The horizontal relationship between the saddle and the bottom bracket should also be constant for each bike, and specific to your fit. Knee pain is bad, and should be addressed before it gets worse. A good fit should address this issue and provide a good dose of happiness. |
08-04-2010, 11:38 AM | #46 | ||||
Resident Black Guy
251
Rep 2,302
as far as the bike on bikesdirect.com what bike do you guys recommend? wow and they have free shipping if i read it correct. and i have new budget of $450 ( i found $50 at walmart.) i spoke to a guy at a bike shop yesterday over the phone and he said theat my size is between 52-54. so if we were to go by that what would you guys reccommend? |
08-04-2010, 12:12 PM | #47 | |
Rep 2,014
I use the same type of pedals on both my road and mountain bike, Crank Brothers Candy http://www.crankbrothers.com/pedals_candy1.php my reasoning is that if I am redlined on a steep loose trail I want my gear to be familiar, I want my shoe to pop out of the pedal the same every time in case I really need to get out quick, and I can use the same shoes which I like and are comfortable on either bike. These pedals are not as streamlined and light as “road” pedals, but they are easy to get in and out of, the hold your shoe securely, and (importantly for this conversation) they don’t lock your shoe/foot into confining position, they allow for a bit of pivoting on the ball of your foot (if that makes sense). Your knee is not forced into an unnatural position. I will concede that perfectly set up gear that allows no slop and is lighter would be more efficient, particularly if 1/10s of a second matter, but for recreational riding in an imperfect world I like my mountain pedals on my road bike. An added benefit is that mountain shoe have a bit more of a sole to them and the look like normal shoes when you get where you are going, you don’t get the tap-tap-tap with every step. |
08-04-2010, 12:18 PM | #48 | |
Rep 395
redbread,
thanks for the input. the new pedals are a lot thicker, and the new skate style shoes also have a much thicker sole (so i raised the seatpost by about 5mm to compensate for the added distance between seat and spindle centerline). i'll try some pedal extenders (to increase the q-factor), then i'm going to schedule a fit session at a local bike shop, and take the old pedals/shoes with me. the specialized BG fit session, tho pricey, seems fairly comprehensive. fingers crossed Quote:
go bears
08-04-2010, 12:21 PM | #49 | ||
Rep 1,288
If at that point you decide to go to bikesdirect then so be it.. you'll at least be armed with good info. I'm 100% confident that if the bike doesn't fit.. you'll end up in pain and stop riding altogether. Then you would have wasted time/money and potentially lost a great hobby. |
08-04-2010, 01:50 PM | #50 | |
Rep 395
misterskimask,
until now, i've followed the same thought process. i've always used the same type of pedal on all of my bikes (shimano m535, or whatever they are calling it these days), and very similar types of shoes (something close to lower end sidi mtn shoes in terms of geometry, sole stiffness, etc). i've also always used the same amount of cleat tension over the years. Quote:
go bears
08-04-2010, 02:07 PM | #51 |
Rep 9,160
dth656, you might have better luck using separate shoes, or moving to stiffer soles on both. Road shoes tend to benefit greatly from stiffer soles, flex in the sole can lead soreness when riding long distances. If you're having knee issues, one of the best solutions is a set of Speedplay X-series pedals. I played soccer, surfed and snow boarded for years and have wonky knees, but Speedplays keep my knees happy. They have 35 degrees of float, and a little horizontal float too. It would require using separate shoes for road and mtb, but for many reasons, this makes more sense. Shoes are a more personal thing, so try a lot and find what works. After years with Sidis, I've found that my feet seem to really prefer the newer Specialized shoes.
08-04-2010, 06:26 PM | #52 | |
Rep 714
I still say you're better off trying to find something used off craigslist. If you know what you're looking for, you can get something that's far better quality than a new bike off of BD.
Black Dakota | Aluminum | Sport | Premium | Cold | iDrive | CA
08-05-2010, 11:47 AM | #53 |
Resident Black Guy
251
Rep 2,302
today is the big day im going to get sized for a bike. does it really cost that much to put a bike together? good thing a friend of mine does some serious mtn biking. he puts his bikes together all the time.
08-05-2010, 12:18 PM | #54 | |
Rep 395
-headseat installation (needs a relatively expensive tool, and i didnt want to screw it up) -bottom bracket installation ( i couldnt get it seated properly, so ended up going to the LBS) stuff you could do yourself: -install, adjust shifters and derailleurs -install cranks/pedals/chain -install cassette
go bears
08-07-2010, 09:50 AM | #55 |
Resident Black Guy
251
Rep 2,302
ok guys so i made it to 2 bike shops in savannah.
first shop: so i tell them i would like a road bike and my budget is $500. first thing he says is well ok we can do that. so he takes me to a cannondale slice ($800 price tag btw). the bike was awesome. but once again way out of my budget. so again i have to remind him that my budget is $500 and he takes me to another bike with a 1k price tag. im dude do you not understand budget? then i start asking him questions about bike and thins like that and he totally blows me off. so i leave. second bike shop: this dude is awesome. doesnt pressure me into buying anything brand new. he real patient answers all my questions in detail. i tried out a couple bikes. asked him his thoughs on bikesdirect.com. he says he bought a couple off there and there is a couple in the store being assembled. he recommended one for me and it was awesome. so im gonna go ahead and get this: http://www.bikesdirect.com/products/...laxy_al_xi.htm i even get free assembly and everythig. overall i say it was a pretty awesome experience. so i will be ordering my bike today and hopefully have pics up for youg guys by the end of next week. thanks for all you guys help |
08-07-2010, 12:06 PM | #56 | |
Rep 2,014
Enjoy your new toy. |
08-07-2010, 08:20 PM | #59 |
Rep 714
congrats, what size did you end up getting?
As far as helmets, you need to try a few on. They all fit very differently, especially Giro and Bell, which are probably the two most popular brands. I use a Giro Ionos personally though. With a helmet you're basically paying for two things: ventilation and lightweight. Whatever you decide on though, ebay usually has the best prices.
08-07-2010, 09:05 PM | #60 |
Rep 9,160
What ever fits. I use Giro and Lazer, Bell tend not to fit my head well. All helmets, from $20 skate style helmets to $300+ pro-line helmets have to meet identical safety standards, so as mentioned, money gets you lightness and better ventilation. Since you live in Atlanta, a good, mid-level helmet is probably your best bet. For your first one, it's probably best to get one form your local shop to ensure it fits well.
08-08-2010, 11:24 AM | #61 |
Rep 1,288
08-08-2010, 01:25 PM | #62 |
Resident Black Guy
251
Rep 2,302
yea i was thinking that bike is way out of my league. i just received an email saying my bike will be delivered thursday. so i will definitely beee going to the bike shop that day. and getting it assembled and testing out. im so excited i use to be into bikes big time when i was younger. but they were bmx type bikes. like for flat land tricks and stuff like that. you guys know any good bike forums?
08-08-2010, 05:15 PM | #63 |
Rep 1,288
roadbikereview.com
bikeforums.com Lots of good info on both sites. Lots of cool people over there, but be careful because there are a TON of elitist pricks too... especially on RBR. Kind of funny to think so, but E90Post can't hold a candle to the amount of attitude/asshole'ishness that comes along with road biking... pretty insane. |
08-08-2010, 06:54 PM | #64 | ||
Resident Black Guy
251
Rep 2,302
you know what sucks, this thread is probably gonna die in the next week because noobody talks about bikes. i had to dig far back for this one. |
08-08-2010, 07:22 PM | #65 | |
Rep 714
we'll keep it alive...I'm riding tomorrow morning with a buddy, we haven't had good luck riding together so far though. First time he got a pinch flat after hitting a big pothole on a fast descent (~45 mph). That wasn't too big of a deal though. The second time, his wedding ring slipped off and went skipping into the grass. Luckily he eventually found it though...
08-08-2010, 09:27 PM | #66 |
Resident Black Guy
251
Rep 2,302
damn you guys ride 45mph? thats good he found his ring. im not gonna have anybody to ride with. i told all my friends about me starting this riding for a new hobbie and they just laughed at me and called me gay. uugghh...of course i got the speedo jokes too. but no big deal. this seems like a fun hobbie and it will get me in better shape. i have gained 70 in the last 2 years due to a back injury so now its time to drop them off. how do i go about installing a bottle holder? i seen a bike with 2 of them. one on the frame and the other on the back of the seat.
