03-04-2014, 10:44 PM | #23 |
Rep 175
Wow, that's slammed. I won't be that low, but thinking I'll run the 265 squared. I heard the Hankook rs3s were being replaced soon by the rs4. Anyone know about this?
04-12-2014, 07:55 PM | #25 |
Rep 175
For an 18x9.5 et 35 up front I'm now thinking of a 255. I tried to fit a 265 from a friends set of apex with exact same dimensions and I hit the strut and fender liner. So I'm thinking 255 35 18. Will I need a spacer for this? What negative camber should I set? Also, is a 265 r and 255 front going to handle ok? I'm pretty low up front.
I think I will need a spacer and -2.9 camber but want to get other opinions. Thanks! |
04-13-2014, 01:43 PM | #26 |
Rep 516
you will need a 5mm spacer up front regardless 255 or 265
04-13-2014, 10:37 PM | #27 |
Rep 175
04-14-2014, 12:00 AM | #28 |
Rep 516
10mm will work, just 5mm clearance waste don outside. assuming you have camber plates I recommend -2.5 and above (I run -3.0 as i track often).
04-14-2014, 01:05 AM | #30 |
Rep 516
Warning? As long as they're hubcentric and you are using extended bolts, i don't see a problem? I'm running H&R spacers with correct length bolts for each spacer (very important for safety reasons)
04-14-2014, 11:30 AM | #32 |
Rep 5,329
this.... used them and not an issue.... their is enough of a lip for the 10mm to work with the z4m, I'm aware of turners warning on their page....
04-15-2014, 12:15 AM | #33 |
Rep 175
So it seems this is the setup:
255 35 18 mounted to an 18x9.5 et 35 with 5mm spacer -2.8 or more camber front 265 35 18 mounted to an 18x10 et 25 with optional 10mm spacer I own. Not sure about rear camber. Any suggestions to this before I buy the tires? |
04-15-2014, 12:19 AM | #34 |
Rep 516
im currently running 265 on 18x9.5 +35 rear with a 10mm spacer. that puts it roughly at +25. Perfect stance for me, camber is set at -2.5
04-15-2014, 09:36 PM | #35 |
Rep 175
What tires do you run? Im looking at the rs3, z2. Found the federal rsr to be really cheap but dont know too much about them.
Car will be my daily and occaisional track car. |
04-15-2014, 09:39 PM | #36 |
Rep 516
on my apex i have ad048 r comps, on my te37 i have federal rsr.
