06-23-2013, 07:14 PM | #23 |
Rep 782
Mine just turned 35k this weekend and I have the same thing. I think I started to notice it when I changed wheels. But I had them checked, aligned the car, balanced etc... still happens at about the same speed 65-80 before and after the car positively glides. Smooth as silk
2011 30i
[SIGPIC]/SIGPIC] |
06-23-2013, 07:28 PM | #24 |
Rep 279
Since I drove the **** out of my car this weekend and could really feel this, and since my wife is out of town for a couple more weeks(fun me time!) I decided to tear into the car today and get it ready for the new cab's, new motor mounts, and euro headers. My control arm bushing are both starting to seperate from their shells right at the offset where the control arm tang passes through. I would say about an inch section on each, barely visible but easily pried open with a screwdriver. If I hadn't just dropped money on other things I would probably do my control arms also but they should be good for awhile longer, will have to do cabs again when I change them, oh well. Will report back when new cab's are in.
Dan |
06-24-2013, 10:12 AM | #25 |
Rep 428
06-24-2013, 12:14 PM | #26 |
Rep 279
06-24-2013, 03:16 PM | #27 |
Rep 428
Thanks, I went ahead and ordered a set of bushings....I love the fact that they come already inside the lollipop...that is half the battle right there!
I can get them installed on both sides in about an hour....should be a piece of cake! Hopefully, this will fix my issue before my 12 hour drive to Orlando!
1999 /// M3 Convertible Techno Violet |
06-24-2013, 03:36 PM | #28 |
Rep 279
Update!
Both Turner and ECS advertise the brackets w/bushings. It looks like the left bracket is back ordered with no date/time frame. This was from ECS. Turner confirmed none in US or Germany, no date. I changed my order at ECS to just the bushings. Turner told me bushings weren't available seperately http://www.ecstuning.com/Search/SiteSearch/31107838575/ Front Control Arm Bushing Set ECS told me these were avilable and would ship on the 28th. Dan |
06-25-2013, 08:43 AM | #29 |
Mechanical Engineer
96
Rep 1,025
Jumping on the bandwagon as well, I've had this issue for some time, "A" wobble. 72k miles. I guess I'm in line for some new bushings.
Anyone who has already ordered these care to post some pictures of the install process? Can this be done without a shop press? |
06-25-2013, 09:18 AM | #30 |
Rep 2,138
Drives: Me
Although, theoretically, you can replace the FCAB’s without doing an alignment, in practice, if you are having issues because of the FCAB, when you change them, your toe may change and have to be adjusted.
I had this issue first hand. I went from zero toe (my default) to toe out when I replaced the FCAB’s. |
06-25-2013, 09:18 AM | #31 |
Rep 69
While in some cases the control arm bushing (CABs) may be the culprit, keep in mind that you may replace them only to find out that the vibration is still there.
If you check my post above, you'll see that I replaced the CABs twice, to no avail. |
06-25-2013, 09:22 AM | #32 |
Rep 2,138
Drives: Me
RobertRO,
This is a off the wall thought, could your 'reinforcement plate' be loose???? |
06-25-2013, 03:14 PM | #33 |
Rep 69
Shipkiller, thanks for the hint. However, I have replaced and correctly torqued down the reinforcement plate bolts on two occasions (first time when I replaced the CABs, second time when I replaced the control arms + CABs). But it didn't fix the vibration.
06-25-2013, 03:26 PM | #34 |
Rep 2,138
Drives: Me
It was an off the wall shot.
06-25-2013, 08:07 PM | #35 | |
Rep 1,107
06-25-2013, 09:49 PM | #36 |
enthusiast
48
Rep 1,695
06-25-2013, 11:36 PM | #38 | |
Rep 279
I didn't take any pics of removal. Front of car on jackstands. Remove reenforcement plate. Remove two 17mm bolts holding LollyPop to frame. Use 2/3 jaw puller(I borrowed one from autozone, small3 jaw)to pull LollyPop off control arm. Had to use Dremel to make control arm tang flat to seat puller. Since I ended up just ordering the bushings I will either need to have a shop press out/press in for me. Or.......Take a trip to the new Harbor Freight up the road and see if they have any small presses and do it myself. Hmmm Bushing has an arrow that aligns with nub on bracket when pressing in. INstall, lube CA tang with dishsoap, use a rubber mallet to pop bushing on to CA tang, bolt LollyPop back to frame. I don't have a torque spec on hand. |
06-26-2013, 05:06 AM | #39 |
Rep 2,138
Drives: Me
Just go to Advance and rent their large bushing kit. That was the kit I used to do my FCAB's.
I did not grind the tab off of the housing. Not sure why you would do that. |
06-26-2013, 06:16 AM | #40 | |
Rep 11,669
The plate is a structural member to stiffen the chasis. ....not to protect from lo-rider scratches
06-26-2013, 06:17 PM | #41 |
Rep 279
The tang on my control arms had rounded riser at the end and the puller I used would slide off of this as it was tightened and cock sideways. About 30 seconds with a Dremel removed this riser and gave the puller a flat spot to seat. I'm talking about the screw that you turn to apply force to the puller. I couldn't get the thing to seat until I Dremeled it....*&^& %$#!
06-26-2013, 06:49 PM | #42 |
Rep 2,138
Drives: Me
Oh, I understand.
In the TIS, it tells you to put a punch-mark in the control arm so that this does not happen. TIS 31 12 049 |
06-26-2013, 07:06 PM | #43 |
Rep 279
I gotcha! I guess I should get the TIS for this car. Would have been prepared for that...I have a TIS but it cuts of at the e46. I wish they had a good Bentley for it. All in all everything is very straight forward but there's alway the little steps/tricks that make the job faster.
06-27-2013, 12:25 AM | #44 |
636
Rep 3,124
Just ordered both side lollipops from Tischer.
And 4 new bolts. Don't forget new bolts. We'll see if a box shows up in a week, or I get an email from them saying "you can't get those". And thanks for the punch-mark tip Ship. At least somebody's reading the instructions. I usually save the instructions for after I do something. To see if they wrote them correctly. |
