11-27-2012, 06:42 PM | #23 | |
enthusiast
48
Rep 1,695
A correct corner balance is with you in the car or substituted weight, so it will be different for every car since we don't all weigh the same. |
11-27-2012, 08:22 PM | #24 | |
Rep 4,531
(thinking that while you sit, you'll preload the bar on the driverside if you don't corner balance correctly) Yes? |
12-01-2012, 11:48 PM | #26 |
Rep 61
I have these endlinks on my KW V3s. Work great and priced right.
http://www.statusgruppe.com/collecti...sway-bar-links |
12-02-2012, 10:42 AM | #28 |
Rep 11,669
You need rear as well to eliminate pre-load.
.....I haven't found any to fit OE bar yet.
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 12-02-2012 at 12:07 PM.. |
12-02-2012, 01:16 PM | #29 |
Rep 5,329
slightly off topic but is everyone still using the stock ARBs??? their doesnt seem to much out their for the z4m?? however the stock bars are quite thick compared to other vehicles....
seems some use the e46 bars BUT..... they arent quite a direct fit i here.. i did notice that KW have what i think would be a nice upgrade without being silly and risking ripping the mount points.... 29mm front and 24mm rears....
12-02-2012, 02:09 PM | #30 | |
Rep 4,531
3-way adjustable, I have it set on medium stiffness right now. I'm leaving the rear sway bar stock. I like how the rear rotates. TCK confirmed that the H&R bar is a direct replacement, and indeed it was. I do need to reinforce my mounting points, anytime you go with a larger bar you will need to do so IMO. |
12-02-2012, 05:49 PM | #31 |
Rep 1,443
That's what I figured. I received mine from Turner yesterday. They look good...just gotta see if they fit.
12-02-2012, 06:26 PM | #32 |
Rep 11,669
^ E46 M3 is the same OE part #
I'll see if that helps the search.
12-02-2012, 06:27 PM | #33 | |
Rep 11,669
GControl is the only other choice I'm aware of
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 12-02-2012 at 06:39 PM.. |
12-02-2012, 06:46 PM | #34 | |
Rep 11,669
http://store.uucmotorwerks.com/pair-...ies-p1104.aspx
12-02-2012, 07:03 PM | #35 | |
Rep 4,531
Not to mention single adjustable. Don't regret my purchase at all. |
12-02-2012, 07:38 PM | #36 | |
Rep 11,669
I didn't notice the single vs 3 way adjustable difference in the two
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 12-02-2012 at 07:44 PM.. |
12-28-2012, 06:55 PM | #37 | |
Rep 11,669
From what I can dig up, the issue is the way the OE presses over the bar stub. http://m3.madrussian.net/diy/rear_ei...ay/diypop6.htm There has to be tons of slop in the OE bar. I hardly see much point in upgrading mount bushings with these things.
01-02-2013, 10:28 PM | #40 | |
Rep 11,669
I think it's the OE that are press fit. All others bolt the link in place. I've pretty much decide to go with the Turner E46 M3 ARBs with adjustable end links.
01-02-2013, 11:42 PM | #41 |
Rep 1,443
I may have mixed up which attaches which way. Everything is still at the shop cause it's too low to get in my garage now. I just hope Turner will cut me a couple days slack on their 30 day return policy since they told me they'd work.
Edit: ...and Turner was totally cool about the return. Do you know for a fact that the e46 bar fits? I hadn't really intended to upgrade sway bars at this point so I'm kinda bummed since now I can't really properly corner balance but I think I'm done with this project for now. Other priorities have come up.
03-01-2013, 03:26 PM | #42 | |
Rep 11,669
http://www.turnermotorsport.com/p-12...or-e46-m3.aspx
03-01-2013, 04:32 PM | #43 |
Rep 4,531
I have an E46 M3 30mm H&R front sway bar installed no issues here.
http://www.tcklineracing.com/webdocs.../Details96.cfm |
03-01-2013, 06:07 PM | #44 |
Rep 918
You only need one adjustable per side.
Andre - 2J into a Z4 Coupe!
