05-04-2011, 09:50 AM | #23 |
Rep 659
Garage List 2022 M5CS [0.00]
FYI, this is what I have on my airbag and it looks great.
http://cgi.ebay.com/ebaymotors/BMW-C...Q5fAccessories
05-04-2011, 12:38 PM | #24 |
Rep 72
Thank's I will let you know how it turns out with BMW.
That looks like a very reasonable solution. Thanks for the pic. Imagine the bucks and customer frustration BMW would save with a simple solution like that. Most BMW owners don't visit forums that have the support or enthusiast level solutions. "Sir I noticed your emblem is starting to de-laminate, we have a nice overlay that will make it look like new for $XX, would you like us to take care of it for you?" Vs. " No, those claims always get denied". "Can't you just replace the emblem?", "No". "But it's your marque, you would think they would be proud of that, does it affect all cars or just Z4's" "Most all newer cars, I know, it's frustrating, it happens all the time, people are not happy about it, but BMW won't cover it, next" "Who can approve it", "Call BMW NA it's in your book" |
05-04-2011, 01:05 PM | #25 |
instagram 997turbotom
286
Rep 7,377
no luck, I'm sending them in for a refund. I REALLY don't wanna raise the rear, so I'm gonna hold off on that for a bit, until people start telling me "your car looks crooked". lol
05-04-2011, 01:07 PM | #26 | |
286
Rep 7,377
05-04-2011, 01:13 PM | #27 |
Rep 4,061
My emblem is in good shape, but just in case that changes, I've ordered a couple too. Thanks for posting the link!!!
Huz-Z
05-04-2011, 02:26 PM | #28 | |
707
While I don't think they should be on the hook for wear and tear stuff, a delaminate or even a messed up roundel (marque as you say) that could be addressed for a few bucks wholesale when it keeps the customer happy and likely to return for another sale? Priceless. It's business 101. |
05-07-2011, 01:01 PM | #30 |
Rep 72
I got the car back from the dealer last night.
- They were a NO on the air bag emblem - Replaced the black steering wheel trim on the left side pod - Did the SIB on the mount bolts. ( tech said it was a PITA, they ordered new bolts, which took 2 days to get) - Extra key programed Key cost with programing $220 - Replaced M emblem on one wheel that fell off $14.00 - Replaced the front rotors but NOT the pads?..to rid the shimmy. The 2 problems with this experience is that the SA, never called to update delivery status. He was never available to pick up the phone. So I had to have the gal chase him down. The valet pulled up the car. No walk around or recap of work done or not. |
05-07-2011, 03:37 PM | #31 |
Rep 51
Air Bag
When the air bag deploys it basically "quarters" the black vinyl cover. One of the quarters holds the emblem. The emblem looks to be set in place then the cover is melted to hold the tabs in place. I could be CAREFULLY cut out I suppose, but it may not be needed if somebody has emblems which can be placed over this one.
I can do a cut away of this old air bag if anybody is interested in more details of the attachement of the emblem. See pics: |
05-07-2011, 03:45 PM | #32 |
707
Cobra, some negatives there, but given experience around here on rotors having new ones is a huge win. Some dealership in the So Cal area are much better than others. Nikki and others can opine on that topic.
They're not cheap either (500 or so OEM)! |
05-07-2011, 04:01 PM | #33 | |
Rep 820
Drives: 2007 Z4MR silver grey
05-08-2011, 08:22 AM | #34 |
Rep 51
Air bag emblem removal
OK, if you really want to remove the old emblem, it can be done. You need to carefully pry out the old one. It has three metal tabs that hold it to the air bag. In my photos, you can see the location of the tabs. I used a small nylon pry bar and worked it under the emblem at the 9 o’clock position. Then using a sideways rocking motion slid it down closer to the 6 o’clock position. At this point I levered out the first tab. Next, put the bar in between the two remaining tabs, slide it closer to one of them, and then pop it out. For the last tab, I just grabbed on to the emblem and pulled out the last tab.
These tabs are thin sheet metal that has been bent over when the emblem was installed. After the bending, a blob of plastic was melted on top of the tab (from the back). When you are pulling the emblem off you are actually unbending and threading the tab through the vinyl cover. As you can see from the photos, the emblem CAN be removed very cleanly with no damage to the black cover. As far as a replacement, I can tell you it will not be able to be installed the way it was originally. The tabs could not be access without removing the air bag cover, and that is not going to happen. So I think the best thing to do would be to glue or two side tape a new emblem on. |
05-08-2011, 03:30 PM | #35 |
Rep 820
^ Wow, very interesting. They went to a lot of trouble on that factory install. Why not just glue a roundel in there and be done with it? It's almost like they didn't want anyone to "de-badge" it, lol. Or .................. tests showed a glued emblem became a projectile during airbag deployment, so the tabbed through the cover and hot glued version became the "safety" solution
