      01-27-2011, 12:57 AM   #23
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Oversized shipping requires air freight. Operation Dumbo Drop anyone?
      02-19-2011, 02:23 PM   #24
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
Originally Posted by nofear View Post
The ride is way superior to stock,i think other tck owners will tell you the same thing,I don't know how to explain the rattle to you but basically it is the dampers in the shocks, I'm hoping other tck owners can chime in...it did not bother me,but it irritated my wife...You can only hear it at speeds of 10-30 mph ,not higher speeds above that no rattle at all and very smooth ride
I have same issue when it supposedly have intall the new revision. The sound is a constant rattle when car is moving over semi-rough surface. My shop call TCK for a replacement an it took them two weeks to ship the replacement. TCK have to rework the shocks. I forgot exactly what the excuse was. It was cover under warranty because I had the shocks for less than a year.
My car do not have the constant rattle noise after replacing the shocks. It is have some noise which is normal. TCK knows about this issue. You should call them to get a replacement.
The ride is much better than stock when it is at full soft. I run 500/600 spring rate to elimiate the dip-and-swat.
Last edited by RobMCoupe; 02-19-2011 at 02:27 PM.. Reason: Edit: Ask mfanatic325. He drove my car before testing AS SSK.
      02-19-2011, 05:00 PM   #25
GP20
RobMCoupe, how long ago did you get your struts exchanged? The last time I talked to TCK, they mentioned that they have an even newer version of struts available in Feb or March this year.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      02-20-2011, 06:09 PM   #26
RobMCoupe
RobMCoupe's Avatar
60
I was back in Feb 2009. My understanding when I had problem TCK shipped the fron DAs for Z3. That is what my shop told me.
      02-26-2011, 05:32 PM   #27
sunealio
Drives: Z4 M Roadster
Is the setup still available?
