      06-29-2019, 02:52 AM   #375
Willy Sea
Drives: BMW M Coupe S54, E36 M3 Evo,
Originally Posted by 3GFX View Post
Willy, if you would have read only slightly above...
...its the exact setup size wise that I am running except 18".
And thank you now to decide Apex or BBS....................
3GFX722.50
      07-14-2019, 05:21 PM   #376
jra
Drives: 2005 z4
Originally Posted by g2096 View Post
Aloha could I fit 18x9.5 et30 with a 215 or 225/40 tire up front on a 2008 3.0si z4 same size for the rear but 245/35 tire. Car is currently on BCRacing coilovers.
Know a guy on ig running 18x8 et 20 with 205/40 on BC's...would love to hear if you make it work, I'm about to redo my wheels / suspension but i can't figure out aggressive fitments lol
      07-28-2019, 03:33 AM   #377
ZiMMie
Drives: S54/E36
Originally Posted by ZiMMie View Post
Will anyone(E85/E86 owners) be interested in a complete bolt on kit that will allows the rear axle to achieve the same wheel fitment as the M?
i.e. low offset/wider rear wheels?
Following up on my post
19x9 ET 32.. 235/35
19x10.5 ET 25 275/30/19
No fenders rolled.
Before
View post on imgur.com
After
The car..
3GFX722.50
      07-29-2019, 01:05 PM   #378
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
love it
      09-09-2019, 09:46 AM   #379
TexasSpartan
TexasSpartan's Avatar
24
Drives: '06 E85 3.0si
Hey all, I've installed M3 CSL style wheel's on my '06 E85 3.0si w/86K miles and getting a little rubbing when I hit a dip in the road. Wheel size: F 19x8.5(35mm), R 19x9.5(40mm) with Michelin Pilot 4s 235/35 up front and 265/30 on the rears. Car has all stock suspension. Rear springs are not cracked but again, they're stock. I've looked at the tires and can't really see where it's rubbing on the rears. I'm getting some very slight rubbing on the outer corners of the front as well. Car was aligned with full negative camber. I've seen where folks have installed this size wheel/tire combo with no issues and have even lowered the car with still no issues. Could it be that the stock springs are just worn? That seems unlikely though.
2006 E85 Z4 3.0si
2015 F10 535i M Sport Sold
2011 E92 M3 Sold
2007 E90 335i Sold
2006 E90 330i Sold
      09-10-2019, 07:19 AM   #380
3GFX
3GFX's Avatar
Take off a wheel and look inside the fender. Could be suspension related, maybe a liner is drooping. Take a look, the wheel sizes look fine.
      09-15-2019, 02:30 PM   #381
Hullbilly
Drives: BMW Z4
My maths is really letting me down today. Would 18x8 ET29 on the front and 18x8.5 ET40 work on a standard Z4? I’m really confusing myself with the offsets...
      09-15-2019, 04:28 PM   #382
Steeler
Steeler's Avatar
2430
Assuming your car is an E85/86 2003-2008.
By my calcs you will be recessed from the fender lip approx 6mm in front and 16mm in back
https://www.1010tires.com/Tools/Whee...et-Calculator#
My Apex set of 8.5 et 35 fr and 9 et 30 is 6mm recessed in front and flush to fender lip out back
      09-26-2019, 11:53 AM   #383
oscars2212
Drives: lots of cars
18x8 and 18x9 fitment question
Apologies if this has been asked and answered, I really did look (and do research various fitment guides) but I am getting lost in the numbers/concepts. Will the following fit a 2013 z4 35is without any need for changes to the stock set-up for the car?
Front 18x8 ET35 with 235/40 r18 tires
Rear 18x9 ET35 with 265/35 r18 tires
thanks!
PS these are the specific wheels I am contemplating (the sight says they do not fit but I do'nt understand why...)
https://www.ecstuning.com/b-alzor-pa...four/030-5kt2/
      09-27-2019, 07:01 AM   #384
3GFX
3GFX's Avatar
thanks!
They will fit but you'll have some gap in the rear you may want to run a spacer.
      09-27-2019, 07:11 AM   #385
oscars2212
thanks for the reply. Sorry to be dense, but what size spacer would you recommend for the rear wheels?
      09-27-2019, 11:51 AM   #386
Griffendahl
Drives: BMW 328i
I would like to know more...
      09-29-2019, 08:51 AM   #387
blrmkr83
Drives: BMW z4
Style 393 wheels fit???
looking to change the wife's sport package 18in wheels to 17in wheels for a more comfortable ride and found a set of style 393 wheels. Only difference I can find is the 393's came off of a 428i that uses an M14x1.25 lug bolt versus the E89's M12x1.5 lug bolts. Anyone know if the lug bolt size will affect the fit of the 393's? thanks
      10-27-2019, 06:37 AM   #388
Ponta
Ponta's Avatar
17
Drives: Z4 3.0si roadster
Once again I'm here to ask you gents.
CSL reps
235/35 8,5x19 ET 40
265/30 9,5x19 ET 45
Any rubbing on 3.0si without M suspension? I want to put B12 on this car, keeping that in mind, would you go fot it?
I do not want any rubbing at all...
Then again, these are standard tyre sizes to Aplina roadster S (ET 50 on front and rear) and M3 CSL, that is why I am curious.
Should I switch to 225/35 on fronts?
      11-07-2019, 02:00 PM   #389
Mega496
Drives: 2004 BMW Z4 3.0
Hello,
I am went through this treat and I was not sure on the response for a specific wheel sizing. I have a 2004 E85 w/the sport package (stock) and wanted to put some 335i M wheels (style 193M) . They have all the same dimensions except for the ET/offset.
Original car specs are:
Front: 18x8 ET47 225/40
Rear: 18x8.5 ET50 255/35
Style 193 wheels are:
Front: 18x8 ET34 225/40
Rear: 18x8.5 ET37 255/35
Does anyone have any experience with this set up or know if they have any rubber due or negative affects on the handling due to the -13 in offset?
      11-08-2019, 07:46 AM   #390
3GFX
3GFX's Avatar
Originally Posted by Mega496 View Post
Hello,
The rims you mention are the exact same width and are really just gonna poke out 13mm more than the original car specs. Basically the width of an average thumb. It should hardly make any difference. It would be the equivalent of added a 13mm spacer which is fairly common to reduce the gap from fender to wheel.
Everyone need to start using this:
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
      11-08-2019, 07:52 AM   #391
3GFX
3GFX's Avatar
Quick google search of "Style 193 on Z4" yielded this.
https://z4-forum.com/forum/viewtopic.php?t=24726
      01-29-2020, 06:57 AM   #392
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
Having opportunity to get my hands on 359M style rims
Front Wheels: 9Jx19 ET31 235/35/19
Rear Wheels: 10Jx19 ET25 265/30/19
Need your opinion gents
3.0 SI with sport suspension
      02-05-2020, 07:46 PM   #393
UNFORGIVABLE
Drives: E85 Z4 3.0i
Okay. I read every post in this thread and I still have a question. I'm looking to pick up a set of these wheels
18x9.5 et35 (Square)
245/35/18
Car: e85 3.0 roadster.
I did all the calculations showing how much more aggressive these will be compared to stock but the front seems a bit too aggressive.
I plan on lowering with coilovers at some point. I can handle rubbing, I just dont want the car looking ridiculous with poke up front.
My question is really about the front. Is that too aggressive? Need a fender roll? Dont buy?
      02-06-2020, 06:36 AM   #394
ZiMMie
Drives: S54/E36
The rears won't fit.
The front will be ok.
AK72286.00
      02-21-2020, 06:38 AM   #395
JimBob0047
Drives: 2006 Z4MR
Any wheel from the E9X M3 is better suited for the Z4M and any wheel from the F8X M3/M4 is better suited for the the non M Z4.
I ran 513M on my non M Z4 and I'm currently running 260M on my Z4M. No spacers, no rubbing but the tire sizes had to be stepped down a size from what came with the wheels from the factory.
AK72286.00
      03-31-2020, 09:26 PM   #396
krisfnbs
Drives: bmw z4 2.5i
Good evening all.
I'm in the market for a set of staggered 18" Style 107's for the e85 Z4
http://www.bmwstylewheels.com/bmw/107
If anyone has a pair laying around lmk. Thank you.
