01-23-2023, 09:38 AM | #331 |
Rep 40
Yesterday, the air duct / elbow actually popped off again. Despite the adhesive tape. Before everything was without problems the last 5 trips. I must say that this really bothers me, because you always drive with a certain fear that at any time the car could suddenly run significantly too much false air and therefore too lean. Understand Karbonius da also not quite why they have shaped the so conical on such a smooth surface.
Does anyone else of you also have this problem?
Insta: bmw_e86_m_legend
Interested in SOUNDGENERATOR like Airboxsound for S54? Whatsapp to +49 171 - 9945373 |
01-23-2023, 11:51 AM | #332 | |
Rep 978
But Karb should redesign the opening to have a ridge around the opening or adjust it so the OE gasket fits. |
01-29-2023, 10:58 AM | #335 |
///M Enthusiast
43
Rep 110
I’ve been driving with the tape that Karbonius installed from the factory for several months now with no issues at all. If you reach out to them I’m sure they’d be willing to ship you some of the tape they’re now using as standard.
01-31-2023, 09:22 AM | #336 |
Rep 978
the anti-slip tape has worked fine. 500+km and has not moved a bit. The issue I see with the felt tape is that the glue they sometimes use is not very durable. but either will work based on the feedback here
the electrical tape absolutely did not work |
02-03-2023, 12:30 AM | #337 | |
Rep 364
Edit - looks like this forum won't let me post the name of the website and replaced it with asterisks? If you're on NAM3, I'm sure you know who I'm talking about (Epousfluent or something?). |
02-14-2023, 06:24 AM | #338 |
Rep 40
I produced a new holder for the tubes.
I used a simple L-Plastic profil, heatet up, forming it, make a cutout and fix it with sika silicone to the airbox. Works perfekt and looks like original.
grannyknot953.00 |
02-28-2023, 06:52 AM | #339 |
Modaholic
88
Rep 1,705
Installed with GruppeM intake! Had trouble fitting the Karbonius airbox onto the throttle bodies, but found that if you attach the bottom nuts first to get the correct orientation, it makes it much easier.
Also, for the crankcase vent hose, I bought the CSL version and it wasn't exactly the same as the stock one. I had to heat up the ends to remove the plug so I could pop in the stock one that has the tube to vent oil vapor.
Euro Delivery - April 2007
wdb4762.50 |
03-09-2023, 11:55 PM | #342 |
Rep 364
Sorry - as far as I know there isn't another group buy.
Incidentally, Karbonius sent me some of the felt tape (my airbox came without it since it was one of the first sent out). Hopefully I'll fit it on the weekend. |
GrayZ4MCoupe8.00 |
03-21-2023, 09:35 AM | #343 |
Rep 978
I re-installed the CSL dipstick for a cleaner look, the issue is that with all the sound generator piping in the way now I have the same issue as most M3 owners do with CSL dipsticks, not been able to access it easily. But my car consumes no oil and I can remove the solenoid vacuum line and electrical connection when needed to check oil.
i also had to plug the hole with a stainless M6 bolt. I like the more stealth look. |
GuggagZ4M22.00 |
03-21-2023, 09:47 AM | #344 |
Rep 783
Strange that it's called a sound generator when it is really a sound release.
I'm sure if BMW had called it a release people wouldn't have scoffed at it so much.
2008 E86 M coupe
03-22-2023, 10:17 PM | #345 | |
Modaholic
88
Rep 1,705
03-23-2023, 03:58 AM | #347 |
Rep 40
Hi together,
a few days ago, my elbow slipped off the Karbonius box again, despite the new tape, which Karbonius sent me specially. The problem is that, as expected, the adhesive of the tape also softens with heat. Thus, the tape is now slipped down (although I have previously degreased everything!). I have then again written to Karbonious and asked for a real solution. It is now manufactured an attachment, which should finally fix the issue completely. I hope that also works. Because otherwise the danger for a too lean mixture is present (because of false air).
03-24-2023, 12:22 AM | #350 | |
Rep 364
Hi Guggag, Do you have any more information about the attachment? Will it go onto the opening of the airbox? I'm definitely keen for a solution more permanent than tape! |
03-24-2023, 12:25 AM | #351 | |
Rep 364
03-24-2023, 06:46 AM | #352 |
Rep 978
