01-24-2024, 09:56 PM | #2906 | |
Rep 12,570
You just need to drill 1 tiny hole so you can get the nubs out. Last edited by 3002 tii; 01-24-2024 at 10:02 PM.. |
01-27-2024, 11:08 AM | #2907 |
Rep 978
Revised Karb OE Style box |
01-27-2024, 03:07 PM | #2908 | |
Rep 2,882
01-28-2024, 08:53 AM | #2909 |
Rep 1,694
I wouldn’t mind a set. Where did you get them?
01-28-2024, 08:57 AM | #2910 |
Rep 12,570
01-28-2024, 08:58 AM | #2911 | |
Rep 1,694
01-28-2024, 03:00 PM | #2912 |
Rep 103
do it ! easy swap every other year
2007 Imola Red Z4M
2005 Phoenix Yellow M3 6MT 2013 Interlagos Blue M3 6MT ZCP CF roof |
01-29-2024, 10:54 AM | #2913 |
Petrolhead
445
Rep 814
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Wheels are back from powder coating. I'm so happy with the way they turned out (Super Chrome Plus for the barrels, BMW Silver for the faces). New OEM center caps and stem valve covers. Car was also polished (3 step process) and ceramic coated while in the garage waiting for the wheels to be put back on.
Also got a set of Bumperplugs since I can't stand front license plates. She's now covered up in the garage until spring.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
02-06-2024, 11:04 PM | #2916 |
Rep 12,570
Don’t have CSL box but I did pick up a RE elbow myself that I plan to pair with an Eventuri intake. Just been lazy and waiting for temps to warm up a little to so the install.
02-07-2024, 11:35 AM | #2917 |
Rep 4,060
03-11-2024, 02:42 PM | #2919 |
Rep 12,570
Finally installed a mirror mount for my Uniden RD. I have to say this product is awesome. Tons of adjustability and very secure. And at $20 something it’s great value considering Blendmount goes for $100+
I can confirm this fits the E85/6, F10, F25 and F15 models. For the Z, the spacing is tight but the key is to position the rear view mirror to your liking first, and then secure/tighten the screws. Pretty sure seller sells attachments for other brands like Escort and Valentine. But I was able to use this for both my Uniden R4 and R7. |
03-12-2024, 05:40 PM | #2920 | |
Rep 26
Chris |
03-12-2024, 10:17 PM | #2921 | |
Rep 12,570
Bought one of those wire kits that has RJ on one end and power & ground on the other (with small fuse in between). And then simply plugged the power & ground directly into the mirror connector. Even though you don’t have auto dimming, you should still check to see if you have the wire behind the plastic trim. Takes 2 seconds to check and there’s good chance the car was pre-wired for it. Else I would just run it across headliner and go directly to fuse box. There’s dozens of threads on Bimmerpost but something like this. FWIW I may actually have a spare wire kit. Happy to send to you if you cover shipping. |
03-13-2024, 06:48 AM | #2922 | |
Rep 26
Thanks for the reply and tip to check for power. Very kind offer on the wire. I'll send you a PM. Chris |
03-21-2024, 07:45 AM | #2924 |
Rep 267
Drives: 2006 Z4 M Roadster
New starter for my Z4M. It went out last week after solenoid stuck in the engaged position. With motor running it smoked the starter coils. Never had one fail this way before.
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic 2012 X5 M - Monte Carlo Blue Metallic 2017 X1 xDrive28i - Alpine White |
03-21-2024, 10:59 AM | #2925 |
Rep 4,060
03-21-2024, 11:00 AM | #2926 | |
Rep 4,060
