05-15-2021, 03:48 PM | #2443 |
dances with roads
4773
Rep 4,102
I bought mine from BMW. They're easy to find. Example:
https://www.shopbmwusa.com/Product/5...ERED-FLOOR-MAT |
05-15-2021, 03:57 PM | #2444 |
Rep 1,345
Drives: 04 Z4, 18 X3 M40i
05-15-2021, 03:59 PM | #2445 |
Rep 3,004
Annual service coming up + front bumper lower right support bracket replacement....
Genuine BMW Sheet Metal Screw 07119904176 ES#: 14514 Mfg#: 07119904176 Qty: 5 Genuine BMW Oil Drain Plug with Washer - S54 S65 S85 ES#: 259336 Mfg#: 07119904550 Qty: 1 Genuine BMW Phillips Screw F Plastic Mat 07146959925 ES#: 16609 Mfg#: 07146959925 Qty: 5 Genuine BMW Hex Head Screw 07147129161 ES#: 16850 Mfg#: 07147129161 Qty: 5 Castrol EDGE Professional TWS 10w-60 Engine Oil - 1 Liter ES#: 2580488 Mfg#: 07510009420 Qty: 6 Mahle OEM Oil Filter for E46 M3, MZ3, MZ4 (S54 Engines) ES#: 11067 Mfg#: 11427833769ML Qty: 1 Expanding Rivet - Pack Of 10 ES#: 2576034 Mfg#: 51717007296KT Qty: 1 Genuine BMW Front Fender Liner - Lower Right - Z4 M Coupe, Z4 M Roadster ES#: 129348 Mfg#: 51718046084 Qty: 1
Racerbruce
wdb4773.00 |
05-15-2021, 09:30 PM | #2446 |
Rep 568
The last skyer blades......and what else do you buy an e85? A playmate. Now which are the blades going to look best on?
05-16-2021, 08:45 PM | #2447 |
Rep 1,695
I finally got a set of 219M's for the Z4 today! They will be refinished but have yet to decide if I will keep the current color or try a dark grey color.
05-17-2021, 08:32 PM | #2448 |
dances with roads
4773
Rep 4,102
05-19-2021, 04:44 PM | #2450 |
Rep 1,134
Drives: '07 M Roadster
Got a factory new steering wheel installed today. Along with that I finally got around to cleaning the inside of the gauge cluster and installing some OEM headlight bulbs. This new wheel feels amazing, and the difference is amazing compared to my old one. My car has about 80k on the clock and my original wheel is hard and glossy. Most of the finish on the trim parts has worn off as well. Feels good to treat my car to some refreshing.
By the way, getbmwparts.com has new M wheels on sale for under 600 right now! https://www.getbmwparts.com/oem-part...el-32307836820
05-23-2021, 05:31 PM | #2452 |
Rep 508
Drives: 2007 M Coupe
Garage List 2007 E86 Coupe [0.00]
2006 Z4 3.0si Coupe [6.00] 2002 330 CI [0.00] 2018 BMW 240M [0.00] 2007 M Coupe [10.00] |
Almost ready to ship, 2 more carbon hatches, roof panel and new wing for the race car. We also just got our new design upper and lower rear control arms in and our self centering shifters. All design specifically for the Z4. When you are ready to take it up a notch let me know. 😉
racerbruce3857.50 Blackbox88881.50 |
05-24-2021, 06:28 AM | #2453 |
Rep 208
Drives: 08 Z4 M Coupe
I'll be taking my Z4 MC in today for it's annual oil change and wallet draining. This year it's getting Vibra-Technics motor mounts, Rogue Engineering transmission mounts, new driveshaft flex disc and center bearings, new water pump, thermostat, temp sensors and coolant hoses.
05-29-2021, 01:44 AM | #2456 | |
1624
Rep 4,296
how much for a set? the rest of the stuff also loos real nice!
Powered by |
05-30-2021, 04:15 PM | #2457 |
Rep 978
06-02-2021, 01:44 PM | #2460 |
Rep 1,695
After screwing up my exhaust by removing the secondary cats and putting in a Magaflow resonator the drone is horrendous on the highway.
And with a trip to ZFest in Greenville looming next month I can't do that drive again with the drone so, I ordered these high flow 300 cell cats from Schmiedmann and these are very nice. Once I have them installed I will post a short video of how they sound. |
06-03-2021, 04:48 PM | #2461 |
Rep 39
Drives: 2005 Z-4 roadster
Cabin Filter
You have to be a contortionist to do it and I found about four hand full of leaves stuck in a 2005 Z4. But it can be done if you follow directions from even though is says easy job on the box.
06-14-2021, 08:02 PM | #2462 |
Rep 1,695
We finally got my top working after getting rebuilt hinges from Top Hydraulic, new soft top motor, rebuilt kit, and two quarts of hydraulic fluid.
06-15-2021, 02:01 PM | #2463 |
Rep 355
StormWerks Handle Set
e-brake feels classier
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
3GFX722.50 wyshyvanuk472.50 |
06-16-2021, 09:24 AM | #2464 |
Rep 127
Installed Bilstein B6 all around. Though firm, I think more compliant than stock. Also removed CDV - great improvement.
wdb4773.00 wyshyvanuk472.50 |
