      05-21-2011, 06:46 PM   #1
crfine88
crfine88's Avatar
442
Drives: E86M
M coupe on a diet
The table of contents will be updated as items are added to the thread
Table of Contents
Post #1 Nav/Stereo delete
Post #16 OEM Battery & accessories
Post #26 Bulkhead Delete
Post #58 "Light weight" battery and bracket
Just finished removing the complete navigation/stereo system.
There were a lot of questions and speculations about weight, so here is the break down.
04.8 lbs-Harness
01.0 lbs-misc brackets
04.2 lbs-2 Kick panel Speakers
14.2 lbs-2 Rear subwoofers
00.2 lbs-GPS antenna
09.0 lbs-Amps/amp brackets
03.4 lbs-4 mid range speakers
00.2 lbs-2 tweeters
03.6 lbs-GPS/DVD drive
02.4 lbs-Pop-up display
02.6 lbs-Head unit
45.6 lbs total
      05-21-2011, 06:54 PM   #2
Samjam927
The One And Only
Samjam927's Avatar
15
Drives: 2006 TiAg ///M Roadster
2006 Z4M Roadster  [10.00]
2003 Z4  [5.00]
interesting, why take it out for such minimal weight loss?
      05-21-2011, 07:47 PM   #3
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
~46 lbs.
So racing type seats; 80lbs for both?
Braille battery, 30 lbs?
Aftermarket exhaust, 40 lbs?
A/C 50 lbs?
So, maybe possible to get under 3,000 lbs?
      05-21-2011, 08:35 PM   #4
pal
pal's Avatar
437
Drives: Z4 M Coupe
That's a decent loss - thanks for the great data. Do you have pictures of the process and the aftermath? I want to keep it all there but see if there is space around the subwoofer for a custom rollbar.
      05-21-2011, 09:17 PM   #5
biped
Drives: 97 e38, 01 e38, 07 z4mc
Because all the minimal things add up. You are using the wrong criteria.
You should be asking :
Is it bolted down ? Will the car still run with out ? yes/yes... good pull it.
      05-21-2011, 11:35 PM   #6
-c-
-c-'s Avatar
Drives: bmw
Looks like the original guess on weight was right on ...kick but.
      05-22-2011, 06:36 AM   #7
onebluemcm
onebluemcm's Avatar
45
Drives: '07 Z4MC
~46 lbs.
A/C 50 lbs?
The Z4M Grand Am car my friend had in 2008 weighed 2900 lbs and that was with anywhere from 50-100 lbs added to it to keep it 2900 - sanctioning body requirement. That was obviously with a roll cage, fire suppression system, dry sump oil system, and cool suit stuff. IF you really want to gut one, lightness is definitely achievable.
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
      05-22-2011, 09:35 AM   #8
Hairballs58
Needs FI
Hairballs58's Avatar
Drives: '06 Z4MR
I'm curious how your interior looks like now too.
      05-22-2011, 01:18 PM   #9
Finnegan
Finnegan's Avatar
Not looking to really gut one; but a couple hundred pounds is about the same as adding 20 HP. Add braking and handling and even MPG benefit.
      05-22-2011, 03:14 PM   #10
ZStig
instagram 997turbotom
286
Drives: Interlagos Z4MR
I'd rip the system out too, if I didn't enjoy the music so much!
      05-22-2011, 04:32 PM   #11
wrose
Drives: 2007 Z4MC
2006 Z4M Roadster  [8.50]
2007 Z4MC  [0.00]
2005 X3  [0.00]
Now you have a great location for a gauge pod -where nav. screen was
-Can watch the boost rise as well as feel it .
-I'm trying to figure our where to mount a boost gague -mounted the ft.splitter yesterday but waiting for my S/C to arrive and install before putting the bumper back on9hopefully next weekend.
_ great updates on your ongoing project
Wayne
      05-22-2011, 07:09 PM   #12
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
Did you add anything back in afterwards (IE headunit or speakers?)
I'm about to put my old girl on a diet once I decide to cut her up for a roll bar, it's amazing how much difference weight makes yet many often overlook it. I've always been one to gut my cars in areas where people least expect it (IE shave foam off the underside of carpet, undercoating removing on the interior, lighter seats, etc).
2004 Porsche GT3 |White
HRE R40 Monoblocks | KW Clubsport Suspension | RSS Lower Control Arms and Suspension Links | GT3RS Wing and Front Bumper | Cup Car Lip | Euro GT3 Seat | GMG Half Cage | Europipe Exhaust | EPL Tuning
      05-23-2011, 06:44 AM   #13
bhoch
SSGT USMC - '78 - '86
bhoch's Avatar
Drives: Z4 3.0si
2007 BMW Z4  [7.33]
conversation with wife:
Me: Shame we are not closer to Cave Creek, AZ.
Her: Why?
Me: I could swap out my dash and get the built in NAV installed from someone there from the forum. Cost would be well worth it.
Her: Thankfully we are not closer to Cave Creek AZ.
Thanks,
Bill
2007 3.0si Roadster Black/Red, sport, Piano Black F14 Forgestar's
      05-23-2011, 07:44 AM   #14
crfine88
crfine88's Avatar
442
Drives: E86M
I can see what you mean, but 46 pound is significant in my book and the dieting is not finished yet
~46 lbs.
A/C 50 lbs?
That is goal. I'm not ready to part with the A/C yet. That will be the last to go. I will try to make up for that weight in other areas.
I will post photos up soon. There is a ton of wasted space under the platic sills below the small rear windows. There is a flat spot there that would be good for mounting a cage, but access for welding would be tight. Might work for bolt in though.
Yes, I agree
nailed it (although I did give myself a 10-15lb +/- )
Good to know we can get them that low. I am going to see how close I can get without fully gutting the car out.
I am going to try and keep some sort of balance between dropping the lbs and keeping a stock look from the cage forward. I hope to drop a few hundred pounds and still keep the interior looking good (fingers crossed)
Can't hear the music over the RPI's I think I used to like how it sounded, just can't remember
Wayne
Thanks Wayne
The gauge pod location in the dash has crossed my mind.
Nothing went back in, but I am thinking about a future project with a removable stereo system in the back section. The only weight that would be added to the front would be tweeters and kick panel spekers. The head unit, sub, amp and aux batt would all be a part of a removable "boombox" of sorts.
Her: Why?
I have had many of these conversations with my wife
      05-23-2011, 07:58 AM   #15
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
subscribed.
the only music I ever listen to in the coupe is the S54
      05-23-2011, 08:00 AM   #16
crfine88
crfine88's Avatar
442
Drives: E86M
More Dieting
-45.2 lbs Batt.
-06.4 lbs acc's on top of batt.
-03.6 lbs batt bracket
-55.2 total
+15.0 rplc batt + custom bracket
40.2 total weight saved
      05-23-2011, 09:30 AM   #17
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
Getting ready for beach season?? lol
Good to know how much weight could be lost with such a simple stereo delete. (since I don't have nav to begin with)
Agreed A/C should be last thing to go, until it's dedicated...especially in AZ.
      05-23-2011, 02:01 PM   #18
ZStig
286
I like that scale. Gonna have to pick one up later on amazon
      05-23-2011, 02:34 PM   #19
Finnegan
Finnegan's Avatar
Subscribed.
I'm guessing you're going to need to keep that lightweight battery on the charger when off the road though!
This is an interesting thread and I'm hoping I can get some ideas for long-term diet projects w/o too much loss in functionality (A/C is a tough delete in AZ for example).
      05-23-2011, 03:56 PM   #20
a_riddler
Bimmer Noob
a_riddler's Avatar
Drives: 08 Z4MC;08 MBZ E350 4Matic
Headlight washer system can go also. The pump to the headlights is at the low point in the reservoir though so you can't pull that unless you find a plug. I was hoping to find a reservoir from non-m model but it looks like they also have the headlight washer.
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing,
AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges
      05-23-2011, 04:24 PM   #21
crfine88
crfine88's Avatar
442
Drives: E86M
subscribed.
yep
Had it for a few years now and it has always been very accurate up to 150lbs
Subscribed.
Ended up going with a 20lb option for more reliability since we do still take the car on road trips.
Good call. I removed this during the Splitter install
      05-23-2011, 07:41 PM   #22
imom
Drives: Subaru BRZ ....... Z4MR (SOLD)
Wow Crfine...how come you haven't pulled the trigger yet and just get carbon fiber body parts. Forget this diet business and go for the serious lippo suction and stomach stapling. Your car will be the monster of a 2600+ lb car with 450HP or more...sorry I didn't follow up on your modification journal, but giving modest numbers...you're probably over 500+ HP now - 1/4 HP for the headers.
I wonder with all of your mods if you're under 3000lbs yet? Very impressive if it already is.
OH BTW, losing AC in AZ is insane especially in the summer...that's really dedication for a car...but to each their own.
