FORUMS
- 5
| 03-29-2011, 04:01 AM | #45 | |
![]() I noticed a big improvement especially at one of the tighter corners on the track where I used to have trouble gettting into second gear.
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
| 03-29-2011, 03:11 PM | #46 | |
![]() ![]() Drives: Sapphire Black/Black Z4Mc Join Date: Oct 2008
I'm going to see how the UUC reds non-bolt through w/o enforcer do on the noise/control spectrum. Thank you for offering up this data point as I think we should have a pretty good spectrum to work from: Stock - Black Neoprene Trans - Black Poly Trans - Red Poly UCC - Re Poly UUC + Enforcer - Vorshlag Orange Bolt Through/UUC Red Bolt Through - Vorshlag Orange Bolt Through/UUC Red Bolt Through + Motor Mounts. At least that's how the spectrum from least noise/control to max noise/control looks like it will pan out. I'll start a new thread in the technical section in the next week or two and try to pull comprehensive listing together based on prior threads, this thread, and any other input folks have. |
| 03-29-2011, 04:13 PM | #47 | |
| 03-30-2011, 03:37 PM | #48 |
Took a few pictures of the Vorshlag mounts while the car is on the lift for the header install.
| Bookmarks |
| Tags |
| ssk |
