Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
      03-08-2011, 09:23 PM   #1
blender
Custom User Title
blender's Avatar
Drives: black
Braille 15# installed
I am thinking of going to the Braille 15# or 17# battery with the HPA bracket vesus the stock 45# battery. Intended usage will be warm weather only, trickle charger between drives.
Does anyone here have any experience good or bad with these batteries? Longevity? Faults?
Thanks in advance.
      03-08-2011, 10:52 PM   #2
nlink720
Drives: 2004 BMW Z4 Roadster
I got the 11 pound Braille last year. It has been a good battery, but I will say that you cannot leave the car on without the engine running (like I did for five minutes at the post office so that my wife could have the heated seats on + daytime running lights were on too). We had to push the car to start.
In the summers, it isn't bad, but in the winters, it can strain sometimes to crank, but never failed to do so other than the one example above. I am happy with the battery, and would buy it again knowing what I do today. I saved about 35 pounds, and have a whole lot of space where the battery was.
FS: Leather Recaro Pole Position Seats & Hardware
      03-08-2011, 11:04 PM   #3
inTgr8r
inTgr8r's Avatar
Drives: E86 Z4MC; E92 M3
JMO but it's not worth the cost.
Weight savings is one thing, but it's at the wrong end of the car to be dropping lbs.
      03-09-2011, 12:08 AM   #4
nlink720
Well it depends on what you are using the car for. Between seats,wheels, battery, and miscellaneous items, I have saved 200 pounds, and it has come from all parts of the car. To flatly state that weight should not be removed because it is from a particular side of the car is a little too narrow in my view. Plus, 35 pounds can easily be compensated for by a small adjustment in corner balance. Perfect 50-50 is not going to be as significant in my view as a lighter car that is, say 49.5%-50.5%.
I would not get the battery for daily driving, but I would get it as part of a comprehensive weight reduction plan.
      03-09-2011, 12:36 AM   #5
a_riddler
Bimmer Noob
a_riddler's Avatar
Drives: 08 Z4MC;08 MBZ E350 4Matic
Do not bother with the carbon batteries. I know of a driver that had to return several of them.
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing,
AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges
      03-09-2011, 07:25 PM   #6
blender
Custom User Title
blender's Avatar
Drives: black
It seems the EAS guys (reseller) recommend the 15# at a minimum for a daily driver, and opting for the 17# if you have comfort-assist or other juice-hogging options (which I don't).
I'll note the battery change amounts to less than a 1% weight difference ( 30 into 3300+) but every bit helps.
      03-09-2011, 07:36 PM   #7
The HACK
Roger Murdock
The HACK's Avatar
521
Drives: 2006 MZ4C, 2015 Fiat 500e
If you have coil overs it can easily be adjusted to shift the weight back one way or another.
The hell I don't! LISTEN, KID! I've been hearing that crap ever since I was at UCLA. I'm out there busting my buns every night! Tell your old man to drag Walton and Lanier up and down the court for 48 minutes!
-Roger Murdock
      03-15-2011, 12:24 AM   #8
ZStig
Drives: sold: VT2-525 M Roadster
I had an oddyssey pc680 in my 3.0, I liked it
      03-15-2011, 10:29 AM   #9
Incompatible
Drives: 07 AW Z4C 3.0Si
Roffle, How long did you have it? Was it a DD or a weekend toy? How long could you let the car sit? Did you need to use a trickle charger? .... Any different handling then a conventional battery? And the big question, would you do it again?
      03-15-2011, 10:46 AM   #10
Twisted Six
Twisted Six's Avatar
Drives: Z4si-coupe
Lol....you can tell Lance is an Engineer with his line of thorough questioning..
      03-15-2011, 10:54 AM   #11
ZStig
from what I remember, it was just like a normal battery. daily driver. didn't trickle charge it. Used in cold climates with no issue. Only issue was to make sure you get car battery posts for it, and making a custom mount for it. I'd do it again, once my oem battery dies
      03-15-2011, 11:32 AM   #12
inTgr8r
inTgr8r's Avatar
Trudat....
I wonder how many guys running COs actually get the car corner balanced?
      03-15-2011, 12:41 PM   #13
Incompatible
And is that not the kettle calling the pot black? back at you.
I took a look at their website; http://www.odysseybatteries.com/battery/pc680.htm. Price is very attractive, with free shipping no less.
      03-15-2011, 12:56 PM   #14
The HACK
Roger Murdock
The HACK's Avatar
521
Trudat....
I got my coil overs just so I can corner balance the car easily. My MZ4 Coupe sits at nearly the same ride height as OEM.
-Roger Murdock
      03-15-2011, 01:42 PM   #15
Twisted Six
Drives: Z4si-coupe
Why I neeeeever,lol
Regarding weight......go with that Odyssey. When the dealer warranty replaced my intermittent OEM unit....they used an even LARGER unit.
      03-15-2011, 05:56 PM   #16
z4mnyc
z4mnyc's Avatar
Drives: Z4 M Coupe
As Riddler mentioned, don't bother with the carbon fiber batteries. I've had two of them and both failed to hold a charge for more than a day. I since switched to the non-carbon fibre Braille battery and it has worked great. I do leave it on a trickle charger when the car is going to be sitting in the garage for more than 4 days.
It will definitley run down quickly, for example -you need to be careful not to leave the lights on for any period of time without starting the car. I leave a set of jumper cables in the trunk just in case.
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
      03-15-2011, 06:23 PM   #17
Incompatible
Mine is primarily weekend use. Would you expect a battery like the Odyssey to drain that fast? TIA
      03-15-2011, 06:25 PM   #18
ZStig
no it won't drain as fast. you can compare specs on their websites
      03-15-2011, 06:52 PM   #19
blender
Custom User Title
blender's Avatar
Drives: black
FYI - bracket solution for the Odyssey:
http://www.bimmerhaus.com/vendors/wiles.html
OEM battery = 43-45 lbs.
PC680 + box = 18 lbs.
"Simplify and add lightness" - Colin Chapman.
      03-15-2011, 06:58 PM   #20
esqu1re
esqu1re's Avatar
31
Drives: M Coupe
I'd dismissed lightweight batteries as an option, but all this talk has gotten me thinking again...Gah!
      03-15-2011, 07:30 PM   #21
blender
Custom User Title
blender's Avatar
Drives: black
Lightweight Battery Specs
Culled from vendor's websites (their claims, not mine):
The Braille unit is superior on paper to the Odyssey for the 15lb size:
Attachment 497320
Locating suitable Z4/E46 brackets are the issue, not many choices. My opening post has one.
Odyssey explains some terminology:
Cold Cranking Amps: For all the power, durability, and life of our technology, the cca ratings can seem disapointing. That's because the cca ratings are often misunderstood. Odyssey batteries are SLI (starting, lighting and ignition), so if you are looking for a starting or reserve battery the cold cranking numbers can be irrelevant.
The "standard" cca test measures the output of a battery for 30 seconds of crank at 0 degrees with the ending voltage of the battery being 7.2v. Some companies use 15 or 20 seconds and some companies use 32 degrees which can make for better results.
A vehicles starter isn't designed to withstand 30 seconds of cranking so we feel the batteries starting power is more important. The Odyssey part numbers represent the 5 second cranking power of the battery.
The PC680 is rated at 680 amps for 5 seconds, 595 amps for 10 seconds, and 525 amps for 20 seconds. Cranking power is even higher for the first four seconds. Similar sized lead acid batteries are only rated at 180 - 220 amps.
      01-08-2012, 08:56 PM   #22
blender
Custom User Title
blender's Avatar
Drives: black
Finally got the Braille kit (battery +bracket) installed, after buying the SAE battery posts separately -they were not included in the kit. Weight savings are nearly 30 pounds.
Battery read 12.7v upon arrival. I'll check it in a day or three to see if there's any significant parasitic draw. Ancillary wires in the photo are for an ignition capacitor and a trickle-charger harness. Both appear to be working normally with the new battery. Car starts normally; not worried about especially cold temps here in SoCal.
Tags
battery
Search this Thread:
Advanced Search
