      02-03-2011, 10:25 AM   #1
crfine88
crfine88's Avatar
437
Drives: E86M
DIY RPI Exhaust Using Jack Stands
DIY Intro:
50 Photos / 17steps / Post #1 Part I / Post #2 Part II / Post #3 Part III
Since I have removed and installed the axle back exhaust about a dozen times, I figured it was time to do a DIY. This is photo heavy step by step DIY including some good tips. The DIY only includes instruction for the passenger side. The steps are exactly the same for the driver’s side. You may also notice that the RPI's are already on the car while it is being jacked up. For the purpose of the
DIY, I put the passenger side OEM muffler back on after the car was off the ground.
Hand Tools Used:
01. 3/8 ratchet
02. 3/8 13mm deep
03. 3/8 12mm shallow
04. 3/8 8mm deep
05. 3/8 8mm shallow
06. 3/8 2" extension
07. 3/8 4" extension
08. 1/4 ratchet
09. 1/4 13mm shallow
10. 1/4 8mm shallow
11. 1/4 3" extension
12. 13mm ratcheting combo wrench
13. Cordless 90 degree driver with 3/8 male adaptor
14. Graduated caliper
Support Tools Used
1. 6 jack stands
2. 3 wheel chocks (4 would be better)
3. 4 wood blocks
4. Shop blanket (creature comfort )
5. Low profile 3.5 ton jack
Reference Material:
From realoem.com
From 2007 BMW TIS
Step 1
Secure front wheels
Step 2
Locate jack point #4 from the BMW TIS ( be careful around the rear diff )
Step 3
Jacking up the rear of the car. Go through the next three photos and read the tips before you do this step.
lining up the jack
jacked up with good alignment and not touching the rear diff cover
Watch the front
Step 4
Jack stand/wood block placement. (review the next two photos/tips)
Tip
Step 5
Locate the front jack point (BMW TIS #1)
Step 6
Review the next three photos related to jacking up the front of the car
Step 7
Front jack stand/wood block placement
Step 8
Remove the rear diffuser. There are 8-8mm fasteners and 2-12mm caps
Coi288.50
      02-03-2011, 10:25 AM   #2
crfine88
crfine88's Avatar
437
Drives: E86M
DIY RPI Part II
Step 9
Mounting Location A Remove 13mm hardware and gasket ring. Once you do this the muffler will pivot up and down; the pivot points being mounting locations B & C
Step 10
Mounting Location C Remove 13mm bolt. Once this bolt is removed, you will want to support the weight of the muffler as will only be hanging by mounting location B.
Step 11
Mounting Location B Remove 13mm bolt. Read tip in second photo. Once this bolt is removed the muffler is no longer attached to the car.
Step 12
Retain all OEM hardware for installation of the RPI exhaust except for the Mounting Location B 13mm bolt. A new shorter 13mm bolt is supplied by RPI
Coi288.50
David701567.00
      02-03-2011, 10:31 AM   #3
crfine88
crfine88's Avatar
437
Drives: E86M
DIY RPI Part III
Step 13
Attach RPI muffler @ Mounting Locations B&C hand tight.
Step 14
Attach RPI muffler @ Mounting Location A hand tight.
Step 15
Fine adjustment for gap between muffler tips and rear bumper cover. This takes place while tightening the 13mm hardware @ mounting location A. There can be a lot of back and forth here until you get your desired gap.
Step 16
Tighten 13mm bolts at Mounting Locations B&C
Step 17
Fine adjustment for exhaust tip protrusion
      02-03-2011, 12:10 PM   #4
r4gs
Viper Driver
Singapore
36
Drives: F-16
^chris, thanks for the superb pictorial writeup! i opted to go the lift route (a lot faster and convenient) and have since re-adjusted my exhaust tips since my initial install. what really helps is ur very last tip on exhaust tip protrusion. my left tips stick out ever so slightly more than my right ones, so i'm going to readjust the 8mm nuts just immediately below the rear bumper cover to fix this. however, i do notice my tips still stick out quite a fair bit more than urs do? it's protruding about 0.5 inches now.
this whole perfect placement thing is seriously a work of extensive patience and meticulous detail. i've opted to go visually with my alignment since i don't have access to a digital micrometer, but i'd say it's about perfect for my very particular human eye now.
      02-03-2011, 12:31 PM   #5
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Great DIY, even more awesome Z4M.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      02-03-2011, 12:47 PM   #6
anthony @ eas
anthony @ eas's Avatar
Drives: R56 Cooper S
Wow, it looks like it took a lot of time to put this DIY together. Nice work
      02-03-2011, 01:23 PM   #7
mousitch
Dark Sider
mousitch's Avatar
127
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Awesome thread right here! Could of used this the first time I did a swap. After six or seven I'm an old pro. Had no idea about the moving rear cover though. Sweet!
2008 Space Grey M Coupe-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert settings
      02-03-2011, 01:24 PM   #8
tekmoe
tekmoe's Avatar
55
Drives: ///M
Very awesome of you to do this writeup. The fact that you took the time to explain how to jack the car up properly is golden. This will be very useful when I change out my diff and tranny fluids.
Thanks again!
      02-03-2011, 04:55 PM   #9
BlackMoupe
Mouper
BlackMoupe's Avatar
Drives: _____
      02-03-2011, 06:10 PM   #10
mpower03
Drives: 08 z4 M Coupe
well written diy!
      02-03-2011, 07:29 PM   #11
RBull
Drives: 2007 M Coupe
Great write up. Thanks for taking the time.
      02-04-2011, 10:03 AM   #12
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
Didn't know about the 3/8" play in the bumper. Will need to see if I can get my exhaust protrusion to look right with your tip. Thanks!
      02-04-2011, 10:04 AM   #13
Eccentric
Eccentric's Avatar
51
Drives: Interlagos Z4 M Coupe
Chris, I really appreciate you doing this for me. Thanks dude
      02-04-2011, 11:16 AM   #14
johanness
Drives: 2008 Z4MC
Mad props for taking the time for this DIY
      02-04-2011, 04:42 PM   #15
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Thanks again!
What a wonderful DIY with lots of great tips! I couldn't agree more on the jacking tips!
      02-04-2011, 06:45 PM   #16
a_riddler
Bimmer Noob
a_riddler's Avatar
Drives: 08 Z4MC;08 MBZ E350 4Matic
Bookmarked! Very well done, very high caliber effort!
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing,
AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges
      02-04-2011, 10:09 PM   #17
l4zy
l4zy's Avatar
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
2017 BMW M3  [0.00]
2015 BMW i3 REX  [0.00]
1995 BMW M3  [10.00]
2013 BMW X3 xDrive35i  [7.00]
WOW awesome DIY! I didn't remove the diffuser for my install though. Probably would have been a lot easier on me if I did =P
      02-07-2011, 06:39 AM   #18
crfine88
crfine88's Avatar
437
Drives: E86M
A lift make things much too easy
Glad you found the write-up useful because that's what it's all about. Since gasket ring is round and the mufflers pivot on an axis, the lower the muffler hangs the further it protrudes from the bumber cover. If your muffler hang a little lower than mine, this may be why thye stick out further
Thanks Tom
Thanks Anthony. The labor was quick, but the photo editing and write-up took more than 8 hours.
Thanks man
Thanks again!
no problem, this is why included "using jack stands" in the title. I figure if someone is searching the DIY for how to Jack up the Z4, this thread should pop up. I'm glad you found it useful.
Originally Posted by SSKE92 View Post
Originally Posted by mpower03 View Post
well written diy!
no problem, glad this tip helped out
Thank you
Yep, it can be done without rear diffuser removal. You just get better access around the bulky stock muffler with it romoved.
      02-07-2011, 06:42 AM   #19
crfine88
crfine88's Avatar
437
Drives: E86M
Thanks for all the feedback guys. It makes the efforts of doing the DIY all worth while.
      02-07-2011, 09:49 AM   #20
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
solid work. more great input into the z community on your behalf
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 *
'14 Jeep Grand Cherokee Overland Hemi... No more snow for the M!
      02-07-2011, 03:10 PM   #21
VinnieAces
VinnieAces's Avatar
Drives: Imola Red Z4MC
2006 Z4 M Coupe  [8.00]
your workspace for ur car is godlike
///M - Some Mods 'N Stuff
      02-16-2011, 01:27 AM   #22
jdl1pt
Drives: Z4M coupe 2007 IL Blue
Thanks so much for the great write up, very impressive!
Search this Thread:
Advanced Search
