09-08-2010, 01:54 PM | #1 |
Rep 2,464
Z4MC wheel alignment
What do you guys suggest for an aggressive but street use? I have 245F and 265R Hankook V12s. I also have Dinan springs.
I know I want about -2 -2.5 camber for the front (or as close as I can get to these numbers since I have the stock suspension), but not sure about toe and caster. I have no idea about rears. Thanks! |
09-08-2010, 02:22 PM | #2 |
Bimmer Noob
30
Rep 567
I'm running the following:
-2.5 Camber Front 0 Toe front -2 Camber Rear .10 Toe Rear Your welcome to take my car for a lap on the autocross course next session. I've seen how slow you drive, not worried you'll break anything... There is noticeable wear on the fronts though. Since I've still got the stock conti's, I'm not worried about it, but I can't comment on what the long term wear would be.
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
09-08-2010, 02:32 PM | #3 | |
Rep 2,464
I'll have the alignment this week (part of the accident thing). What is the caster you're using? |
09-09-2010, 07:03 AM | #4 |
Rep 637
I didn't think caster was all that adjustable on the stock set up - have I been misled?
And I would just say that to get -2 to -2.5 degrees up front, you need shims or camber plates - I thought ~ -1.8 was the most you could get with the stock camber adjustment up top. Do let us know what they did and what you end up with.
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
09-09-2010, 07:18 AM | #5 | |
Rep 11,669
-2.4 Camber Front 0.0 Toe front -2.1 Camber Rear 0.03 Toe Rear
09-09-2010, 10:52 AM | #6 |
Bimmer Noob
30
Rep 567
I didn't ask for any changes to Caster.
Ended up with: 5.9 Left, 6.07 Right Before was: 5.98 Left, 6.13 Right
09-09-2010, 11:03 AM | #7 | |
Rep 11,669
I have shims.
09-09-2010, 12:14 PM | #8 | |
1821
Rep 5,337
On the track my car is happiest at -3.0º front camber, -2.0º rear camber, with 3/16th toe-out front and 1/8th toe-in rear (no caster adjustment). Would I run this on the street? Not really. No matter how "aggressive" you drive on the street you're never going to see the kind of wear you're going to see on track. Not even remotely close. Take my alignment settings and cut everything in half, and swap from toe-out up front to toe-in up front and you'll get a pretty good "street" setting regardless of how "hard" you drive on the street. |
09-09-2010, 05:28 PM | #9 |
Rep 2,464
Thanks for the replies guys. I think I remember one member was able to get -1.9 camber but in general everyone is around -1.5 with stock setup. I'll either get whatever I can get or I'll order Turner motorsport washers... didn't decide yet, since I'll invest on camber plates next year...
@Hack, I guess it is because of my poor English, you never seem to understand me and give me answers with attitude... |
09-09-2010, 07:00 PM | #11 |
Rep 11,669
....just got back from alignment.
With my drop the lowest I can get on front camber is -2.75 with 2 shim washers. (Eibach on Koni struts) I'm really looking forward to running this setup tomorrow, but I don't think I can keep it like this long term. I'll have to go to 1 washer to get camber in the -2.4 range.
09-09-2010, 07:05 PM | #12 | |
1821
Rep 5,337
My point is this. You will never need the amount of camber recommended by some of these members here. Anything OVER -1.5 for street use is overkill. If you don't plan on taking the car to the track (heck even if you ARE planning on taking it to the track) any camber over -1.5 with zero or toe-out up front will eat through tires like crazy. So even your "aggressive" but mostly street driving, any sort of alignment outside of what the factory recommends, in my not so humble opinion, is a waste of time and money. For example, my typical "turn" at the track can involve a 120+ mph right or left hander REPEATEDLY, up to 15 times in a 25 minute span, pulling in excess of 1G. That sort of "grip" and forces that require any sort of negative camber more than 2 degrees up front will NEVER be experienced on the street. At least not safely nor possible without killing a lot of people and destroying a lot of properties. So my suggestion to you is, instead of being offended by what I have to say, take my track specs, cut everything in half and toe-in up front instead of toe-out. That is a good starting point for street alignment and will preserve your tires. Trust me on this. Negative camber up front for you is USELESS. |
09-09-2010, 07:15 PM | #13 | |
M = Midlife Crisis
66
Rep 2,006
2006 Z4MC - #LL93158
