      08-12-2010, 11:36 AM   #23
a_riddler
Bimmer Noob
a_riddler's Avatar
Here is a link to the Z4 M Coupe/Roadster spreadsheet:
https://spreadsheets.google.com/ccc?...Hc&hl=en#gid=0
You'll find that the Z community is very well informed about the cars...
      08-13-2010, 09:33 AM   #24
Hawkeye
Hawkeye's Avatar
No_Country
258
Drives: '07 Z4 si Coupe, '08 R6
There is some dude leaning on your car. Otherwise it looks tip top. Wish I had an AW M...
2007 Z4 3.0si Coupe 6 MT Black Saphire Metallic PP SP Heated M Seats Clutch Stop Stubby
2008 R6 Raven Black GPR Steering Stabilizer Comp Werks FE Hotbodies Flush Mount Blinkers
2016 GMC Sierra SLT Z71 Premium Plus 4x4 K&N CAI Toyo G2 LT305/55R20
      08-13-2010, 03:02 PM   #25
Finnegan
Finnegan's Avatar
Congratulations! That's a beauty!
The supplemental ///M manual can be found here
. No differences for 07/08 (as far as I know the car did not change, and the 07 supplement looks exactly the same as the 06). The M supplement covers the ///M features and differences; the rest of the car is the same as the Z4.
If you're looking for the "regular" manual, that's the just the Z4 download from the BMW site or from this link. The Z4M has some extra features, but it's basically a Z4. Unfortunately the regular manual doesn't cover navigation, and it references a separate Nav/Computer manual which the BMW site doesn't have available for download!
Here is the list of all the manuals you should have. The only thing I can find for the computer/nav/sound system is this. This is not the Z4 computer/nav manual, but the computer functions appear for the most part to be very similar (some exactly the same) to those in the Z4. I think it should help a bit to point you in the right direction at least to get started.
The best bet probably would be to find someone near you with a full Z4 manual set and take it to a copy center....in the meantime, see if this helps.
      08-17-2010, 03:20 PM   #26
zer0xity
Drives: 2008 M Coupe
Finnegan: thanks a lot! Those links are basically what I was looking for. I read in the Z4 M Coupe brochure that the car can measure tire pressure as a standard feature. Does anyone know if that's part of the onboard computer? I couldn't find it anywhere. Just curious.
      08-18-2010, 02:51 PM   #27
CFoote
Drives: '06 Z4M, '00 M5, '01 X5 4.4
Unfortunately, in the Z cars BMW does not allow you to read out the tire pressure in each of the tires; it is simply a warning system that turns on a light in your gauge cluster if it senses the tire pressure hits a certain threshold (I think it's 10psi below what you set the system, but someone reply and confirm?). The system is not as sophisticated as in newer cars, but it serves the same purpose -- if there's a real problem, it will let you know
Chris
'06 Z4M, '01 X5 4.4i, '00 M5, '05 Acura RL, '12 X6 3.5
Tags
california, manual, meets, z4 m coupe
