      07-20-2010, 10:16 AM   #133
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Well I just got an email from LeatherZ stating that the RE mounts might be backordered until the end of the month. I'm thinking about cancelling the order and going with the UUC option 1 complete or option 2. Decissions decisions.
From what I've read, it is an easy swap so maybe I should gamble the 35 bucks and try the option 2. If I don't like, try to sell them and go option 1. Yup, thats what I'm going to do, just decided.
      07-20-2010, 10:24 AM   #134
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
Dang it. I just ordered from leather z 2 minutes ago.
      07-20-2010, 11:19 AM   #135
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Just ordered UUC (cupless) before you guys suck up all the inventory there too.
      07-20-2010, 12:08 PM   #136
jragan
Imola Lover
jragan's Avatar
I'm going to be the a-hole and come out and say that your bushings aren't going to "solve" this. Because you're now trying to re-create the "problem" (which is changing, subconsciously, how you work the clutch just the slightest bit) you will not, as a result, be able to reproduce it. In fact, you're actually solving the problem by your deliberate attempts and resulting subconcious adjustment. The problem is in the synchros and the speed at which they engage (which is why a fraction of a fraction of a second of added pause with the clutch in or slipping the clutch the tinyest bit solves the problem). After you install the bushings, once you relax and settle back into your driving habits, you'll start grinding again.
Hers: 997-1 C4S: Pics
      07-20-2010, 12:28 PM   #137
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^ bushings = CDV?
      07-20-2010, 01:05 PM   #138
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
I got the cupped one. We can compare afterwords. =)
I'm not completely sure I understand what you're saying, but if the problem is indeed in the synchros, then nothing we do this side of upgrading the synchros will work? First thing I'm going to do when I get this in is to rev it up beyond 5k and do a quick shift into 2 and repeat until I'm satisfied. Someone with this mod should post more of their results for the same.
      07-20-2010, 01:22 PM   #139
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
IMO, we're dealing with 3 separate issues in this thread.
a) 1-2 grind which is tranny design/synchos; other fluid may help RP Synchromax, Redline MTL etc.
b) Downshift to 2nd gear rejection under loading conditions. = tranny mounts
c) Clutch engagement feel = CDV
      07-20-2010, 01:28 PM   #140
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
      07-20-2010, 02:08 PM   #141
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
The synchros are always engaged, no? they don't move when selecting other ratios, only the fork does. The bushings will not solve the notchiness, which I agree, is BMW's "design" but the denial under load was indeed solved, which was my goal. I never had any grinding of any kind, just a really bad inconsistency. Many BMWs suffer from this condition, ask anyone with an E36 M3 how fast they changed their bushings
      07-20-2010, 02:23 PM   #142
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
Ah! Yeah, denial into 2nd is a huge problem for me.
      07-20-2010, 02:33 PM   #143
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^ me too, I'm good otherwise.
I had a track day recently that has a hard right hairpin requiring a 3-2 shift.
I could get it maybe 25% of the time.
It also has a hard left hairpin requiring a 3-2 shift, which was no problem.
Another M Coupe had exactly the same problem.
I'll be back there in Sept with the new mounts, so it'll be a great comparison.
      07-20-2010, 03:01 PM   #144
Blind32
Blind32's Avatar
Drives: '07 Z4MC
The problem I speak of is the denial of going into 2nd and that hideous grinding noise that comes with it. Feels like the shifter only goes 1/2 way in.
25% of all your laps? How many laps did you do? Just trying to determine how many times it denied you. Sounds like your report will definitely be a great comparison.
      07-20-2010, 03:26 PM   #145
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
For me it's this:
Denial into 2nd can happen without grinding. This happens more often than grinding (that bzzzt sound), which always also results in denial into 2nd.
      07-20-2010, 04:00 PM   #146
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
lol... damned if I know; lots!
There were only ~ 16 of us there & had the track all day.
      07-20-2010, 06:17 PM   #147
jragan
Imola Lover
jragan's Avatar
Interesting. This is the first I've heard of a problem from 3-->2 under load. My local road course is extremely tight and very technical (i.e. fairly slow) and I've never needed to touch 2nd gear (and I was always one of the faster on the track). Maybe you should drive faster so you don't need to downshift into 2nd... I keed, I keed!
      07-20-2010, 06:32 PM   #148
RBull
Drives: 2007 M Coupe
Pretty straight forward to me too that these are 3 genuine and separate issues with this car.
      07-20-2010, 06:47 PM   #149
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
lol.... I've driven that corner faster a couple of times with negative (oh shit ) results.
This isn't a high speed track. I barely get into 4th on the back straight.
It's a very technical 2.5 mile loop with 14 corners.
It shows your short comings in a hurry.
The funny thing is the downshift is not just driver error, since others find the same thing on that corner.
It's also strange that it's only the right hander that's a problem, the left hand hairpin is no problem at all.
I'm really looking forward to testing new tranny mounts to see the difference.
I'll definitely post my findings.
      07-20-2010, 06:58 PM   #150
RBull
LOl, ours is 1.6 miles with 11 corners and lot of elevation changes and I also just hit 4th on the back straight with the G. They claim it to be one of the most technical tracks in the country. My shortcomings were certainly evident early too.
I experienced the 3>2 rejection a couple of times in CB. Just can't remember now which direction of turn but sounds like it must have been a right hander.
Too bad you aren't down a little earlier to have a run.
      07-20-2010, 07:04 PM   #151
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Yeah, that'd be great.
I'm definitely planning on CB, just not sure when we'll hit it.
      07-20-2010, 07:20 PM   #152
jbh
jbh's Avatar
18
Drives: 2007 Z4M
Lots of 3-2 rejection for me last Sunday. It happened 100% of the time on my 8 laps autox. This is the issue I am trying to fix.
Local Indie shop was aware of the problem and recommended the uuc mounts with the cap over the RE mounts. Recommended black over red due to the vibrations. I ordered them last night. Also ordered the replacement cdv valve as well. Hopefully it will all be better now.
Indie shop said about 25% of the BMW cars they see have updated mounts and most of those cars never see the track.
      07-21-2010, 08:43 AM   #153
Blind32
Blind32's Avatar
Drives: '07 Z4MC
1-2 rejection for me last night leaving a stop sign. Only ran it up to about 4k.
      07-21-2010, 09:03 AM   #154
jragan
Imola Lover
jragan's Avatar
Originally Posted by jbh View Post
Lots of 3-2 rejection for me last Sunday. It happened 100% of the time on my 8 laps auto. This is the issue I am trying to fix.
Are you talking about Lonestar Bavaraian? Which track were you at?
