      04-03-2024, 07:44 AM   #2949
maupineda
Drives: E86 Z4MC
You know, I thought this a lot when choosing the ratio, and settle on 4.1. Now I think 3.91 might be a better compromise… and, you can still go to a 12% increase by changing tire size down to 40/35 from 45/40.
A 3.91 is 8% increase, tire size is 4%, and 4.1 is 13%.
      04-03-2024, 08:38 AM   #2950
grannyknot
grannyknot's Avatar
953
Drives: 2008 Z4M coupe
I rebuilt my diff a couple of yrs ago and swapped out the stock gearing for 3:91 gears, I do like the quicker take offs but I'm wishing now that I had gone with the 4:10 instead.
2008 E86 M coupe
      04-03-2024, 10:03 AM   #2951
3002 tii
3002 tii's Avatar
2305
4.10s is more fun and better ‘bang for buck’. The only time 3.91 is better is when you’re on the highway. Cruising at 70-75mph no longer feels like cruising. But just comes down to what you want, but the M won’t ever feel tame with 4.10s.
Follow for latest mods
      04-05-2024, 01:04 PM   #2952
dre99gsx
Drives: 1994 Toyota Supra
Improved splitter mounting
TRiCC264.50
wdb4773.00
      05-11-2024, 06:13 PM   #2953
3002 tii
3002 tii's Avatar
2305
After getting boatload of maintenance done (rod bearings, vanos, cooling), decided to get the car dyno’d. Only drivetrain mods are Euro headers, 100 cell high flow cats and off the shelf Epic tune. Put down a respectable 298whp, which means I should be able to crack 300 once I install the Eventuri intake in few weeks
wdb4773.00
86Zed937.50
MVRS4.50
      05-11-2024, 07:29 PM   #2954
homebrw
homebrw's Avatar
Drives: 06 Z4 MR, 22 Mustang GT PP1
Congrats! 300 at the wheels on an 18 year old is legit!
3002 tii2304.50
      05-14-2024, 12:04 PM   #2955
robblr
robblr's Avatar
Drives: 128i 6MT
Took a few months to arrive, but good art is worth waiting for.
Going with an Alpha-N tune from pokeybritches .
86Zed937.50
wdb4773.00
      Yesterday, 06:02 PM   #2956
SepangZ4MC
Drives: Z4M Coupe
I am attempting to program this homelink mirror
on my coupe but couldn't find any programming instructions on it. After researching for a bit, this doesn't seem like the stock oval mirror. Anyone know what BMW this mirror is from?
      Yesterday, 09:03 PM   #2957
ried
ried's Avatar
Drives: E86M, F31, F80
Isn't there a part number on it?
      Yesterday, 09:30 PM   #2958
cbpip
cbpip's Avatar
175
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [0.00]
Try this
Clearing Existing Homelink Programming
Before you can program new settings, you must clear the existing programming in your Homelink system. Here’s how:
Step 1: Start by sitting in your vehicle near the garage door opener. Car on, not started. Doors closed.
Step 2: Locate the Homelink buttons on your car’s visor or rearview mirror.
Step 3: Press and hold the first and third Homelink buttons simultaneously until the indicator light begins to flash slowly.
Step 4: Continue holding the buttons until the light changes from a slow flash to a rapid flash, indicating that the programming has been cleared.
Programming Homelink for a Single Garage Door Opener
If you have a single garage door opener, follow these steps to program Homelink:
Step 1: Again, sit in your vehicle near the garage door opener.
Step 2: Press and hold the desired Homelink button you wish to program and the button on your compatible remote simultaneously.
Step 3: Wait for the indicator light to change from a slow flash to a rapid flash, indicating successful programming.
Step 4: Test the Homelink button by pressing it to ensure the garage door opens or closes as expected.
      Today, 09:22 AM   #2959
wdb
dances with roads
wdb's Avatar
4773
My experience with older Homelink mirrors (2007 in my case) is that they won't work on modern doors without an adapter. And the adapter doesn't maintain its settings through a power outage. Which makes it essentially useless. I gave up and now use a clip-on unit from the garage door maker.
XMetal1167.00
