      01-15-2020, 09:58 AM   #1
MiamiBimmerClub
Drives: AY F80 M3
Any Legit 3.0si N52 flash tune out there?
Is there any way to squeeze more power?
      01-15-2020, 06:17 PM   #2
rjahl
rjahl's Avatar
998
Drives: Z4 35is
2012 Z4 35is  [0.00]
Have you looked?
Check out the E90 section
Your real options exclude:
Tune
MLVS
Headers
Supercharger
Naturally aspirated your probably capped at 245HP at the wheels, supercharged can get you another 50.
If your stock and a manual you are probably sitting at 215 at the wheels.
      01-25-2021, 04:42 AM   #3
M-Cast
M-Cast's Avatar
Drives: 2007 M Coupe
2007 E86 Coupe  [0.00]
2006 Z4 3.0si Coupe  [6.00]
2002 330 CI  [0.00]
2018 BMW 240M  [0.00]
2007 M Coupe  [10.00]
Both Epic and Kassel have tunes for the 3.0si, but both are around $900.
I am running with the following.
SuperSprint headers and race exhaust.
Dinan bigi bore throttle body
AFE cold air intake
JB Lightweight flywheel and clutch
The 3.0si already has the stage 3 intake. There is not much more you can do.
If you really want more power you should look at upgrading the differential to a 3.73 LSD
      01-25-2021, 10:45 AM   #4
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
We got 337.6 whp with the ESS G1 supercharger, custom intake, water/meth, and 10 psi of boost on a 2007 Z4 3.0si. The lack of vacuum available to actuate a normal bypass valve is our current obstacle. While there are venting options available, my intention is to not run alpha-n in the future and instead run a MAF-based tune, so we are looking at electronic bypass valves.
wdb4773.00
pyshin110.50
      01-31-2021, 04:58 PM   #5
FrenchieTacoZ4
Drives: 2006 Z4 3.0i 6spd manual
2006 BMW Z4  [0.00]
2004 BMW Z4  [0.00]
I got my stage 3 tune for $360 from Kassel performance. I had a stock 3.0, did the 3 stage manifold conversion Kassel tuned it for me.
      02-01-2021, 02:14 PM   #6
Steeler
Steeler's Avatar
2430
Severn Tuning and pokeybritches are as legit as it gets for this platform whether N52,M54 or S54!!
      02-02-2021, 04:43 PM   #7
Spec-Al
Drives: bmw
AFE cold air intake
Curious if you were able to dyno this setup?
      02-06-2021, 07:48 PM   #8
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Have Ess SC with their tune, AFE meth injection, Dinan throttle body, 3.73 diff working on LSD, jb lightened flywheel and Sachs stage 2 clutch, on the fence about MILV and once divorce is settled going to work on trying to get SS headers and car retuned ...can def squeeze more ponies out of it an si
      03-26-2021, 02:59 PM   #9
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Finally got some numbers back from the Dyno comparing the 2 known providers of Tunes for the N52
DynoJet Results
Kassel Performance 253.15 Whp and 291.12 estimated at the crank.
Epic Motorsports 248.74 Whp and 286.05 estimated at the crank.
Through the mid range the Kassel has about a 10hp gain but less above 6300 RPMs. I think with a little more time the Kassel could get to 255.00
My Takeaway is if you are racing then the Kassel is a better bet, but for the street the Epic is less stress on the engine.
List of Modifications:
  • Headers
  • Straight pipe exhaust to Supersprint Muffler
  • Dinan larger throttle Body
  • AFE Cold Air intake
      03-26-2021, 04:39 PM   #10
rjahl
rjahl's Avatar
998
Drives: Z4 35is
2012 Z4 35is  [0.00]
DynoJet Results
  • Headers
Is there any chance the AFR charts are reversed for the two tunes?
One goes pig rich at the top, almost looks like cat protect is not turned off. You would expect that tune to produce the least amount of power in that range.
      03-26-2021, 06:35 PM   #11
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
The dyno guy said the same thing, we ran both DME's for 6 runs each. I have sent the results to get an explanation from Epic.
rjahl997.50
      03-27-2021, 01:45 AM   #12
Willy Sea
Drives: BMW M Coupe S54, E36 M3 Evo,
Interesting, thank you for sharing this.
Keen to look at torque increase line, to see where any increases are.
      03-27-2021, 09:15 AM   #13
rjahl
rjahl's Avatar
998
Drives: Z4 35is
2012 Z4 35is  [0.00]
So are these charts,"the best of six" or an average?
      03-27-2021, 08:24 PM   #14
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
These are the average, the Kassel hit 258.03 one run
      04-13-2021, 03:29 PM   #15
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
FYI
So I went to VIR a few weeks back for CCA club race with the Kassel tune and ran into a small problem. The torque limiter kept throwing the car into limp mode.
This is a rare issue but one to be noted, Jim said this had only happened once before and it just so happened to be his car. We are adding the MLVS to the mix this time around to see if we can pick up another 8 to 10 whp so hopefully the adjustments will fix the issue.
wdb4773.00
      04-22-2021, 02:48 PM   #16
E86Z
Drives: 3.0si
Will Kassel offer the milvs tune?
      04-24-2021, 06:41 PM   #17
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Yes, I just finished getting mine installed and am waiting to get the DME back for another test day.
      05-07-2023, 01:34 AM   #18
ornicar
ornicar's Avatar
No_Country
136
Drives: 125i
Hi,
can you pkease give us your feedback with the Milvs Kassel tune?
      09-19-2023, 08:13 AM   #19
StiffNeck
Drives: 07 BMW Z4 3.0i
I apologize, I just dropped to the bottom response so if this is redundant then I apologize. Active Autowerkes's does have a magnificent Z4 tune for the 3.0i available for $500. I purchased it and absolutely love it. But the real cherry is that working with Nick ( the actual programmer ) or one of the Hugh brothers, ( the actual founders of AA is such a positive experience it in my humble opinion is the way to go since it is so easy to then have AA deliver another tune at a reduced cost for any other mods you may do. They are stellar fast at updating your exacting mods into thier personalized tunes it is incredible and they are so willing to do it too. Hope this helps.
      10-22-2023, 03:24 PM   #20
Mysecondwife
AF Officer
Drives: '11 335xi M Sport/Black-Black
Looking for CAI bolt on OEm swap for my ‘08 E85 3.0si?
2011 335i xDrive/BSM on Black/6AT/M Sport/Performance Edition/Premium & Cold WX Packages/Nav/Paddle Shifters
2009 328i xDrive/Titanium Silver on Black/6MT/Sport, Convenience, Premium & Cold WX Packages
