      01-17-2023, 10:58 PM   #1
z4ninja
Drives: 2003 bmw z4
Thumbs up I want to run thicker tires for better ride quality
Hello I have a 03 z4 sport
I have front 18 8.5 et 35 running 225/40/18 and rear 18 9.5 et 35 running 255/35/18
I kinda want to get a thicker tire because ride quality is bad. I do not want to size down on wheels as this is to my liking. Is there other sizes rear wheels that can fit with no issues?
      01-18-2023, 07:52 AM   #2
grannyknot
grannyknot's Avatar
999
Drives: 2008 Z4M coupe
I went up to 245/40 18 front and 275/40 18 rear, it did improve the ride quality, it was noticeable but not a lot.
If you are still on stock shocks and springs you shouldn't have any problems with rubbing.
If you have lowered the car then you may have to increase the neg camber to avoid rubbing.
2008 E86 M coupe
      01-18-2023, 09:40 AM   #3
Emmrbee
Retired
Emmrbee's Avatar
Drives: 2006 Z4M Roadster
Try this web page for comparisons
https://tiresize.com/comparison/
      01-18-2023, 10:43 AM   #4
wdb
dances with roads
wdb's Avatar
5021
You might also want to consider new shocks and other suspension refresh items on a 2003 car.
One of the biggest things you can do is ditch the runflats if the car still has them. Carry a patch kit or a AAA card and put non-runflat tires on the car. Runflat sidewalls are very stiff compared to non-runflats and really impact ride quality.
      01-18-2023, 11:25 AM   #5
KevinC
your average JAMF
KevinC's Avatar
If running runflats, get rid of those turds and you probably won't feel the need for a "thicker" tire. Suggestion to refresh suspension components is also a good idea, assuming they haven't already been addressed at some point since new.
'21 M2 Comp
'19 Golf R
      01-18-2023, 01:13 PM   #6
Rafichicago
Rafichicago's Avatar
Drives: 2018 M5 2009 E63AMG Wagon
Shocks and ditching run flats are your best bet on your car. If you diy remove the wheel support suspension at the bottom and unbolt the shock. Push it in. If it doesn’t return or doesn’t require significant force to push in its shot.
