06-28-2016, 08:48 AM | #1 |
Rep 71
Top motor may be dead
I was enjoying a nice top down day on my drive to lunch and decided the car needed a wash. Took it to a hand wash place, got it back nice and shiny, lowered the top and drove back to work. After work, lowered the top, drove home, and when I got home the top died halfway up. Had to manually raise it.
I'm guessing my top motor is dead even though I had removed the driver side drain plug. Any suggestions on how to trouble shoot? Am I looking at $2k for the labor and parts to replace the motor? If so, does anyone want to help me out on a weekend to replace it with me? I'm willing to pay for your time. I appreciate any advice. |
06-28-2016, 09:02 AM | #2 |
Rep 355
I paid 1k(parts + labor) for motor at an indie.If it's just the motor(probably),that's about what it should run you.
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
06-29-2016, 08:28 PM | #3 | |
Rep 758
Top Down 365
07-01-2016, 07:17 AM | #4 |
Rep 1,907
I paid about $800 total getting a used motor off the classified section at my indie shop. $2k seems like a lot even for stealership.
07-01-2016, 08:48 AM | #5 |
Rep 1,689
I got a brand new motor and clean out vacuum lines before I took delivery of mine last June.
There was a tropical depression a few weeks ago and it rained for a while here on Florida. Went to put the top down after the storm and the top motor sounded muffled which meant it was UNDER WATER! Spend about four hours yesterday on due diligence about getting a new top motor moving the top motor to the trunk, I got a quote for $1,500 plus the move. Sounds way too high so more research is needed. Good luck to you. |
07-02-2016, 03:49 PM | #6 | ||
Rep 758
Looks like you're here in Orlando? If so and you want a hand drop me a line.
Top Down 365
07-02-2016, 08:40 PM | #7 | |||
Rep 1,689
I want to move the motor to the trunk because I think if I don't I just may need to do this again next year. Thinking of just having the top manual, but I probably won't do that. Currently I am waiting on a call from a shop in Winter Springs since they did two Z4 tops this week. Let's talk so you can walk me through the process, if you don't mind. I will buy drinks! And yes, I am in Orlando. |
07-07-2016, 07:17 AM | #8 |
salty cowboys fan
6158
Rep 3,406
+1 for DIY with Shipkiller's guide. It's not so bad, and don't need any special tools IIRC. I had to replace the pump on my old 3.0i sport a few years ago, I believe I paid around $400 for a new pump and maybe some fluid, can't remember... But I do remember thinking after I was done that I could do it again within an hour or two.
Watch the paint if you decide to!
07-17-2016, 09:27 AM | #10 | |
Rep 106
BTW - the motor replacement can be done at home using Shipkillers guides. Good luck |
07-17-2016, 04:04 PM | #11 |
Rep 779
Mines been dead for 2 years, I would totally move it to the trunk and never look back whn I do mine..
-Roranji
Spaceman Spiff85.50 |
04-13-2017, 03:27 PM | #12 |
Rep 71
Finally found enough change between the cushions and a reputable shop (my local shop At Speed closed) to take in to replace the pump. look at this corroded crap.
Luckily the shop lets me bring in my parts. but the lines may need to be changed too. argh |
04-13-2017, 09:00 PM | #13 |
salty cowboys fan
6158
Rep 3,406
Special place in hell reserved for the guy that decided to locate the pump next to the water drain
04-16-2017, 10:46 PM | #14 |
636
Rep 3,124
Right next to the guy that designed the Vanos exhaust hub and the guy that didn't use a key on the plate with the camshaft splines, so that the bolts are stressed in shear and well, shear.
04-17-2017, 10:58 AM | #15 |
Rep 71
Got the car back and took it for a drive this weekend with the nice weather. Man was it nice to be driving it again with the top down for the first time in a few months! almost worth the $2k!
The car was covered in pollen so I took to a touchless car wash and duct taped over the driver side top drain access. Should I be concerned about the passenger side drain as well, does that drain go near the pump or any of the top mechanics? |
04-17-2017, 11:11 AM | #16 |
Rep 35
Two people to move the top back off the car, and the blue painters tape all along where the top meets the paint are the two most important parts of the job to remember. Also when removing the left side shelf tray support, finding the little plastic rivet in the middle top of the tray support took me a few minutes. The rest is pretty straightforward if you pay attention to all the guides out there. I am way too tall to get into the trunk but was able to reach the bolts just by leaning in and working above/behind my head. If you have any lower back problems take some ibuprofen first.
04-17-2017, 11:47 AM | #17 | |
Rep 758
The touchless car washes are even worse than a regular wash because of the higher volume of water they use. There's really no car wash that doesn't have some negative effect on a vert car. In either a touchless or a conventional car wash the chemicals (soap & wax) are designed for automotive paints, not top canvas, and they can be caustic to the cloth materials.
Top Down 365
04-19-2017, 09:22 AM | #18 | |
Rep 71
.... and the potential for speaker damange! that guy should be kicked in nuts! |
04-19-2017, 10:33 AM | #19 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
Salty
04-24-2017, 01:45 PM | #20 |
636
Rep 3,124
I think they have a justification for that.
They wanted to keep the crank short, and therefore the block, and therefore also save weight for racing. Fine if you have a crew that's going to pull the motor and rebuild it every few races. Not so fine for a street machine.
