10-10-2015, 03:30 PM | #1 |
Rep 12,570
Dead ECU, any INPA Users Here?
I did headers a while back and had a tune from AA that turned down the o2 sensors for inspection purposes. Everything was fine but I would get a weird surging idle. AA offered to revise the tune and I figured may as well purchase their new flash loader for quicker uploads. Big mistake.
After following all procedures and uploading the tune, my car won't start. Turn the key and the engine cranks but it won't turn. I the unplugged the AA flash loader and hooked up my OBD diag device and even that can't connect to my ECU... wtf?! I then tried to recover my ECU using my backup tune but still same result. And I also noticed this time the AA flash loader showed "vehicle manufacturer ECU hardware number shows ????" For those familiar with INPA, can I recover my ECU? I've never used it before but at this point I'll try anything. Did some research online and seems like INPA may be able to recover if I realign the DDE and EWS. Last edited by 3002 tii; 11-07-2015 at 12:06 PM.. |
10-10-2015, 04:34 PM | #2 |
#buildnotbought
11116
Rep 4,930
INPA doesnt flash ecu's
BMW uses other programs for that. They have 2 but I'm not sure about the difference. The bmw flash tools are not exactly user friendly. INPA is diagnostic with some adjustment on components. But if you can read your cpu with inpa, your ecu can probably be saved. I have no idea if the bmw flash tools will be able to handle your backup file. (I doubt it)
10-10-2015, 04:42 PM | #3 |
Rep 12,570
Flash or not, my question was really asking if INPA can be used to fix my car using those few adjustment capabilities? I've read others with similar symptoms stating it was an immobilizer issue and "realigning the DDE ans EWS" using INPA allowed the ecu to start communicating again.
10-10-2015, 10:24 PM | #4 |
Rep 12,570
Mini update but I'm convinced my ECU is bricked. Not sure how it happened as my voltage was good and the laptop never froze. *Sigh*
10-11-2015, 07:58 AM | #5 |
Rep 400
I'd try to get a hold of AA. I bet they will be able to give you some advice. I doubt your DME is toast. Worst case though, you might have to send your DME to them to reflash it.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500 |
10-16-2015, 06:40 AM | #7 |
Rep 12,570
I sent in my ECU, EWS (what a pain to remove) and key to AA. They're going to recover and reload the map and send back. Just no idea how long it'll take because they need to get a Z4 3.0 in their shop to test before shipping back to me.
11-06-2015, 09:03 PM | #8 |
Rep 11,669
Glad to hear that you are mobile again.
Sounds like it was a real PITA.
11-06-2015, 10:02 PM | #9 |
Rep 12,570
It was but what can you do? Anyways if anyone ever has a fried or bricked ecu, I highly recommend shipping it to RPM Motorsports. They were able to able to recover my ecu back to stock, really professional crew over there.
11-07-2015, 07:31 AM | #10 |
Rep 11,669
Thanks, added to subscribed
11-07-2015, 02:08 PM | #12 |
Rep 12,570
They "owe" me a tune so I may ask for a map that's same as factory but with o2's turned down so I can pass emissions. I'm hesitant for a performance tune since I no longer have the weird idle. That's the thing with off the shelf tunes, n52 on z4 isn't same as e90. I'd imagine its same as the s54 tune for the m3 won't work as intended on the z4. Maybe down the road I'll get a custom dyno tune from Frank Smith.
11-07-2015, 05:23 PM | #13 | |
Rep 882
I did some research looking into the E90 with the N52 and the E87, they have the same version of ECU as the Z4's. But the N52 was used in many different cars so the ECU might vary. |
11-07-2015, 06:25 PM | #14 | |
Rep 12,570
11-16-2015, 02:57 PM | #15 |
Rep 932
I am about to contact RPM Motorsports to rebuild my e36 M3 DME. I hear they are the best because I have another company to check my DME and they screw it up. Now I have 2 VINs and it is an automatic.
11-17-2015, 09:10 PM | #16 |
Rep 12,570
Tell Zach Daniel with Z4 referred you, he'll the excellent care of you
11-02-2020, 12:38 PM | #17 |
1999 E46, 2002 E53, 2007 E85....all in progress
Rep 103
Hello all. I just used BimmerLabs files and WinKFP to flash my 2007 Z4 N52 software from a
3.0i to a 3.0Si and now the car cranks but wont start. Any help would be greatly appreciated!!! _
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress..... Last edited by CrazyOneToo; 11-02-2020 at 12:47 PM.. |
11-03-2020, 12:02 AM | #18 |
Rep 2,782
It could be several things, but a checksum error is most likely. Flash a stock tune with WinKFP and see if it solves your issue.
11-03-2020, 01:28 PM | #19 |
Rep 103
How would I check for that issue? Here is what I saw.
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress..... |
11-03-2020, 06:36 PM | #21 |
Rep 103
11-03-2020, 07:07 PM | #22 |
Rep 2,782
Did you try writing a stock tune?
