      10-10-2015, 11:56 PM   #1
Nikitas_Z4mcoupe
Nikitas_Z4mcoupe's Avatar
15
Drives: Z4 m coupe
Z4m coupe top speed 300km/hr
As its my first post here, I would like to say Hi to everybody and share my following video.
Hope you enjoy it as I did .
FD3S69.50
      10-11-2015, 03:25 AM   #2
Vanne
Vanne's Avatar
United Arab Emirates
1624
Drives: 2007 Z4MC
Bloody hell, hope your doing that on one hell of a straight at a circuit mate.
Welcome..
Powered by
      10-11-2015, 03:34 AM   #3
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
Welcome..
No worries, at a remote area late at night with zero traffic......
Thanks man
      10-11-2015, 08:33 AM   #4
GTA Z4MC
Drives: Z4MC
WoW. 300KM's at 4000 RPM.
Unreal.......
      10-11-2015, 08:37 AM   #5
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
Unreal.......
You mean 8000RPM... my diff is 3.91, at the end I put it to neutral to remove the strain from the engine
      10-11-2015, 04:31 PM   #6
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
That's one hell of a first post! Welcome! What tune do you have?
      10-11-2015, 04:43 PM   #7
Steeler
Steeler's Avatar
2430
Unreal.......
Thought the same thing but he wouldn't be getting that acceleration with a lower numerical rear gear
What 007 said.......what tune?
      10-11-2015, 11:16 PM   #8
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
Thanks man!
Currently I am running with SS V1 stepped headers, rpi scoop & cat back exhaust, custom tune and 3.91diff.
All of the above the diff made the biggest difference, lots of torque and higher top speed.
I have some pictures at my albums if you want to have a look at the car from some events-gatherings.....
      10-11-2015, 11:23 PM   #9
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
[QUOTE=dbarton62;18726848]Thought the same thing but he wouldn't be getting that acceleration with a lower numerical rear gear
I wish it could but not possible .
With 3.91 ring & pinion you have to go all the way near the rpm limiter to reach 300Km/hr. But it really transforms the car, you just need good tarmac to feel the difference, otherwise it spins a lot....
      10-16-2015, 07:42 AM   #10
Twixboy
Drives: '04 Z4 3.0i 6spd
Don't mean to sound negative, but if you did that on a public road you could've easily killed yourself. One bump in the road and you'd go flying out of control. Stay safe man.
      10-16-2015, 09:49 AM   #11
GuidoK
#buildnotbought
GuidoK's Avatar
11123
Drives: Z4 3.0i ESS TS2+
No gps speed?
That is the only conclusive way to measure if you want to make real conclusions about top speed.
You can use android tracks or some other (free) logger.
GPS is 100% accurate.
      10-16-2015, 01:10 PM   #12
PLCZ4MC
Proud E86M Owner
PLCZ4MC's Avatar
Drives: 07 Z4M Coupe Monaco Blue
O wow. I reach only ones 172mph. Well it cannot be 100% as I was not monitoring the speed professional. But I got pretty scare going that high speed. Only ones in my roadster. Never again. Feels very different going 150 mph and going 172mph. And yes I agree with Twixboy in a public rode it felt even worse. Crazy experience but not doing it again.
Nice first post tough. I wonder how you were able to get the camera to record just the speedometer.
      10-16-2015, 03:54 PM   #13
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
[QUOTE=Nikitas_Z4mcoupe;18728146]
Unless you recalibrated the speedo after changing to the 3.91 diff, you weren't going an actual 300 KPH. You were going approximately 8% slower......
Top Down 365
      10-16-2015, 04:03 PM   #14
GuidoK
#buildnotbought
GuidoK's Avatar
11123
Makes sense. Just like different tyres give errors (and the speed dial itself isnt that accurate too)
Thats why I always use gps if I want to know the actual speed. Everyone carries a gps nowadays in their phone so you can always log your journey and see your top speed.
For performance testing (0-60 or whatever) I use a seperate 10hz gps, so I get a real accurate time. Phone gps chips only have a 1 second refresh interval.
I think the coupe will be a bit faster on top speed because I suspect it has a better drag coefficient.
At those kind of speeds I'm always afraid that my rear glass window will shatter or that my hood will tear off completely
The fabric at the back really starts to resonate. I think there may be some kind of vortex at those speeds on the back of the fabric top.
Also above 170mph there is some kind of force on the side windows that sucks them a bit apart and that also creates an ear deafening slit. (at least on my car, maybe I can adjust the windows a bit tighter)
The ragtop is not made for those speeds I guess.
      10-17-2015, 12:47 AM   #15
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
[QUOTE=dc_wright;18757916]
Not true you are changing the diff ratio... each gear will produce 8% less speed at same rpm compared to 3.62, thats why now the car goes 300km/hr at almost 8000rpm with 6th.
not same as reducing the diameter of the wheels - tyres
      10-17-2015, 01:07 AM   #16
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
True, GPS is the only professional way of monitoring performance of the car (0-100 or 100-200km), including top speed but still speedometer is a good indication of how fast you are going...
I just wanted to share with you guys as going through the net, youtube etc I have never seen any other Z4m reaching this speed only M3s
Thanks.....Iphone can fit in between the wheel......
      10-17-2015, 01:14 AM   #17
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
I fully agree. I had a Z3 roadster and at high speeds was a nightmare.... lots of wind, noise and felt not stable at all. That’s the reason I decided to buy a coupe
      10-17-2015, 02:10 AM   #18
NickyC
NickyC's Avatar
17683
Tell me you weren't holding the camera for that!
      10-17-2015, 02:37 AM   #19
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
I am crazy but not that much.......
      10-17-2015, 09:14 AM   #20
Drives: M2 Comp
The diff does not change the speedo.
Pickup point is after the diff
      10-17-2015, 01:22 PM   #21
GuidoK
#buildnotbought
GuidoK's Avatar
11123
I don't think the z4 roadster gets unstable at high speeds, but its more that a fabric hood gets a pretty big beating above 250kph.
Especially hoods with a big curvature. Hoods on supersportscars mostly are much flatter as their base sits higher.
      10-17-2015, 04:59 PM   #22
dc_wright
dc_wright's Avatar
249
My bad! I was thinking there was a speed sensor on the diff that sensed the ring gear teeth like earlier BMWs used...............
Top Down 365
