08-23-2007, 09:00 AM | #1 |
Rep 1,191
AUX DIY
don't buy one for the z4..it's like $70! one for the E46 is only $32 with club discount at Tischer BMW
1)take the vent out (use another DIY) 2)unscrew two screws on the headunit and pull out. 3)insert the cable into back of the head unit. If there is a black plug already occupying the space, remove it and insert the AUX cable. I believe it is for a CD changer 4)POP open the ashtray, unscrew 1 screw and slowly pry apart the console w/buttons 5)take the aux cable and drop it behind the headunit and should drop down to where you can grab and pull from bottom 6)drill a hole on the ashtray on the slanted part(just my preference) big enough for the aux cable to go through, then POP out the empty flat part with a hole thingy and get rid of the plastic cone that is behind it. 7)put the aux cable through, put the face on, screw the face on and you are done |
12-25-2014, 05:56 PM | #6 |
Rep 2,707
Holy thread resurrection but funnily enough I was reading threads on this mod today
One question for you, are the controls on the steering wheel usable with this retro fit to control the iPod?
01-07-2015, 01:35 PM | #7 | |
///Multiple
2993
Rep 4,243
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
If you want to interface with your iPod you need to add the BMW iPod adapter. I have no part number for this as it was installed by the previous owner. With this adapter, which plugs into the head unit in place of the CD changer, you are basically fooling the head unit into thinking that your iPod is a six-disc CD changer. You have to have five playlists on your iPod whose names start with BMWn, where n is a number from one to 5, e.g., BMW1 Rock, BMW2 Jazz, etc. Choosing disc 6 plays all five playlists. You can use the steering wheel buttons to change tracks up and down. There is no way to shuffle and every time you pick a different playlist it plays it from the beginning. Also, this will only work with certain generation iPods. It works with my nano 3G, but not my 5G. Most people go with the third-party DICE unit, although this has had mixed reviews.
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
01-07-2015, 06:02 PM | #8 |
Rep 2,707
Thanks great info
02-02-2015, 03:08 PM | #10 |
Rep 847
http://www.zpost.com/forums/showthread.php?t=105298
I have done this more than 10 times I think. You can just slide a credit card in the gap between the vent and dash trim on top where the tabs are and that will release the tabs (one at a time). |
02-11-2015, 12:58 PM | #11 |
Rep 115
I got everything installed but I can't figure out how to get the radio to pick up my phone. I can still only switch between CD and Radio. How do I put it in AUX mode?
Also, can you verify that I plugged the cable in correctly? It fit in there several ways. |
02-11-2015, 03:44 PM | #12 |
636
Rep 3,124
You sure it's plugged into the correct hole?
See page 12 here. Once it's hooked up correctly, the radio will automatically recognize it and add AUX to the mode selection.
02-11-2015, 06:27 PM | #13 |
Rep 115
I did exactly what Black Sapphire showed. I removed the black wire that were plugged in there and put the AUX cable in its place. I tried flipping it and I still couldn't get AUX mode when I turned on the radio.
02-11-2015, 06:39 PM | #14 |
Rep 115
One thing I noticed is that the cable I pulled out is a 12 pin connector. The AUX cable I replaced it with is a 10 pin. It fits but there are always two standalone pins... Is this a problem?
02-15-2015, 09:18 PM | #15 |
Rep 115
I ordered the one without Navigation and it was definitely NOT the right part number.
This is the connection type you need for a 3.0i with a business CD radio: http://www.ebay.com/itm/331363757201...%3AMEBIDX%3AIT |
02-19-2015, 07:30 AM | #16 | |
Rep 151
05-29-2017, 11:17 AM | #17 | |
Rep 1
