04-11-2013, 12:32 AM | #67 |
Rep 509
Ok thanks
My Hellrot '06 BMW Z4 3.0si Coupe and My Mineral Grey '14 F30 (sold) New daily: Sunset Orange 330E G20 Instagram: @StigJ77 & @bmwe86driver |
04-13-2013, 11:11 AM | #68 |
Rep 4,320
Drives: '07 Z4 M Coupe
Keep vasilating on what size ARC-8's to order.
Currently lowered on H&R springs, but will get some coilovers/camber plates (H&R or Fortune Auto) next winter. Ideally, want a wheel setup that will look good and work with either suspension component with little adjustment. This is just used for street driving - maybe 1 auto-x a year. Leaning towards: F: 18x9 et42, with 245/40/18 R: 18x10 et25, with 275/35/18 With Michelin PSS', Hankook V12 Ventus, or something similar. David at Apex said: "They'll work as long as you use a street tire in the 245/40/18 tire size, since the tire will be slightly stretched. If you use an extreme summer tire such as a Hankook RS-3 or Dunlop Star Spec, you may need a small 3mm spacer so that the tire doesn't rub on the strut." Should I stick with the planned setup? Should I drop to a 18x8.5 in front (and if so, what tire size)?
04-16-2013, 06:54 AM | #69 | |
Rep 376
Hope this helps!
04-16-2013, 12:04 PM | #70 | |
Rep 4,320
04-16-2013, 05:44 PM | #71 |
Rep 911
I am running R888 and rub the rear fenders, mainly because that tire has a tall and straight sidewall. Choose your tire carefully if you will be dropping the car anymore than an inch. They seem to work fine at 255 size in the front, although the vehicle hasn't seen aggressive driving yet.
Andre - 2J into a Z4 Coupe!
04-21-2013, 06:56 PM | #72 |
Rep 507
Just installed my ARC-8s!
Wheels: 9"x18 ET42 fronts - needed a 3mm spacer to clear strut. Could use another 5mm or so to flush it out. 9.5"x18 ET22 rears - perfect fitment, no spacer Tires: 235/40/18 Front - Tad bit stretched on a 9" wheel 265/35/18 Rear - Tab bit too much meat "overhang" on a 9.5" wheel Optimal wheel widths for these tires would be 8.5" front and 10" rear. I am VERY happy with the fit and finish of these wheels! Pics:
SOLD: 2008 M Coupe
04-22-2013, 02:38 PM | #73 |
Rep 6,758
Looks great mgwatson48! Thanks for sharing!
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
04-22-2013, 04:46 PM | #74 | |
More of this than that!
29
Rep 817
. . You want me to start liking blue cars ....dam that car is sexy!!
'06 Z4 3.0i Jet Black/ Biege/Black Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector |
04-23-2013, 01:34 AM | #76 | |
Rep 509
Going for same tire dimension as you but 8.5 for the fronts. And since I have the 3.0si I need the 9,5 ET35... I like meaty look
04-25-2013, 08:13 AM | #77 | |
Rep 441
04-25-2013, 12:48 PM | #78 |
Rep 507
Lol, I don't quite understand how it couldn't be normal... The 9" wheel with an ET42 offset gives you 13mm less strut clearance. When I mounted the wheel it was touching the strut (stock suspension).
SOLD: 2008 M Coupe
05-03-2013, 06:37 PM | #79 |
Rep 441
So...When is the next group buy?
thats what I was missing haha |
12-16-2014, 11:07 PM | #81 | |
Rep 2,782
01-06-2015, 06:47 AM | #82 | |
Rep 12,565
01-07-2015, 03:05 AM | #83 |
Rep 7
A question.
I am located in israel and just got a set of ARC-8 i would like to buy a different center cap / roundel , what is the exact size i should look for ? i am going to powder coat the wheels in copper so it was just a test fit. btw: Non-M on KW v2 - 9.5/18/et35 on the rear with 255 tire , no rubbing at all. |
Tags |
18x10, 18x9.5, apex, arc-8, arc8 |
