      03-27-2013, 12:17 PM   #1
jnkhan82
jnkhan82's Avatar
Drives: 03 Z4 2.5i
Send a message via AIM to jnkhan82
Coolant
Hey guys,
First time putting Coolant into the Z, wondering if it has to the be the BMW brand?
Anyone know of a 3rd party brand that could work?
Thanks in advance!
Amir
      03-27-2013, 12:18 PM   #2
330indy
CCA member
330indy's Avatar
Drives: e46 + e92
Always, always use BMW branded with distilled water.
00 Z3 - Conforti, Magnaflow
02 330i ZSP - Dinan Stage3, Corsa
13 M3 ZCP - Corsa
3 pedals all, Redline fluids
      03-27-2013, 02:04 PM   #3
kleenE85
Drives: 2004 BMW Z4 3.0i
^ agreed with the above statement. BMW coolant is a concentrate so you'll have to dilute it 50/50. Here in Newport Beach CA its about $26 per bottle. If you went to Walmart a 50/50 mix of Prestone is about $13...pricing-wise its almost the same price so go with the good BMW stuff hope this helps!
      03-27-2013, 03:33 PM   #4
elwesso
elwesso's Avatar
Drives: Z4 M Coupe
The BMW coolant is blue, FYI.. Since the OEM coolant is pretty reasonably priced, makes a lot of sense to just get the BMW stuff.
- Wes
2007 BMW M Coupe
2016 VW GTI
      03-27-2013, 03:39 PM   #5
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
Pentosin makes BMW's coolant, you can buy Pentosin blue at most autoparts stores. Pentosin red is for Audi/VW, don't buy that. Look on Pentosin's website for the part number, its G something (maybe G13?)
I think its only a dollar or two cheaper but its a lot easier for me to get than going to BMW or putting in a web order just for one item.
      03-28-2013, 12:11 AM   #6
jnkhan82
jnkhan82's Avatar
Drives: 03 Z4 2.5i
Cool. Thanks guys. BMW is to far from my house, so I just ordered it from Bavauto.com.
:::tips hat:::
      03-28-2013, 12:39 AM   #7
jnkhan82
jnkhan82's Avatar
Drives: 03 Z4 2.5i
Question.
How many bottles do I need? also, what do you guys use to mix with water? just a random bottle container?
      03-28-2013, 01:17 AM   #8
XMetal
XMetal's Avatar
Drives: '04 X5, '08 Z4MC
2008 Z4M Coupe  [0.00]
2004 X5  [3.50]
If the radiator & engine block are empty, it takes 2 gallons to fill. So, 1 Gallon of BMW coolant and 1 gallon of distilled water should be good. Make sure you use distilled water to avoid introducing minerals into the cooling system.
      03-28-2013, 07:25 AM   #9
elwesso
elwesso's Avatar
Drives: Z4 M Coupe
Originally Posted by jnkhan82 View Post
Question.
Nothing special is needed, maybe an old (washed out) milk jug would be convenient because you just fill them half/half, then if you have any left over you'll have it in a convenient container already.
- Wes
2007 BMW M Coupe
2016 VW GTI
