      03-25-2013, 08:01 PM   #45
ZStig
I'm also wondering if there's a 9psi upgrade option available. I'm guessing with larger injectors, it shouldn't be an issue, and the software would probably adapt by itself. I'm already at 8psi
      03-26-2013, 04:25 AM   #46
tikamak
Lebanon
24
I need the 500 kit intercooler hose as well, Since i haven't started my install, maybe you can ship it out to me in these 2 days if it's readily available?
Should make it a hell lot easier since i will be installing it with my mechanic and a few people lined up to watch for information purposes.
      03-26-2013, 05:57 AM   #47
Beedub
you dont NEED the hose they were just saying theyve changed things to make an easier install :-) you misread.... you Need the injectors and pullies, if i was at your stage id definitely be upgrading to 525 spec
      03-26-2013, 10:01 AM   #48
tikamak
Lebanon
24
I know I know, but if it will make it easier, i'd rather just buy the 1 piece hose.
When talking about upgrades, i am against upgrading into 525hp injectors and tune. I'd rather blow more money and go for built motor. Plus, i haven't installed the kit yet, so i don't know how the 500 will behave, i bet for a year or so it will be plenty for me.
      03-27-2013, 05:06 AM   #49
Beedub
Jad you may make 525+ being catless anyway???
      03-27-2013, 08:10 AM   #50
tikamak
Lebanon
24
Well according to AJ i should be making 525+ with 8 psi boost.
What is left to check is the tuning expertise and how true these statements are. i have no doubt at this point after seeing all the Z4M ESS cars including your ride.
AJ seemed very confident that my car is able to pull that kind of power, knowing that my engine should be healthy and the exhaust is decent.
Both of these requirements are met since my engine has been revised and will be in case of anything that is not up to spec (compression, rod bearings, valves, pistons, ...)
My exhaust is a EURO header --> emptied section 2, stock Xpipe and RE El diablo mufflers which is very close to what the ESS kit was tested with.
I could only find 2 grey bosch injectors, one was full grey and the other was grey with black head and the difference between the 2 is that one is 55 lbs and the other is 50 lbs. 10% increase.
15lbs = Gray top injectors
19lbs = Yellow (or sometimes referenced as Orange) top injectors
19lbs = Solid Orange "skinny" injectors
21lbs = Solid Light Purple "skinny" injectors
22lbs = Violet top injectors
22.5lbs = Blue & Black top w/ Silver body injectors
24lbs = Sky Blue top injectors
25lbs = Solid Black "skinny" injectors
25lbs = Solid Light Blue "skinny" injectors (Ford Navigator)
27lbs = Solid Light Gray "skinny" injectors
30lbs = Red top injectors
36lbs = Brown top injectors (low impedence, used in the 4 cyl Turbo vehicles)
36lbs = Dark Blue (Colbalt Blue) top injectors
36lbs = Solid White "skinny" w/ rectangular connector injectors
39lbs = Solid Blue "skinny" injectors (Blue Giant) (Ford rates this at 39lbs, flow rate is actually 42lbs)
42lbs = Lime Green top injectors
42lbs = Solid Green "skinny" injectors
48lbs = Beige top injectors (found on 85 CFI 5.0's)
50lbs = Gray top injectors
55lbs = Black w/ Gray top injectors
65lbs = Purple top injectors
160lbs (1600cc) = White top injectors w/ black body
      03-27-2013, 10:36 AM   #51
pokeybritches
pokeybritches's Avatar
Bahrain
125
Drives: ESS/G-Power Z4M, VF Z4, 987.2
2006 BMW Z4M  [5.00]
2006 BMW Z4M  [4.25]
2003 BMW Z4 3.0i  [4.50]
I might consider buying some of your old injectors, assuming they are 50 lbs.
VF Engineering Z4 3.0i, ESS Z4M, G-Power Z4M, 987.2 Cayman S
      04-02-2013, 05:22 AM   #52
tikamak
Lebanon
24
Looks like the ESS VT2-525 for Z4M is now official:
http://www.esstuning.com/products/Z4...er-System.html
However, I have a few notes:
- There should be no transmission option to choose from, Z4M only comes in manual
- I have been previously informed by both Roman and AJ in this thread and outside that the Z4M platform doesn't support the E-flash yet it is widely advertised in the link above. Can you please reconfirm ? is the e-Flash supported or not?
IF yes, I will be very frustrated as i had to spend a lot of money to send my ECU all the way from the middle east to Arizona. please let me know so that I can purchase cable to be included with the ECU on the way back.
If not, please update the website to represent correct data.
      04-02-2013, 06:42 PM   #53
ajw45
Drives: Z4M Coupe
Is there any noticeable difference in throttle response with the ESS system installed?
      04-02-2013, 07:23 PM   #54
tom @ eas
tom @ eas's Avatar
Drives: BMW
2010 BMW M3  [5.00]
2015 BMW M4  [3.50]
Very much so, ESS has always had a greater advantage when it comes to tuning.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG FACEBOOK YOUTUBE FLICKR INSTAGRAM
      04-02-2013, 08:22 PM   #55
Gt4
Gt4's Avatar
Drives: E46 M3 ZCP & T4R Limited
So basically, what the price to upgrade to VT2-525 if I already have the VT1-445?
Do I need to send my DME?
It would be great if I can do this mod before the Time Attack season begins
      04-04-2013, 12:02 PM   #56
tom @ eas
tom @ eas's Avatar
Drives: BMW
2010 BMW M3  [5.00]
2015 BMW M4  [3.50]
Week 2 in driving, and loving every minute of it!
Upgrade pricing will be released in the upcoming weeks. Please drop me a quick email if you would ike to be added to the waiting list to be notified.
      04-27-2013, 04:14 PM   #57
tikamak
Lebanon
24
Hi EAS, ESS owners, ESS sent me intercooler brackets that belong to E46 M3, can you please measure the intercooler brackets your have as well as take angles so that i can fabricate it locally?
I also need the length of the intercooler pipe bracket
I also need pictures of both intercooler pipes (sc to i/c and i/c to intake) taken from below the car as well as from above so that I know how to install them.
I was sent an e46 M3 manual as well. so i don't know how this will fit exactly.
awaiting your replies in here or on jad_mrad@hotmail.com
      04-29-2013, 04:18 PM   #58
tom @ eas
tom @ eas's Avatar
Drives: BMW
2010 BMW M3  [5.00]
2015 BMW M4  [3.50]
ESS should be able to provide you the needed info, since you already have the parts. If not, we can check on ours next time its up on the lift.
      04-29-2013, 04:18 PM   #59
tom @ eas
tom @ eas's Avatar
Drives: BMW
2010 BMW M3  [5.00]
2015 BMW M4  [3.50]
The VT2-525 Z4M will be on display in the EAS booth for Bimmerfest, those that are attending are welcome to see it in person.
Be sure to drop by and say hi!
      05-01-2013, 04:03 PM   #60
Str8 RippiN
Str8 RippiN's Avatar
26
Drives: E46 ZCP ///M3
Talked to Roman, the unofficial price as of now on the upgrade from 445 to 525 is approximately $3995..more than i though it would be
-Tommy
"The Zillenium Falcon" mod journal - http://www.m3forum.net/m3forum/showthread.php?t=440670
      05-01-2013, 06:25 PM   #61
tightie
JOSH SHOKRI.
tightie's Avatar
Drives: 991 GT3RS, 964, Raptor
2008 BMW M3  [3.95]
It was awesome having you guys.
Steve seriously would not get off the track that day. This thing held up nicely, only thing he ever came off for was gas and was right back on track.
Current: 16 991 GT3RS , 91 964 C2, 17 Raptor | Past: 2015 991 GT3, 2015 i3,15 YMB F80 M3, 13 E92 M3 DCT, 08 E92 M3 6MT, 07 E60 M5, 02 E46 M3
Instagram: @josh_speeddistrict #SpeedDistrict @SpeedDistrict
      05-02-2013, 02:00 AM   #62
Beedub
That's ALOT!!!
      05-03-2013, 01:17 PM   #63
Str8 RippiN
26
That's ALOT!!!
seriously i thought it was going to be 3k tops but i guess you need to figure in the small quantity of sales
-Tommy
      05-03-2013, 01:41 PM   #64
gmd2003
gmd2003's Avatar
179
Drives: 2014 CP M6 and 2006 VT 525 Z4M
Taking Freshly Installed VT-2 525 to Roebling Road tomorrow
I'm finishing up the install of my upgrade kit , taking me from Vt-1 to Vt-2 525 this afternoon and will be giving it a proper track shake down on Saturday. I liked the VT-1 but especially in the southern heat and humidity it lost a ton of torque especially toward the end of a 25 min session (despite good oil temps with a E63 M6 oil cooler). Thus after two years of tracking it in Vt-1 trim I decided to upgrade (I didn't like the idea of 200 degree intake air temps anymore either). I have a ton of time at Roebling so I'm pretty darned quick there , so I will give it a proper thrashing. I will report my peak oil temps, delta on my straight speed vs the old kit ( best ever was 147mph on 50 degree morning by Aim Solo gps ) and total lap time delta ( best 1:20.8).The straight will be interesting as I redline in 5th at 147 with my 4.1 gears , so i will have to shift to 6th . Stay tuned....
Cheers
George
Tags
eas, ess, vt1-445, vt2-525, z4m
