02-04-2013, 08:26 PM | #1 |
Rep 832
Programming for Odometer - Miles to KMs
OK, I finally got my cable and software up and running for diagnosis and such. I have used DIS to to checks and Progman to do some car/key programming (now have one touch 3 signal flash among other things).
Where I am stuck is trying to find where to change miles to kilometers on the odometer. I am assuming its in NCSexpert but am still a little intimidated by the thought of using it. Can anyone help me get this done with step by step instructions? Thanks in advance |
02-04-2013, 09:28 PM | #2 |
///Multiple
2993
Rep 4,243
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
Did you see anything that would allow you to enable Seat Memory - Automatic driver's seat position? In my research it appears that this is only able to be done by the dealer.
I ordered the same cable and software but haven't gotten around to installing anything yet. It would be great if I could do this without going to the dealer.
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
02-04-2013, 10:11 PM | #3 |
///Multiple
2993
Rep 4,243
Great! I just tried copying the files from the DIS and SSS discs and discovered that the SSS disc is cracked!
Could someone copy the SSS disc and send it to me? It would probably be faster than contacting the seller in Romania.
02-04-2013, 11:08 PM | #5 |
///Multiple
2993
Rep 4,243
I've e-mailed the seller, bmwfanatiq, and asked if I have to return it or whether he can just send me another disc. I bought it on 12/27 and got it about 10 days ago, but I had relatives from out of town staying with us and didn't try to install it until today. I'll see what he says but it may be faster to just wait for you!
02-05-2013, 07:33 AM | #7 |
Rep 4,062
Although this may not be particularly helpful, I had my dealer in Florida do that for me when I bought the car. If you are close to the border, a US dealer is cheaper.
I had the following things set up:
Cheers!
Huz-Z
02-05-2013, 08:19 AM | #8 | |
Rep 11,669
If the files aren't too big maybe they can be emailed?
02-05-2013, 09:16 AM | #9 |
Rep 832
The SSS disk is huge. Takes up almost the whole DVD so it's a few Gig.
Huz-z...yes, I can now code those things you mentioned myself. Cost me $35 for everything. Problem is that the odo coding is not in the same program which has a decent user interface. It involves pulling code from a module, rewriting the code, then uploading it back. Need to be 100% certain so your not turning your car into a paperweight. |
02-05-2013, 09:27 AM | #10 |
Pilot
19
Rep 334
Hi,
I did a few changes on my Z4, M3 and X3 through NCS Expert. Worked great! I did on the Z4: - open/closing Top with key - Open/closing top doesn't stop when start driving - disabled belt beep. - blinking lock/ unlock car - LED in mirror - disable Miami setting (locks close when faster than 15 km/h) - full moon brake light when hard braking - Brake-Force-Light. third brake light flashes when ABS kicks in. As I remember there was a setting for miles and km/h. I need to check the SW_PSW.trc file.. I might have it in an old email |
02-05-2013, 10:38 AM | #11 |
///Multiple
2993
Rep 4,243
I received a reply from the seller and he's sent me a torrent file with a link to download directly from his PC. I haven't tried this yet, I hope it's not going to be too slow. He said that if it were too slow he would send me another copy, but that's going to take at least 4 weeks based on the original shipping time.
02-05-2013, 11:26 AM | #12 | |
Rep 135
Hope this helps. |
02-05-2013, 11:47 AM | #13 |
Rep 135
Sorry, didn't realize you had not used NCS prior. Here are step by step directions:
1. Connect your cable to your vehicle’s OBD II port and to your computer. Your vehicle’s ignition should be in the ON position, but your engine does not need to be running. 2. Launch INPA and verify that it reads Battery: ON and Ignition: ON. You should also have a program called “EDIABAS Server” running in your task bar. If everything checks out, close INPA. Leave the server running. 3. Open “C:\NCSEXPER\WORK” and create an empty text file named “FSW_PSW.MAN”. I just use NOTEPAD for this. 4. Launch NCS Expert. Go to File -> Load profil and select “Revtor’s NCS Expert Profile”, click OK. 5. Select “VIN/ZCS/FA” then “ZCS/FA f. ECU”. This will tell NCS Expert to attempt to read your VIN from your vehicle’s ECU so you don’t have to type it in. 6. Select your chassis from the list and click OK. Then select which module you want NCS Expert to read your VIN from. Usually the first choice is fine. Click OK again to have NCS Expert read your VIN. You should see the CHASSIS, FG, and FA fields populated in the top part of the NCS Expert window. 6. Select “Back”, then “Process ECU”. You will be prompted to select a module. Select the module you want to read values from(in this case KOMBI OR AKMB) and click OK. Click OK again on the window that appears to return to the main NCS Expert window. 7. Select “Job” and choose “CODIERDATEN_LESSEN” from the menu. This will change the job from one that writes to one that only reads data. Many of the job names look very similar. Always read job names carefully to ensure you select the correct one. 8. At this point NCS Expert is relatively harmless, as all it can do is read from your car. Select “Execute job” to begin reading from your selected module. When you see “Coding ended” below the module name, the process has completed. 9. Once NCS Expert has read data from a module, it stores that data in a file called “FSW_PSW.TRC” (called a “trace file”) in the “C:\NCSEXPER\WORK” folder. This file contains some general information about your car, as well as all the values currently stored in the module you read from. NOW THE WRITE PART: 1. Open “FSW_PSW.TRC”(you can use NOTEPAD) and find the field you wish to modify. Trace files are formatted as: FIELD_NAME field_value 2. Change the field value(s) to your desired settings(this is where you look for the WEG_EINHEIT field name, and change value to "km"), then save this file as “FSW_PSW.MAN”, overwriting the empty one you created earlier. 3. If you closed NCS Expert, follow steps 1-6 in the section above to get back to the correct screen. Otherwise, NCS Expert is ready to code your module as soon as the job is changed back to the default, “SG_CODIEREN”. Do this by selecting “Job” and then “SG_CODIEREN”, then click OK. Verify that the correct job appears in the “JOBNAME“ field. 4. Click “Execute job” to have NCS Expert write the information from FSW_PSW.MAN to your vehicle. When you see “Coding ended” below the module name, the process has completed. Depending on what you coded, you may need to turn your car off and back on again to verify the desired feature/behavior has taken effect. 5. Open “FSW_PSW.MAN” and delete its contents. Save and close the file. Revtor's profile for NCS should have come with the package you purchased. If not, it is readily available for download on the internet, along with simple instructions on how to integrate it with NCS Expert. Last edited by Jstic; 02-05-2013 at 11:53 AM.. |
02-05-2013, 12:53 PM | #14 | |
///Multiple
2993
Rep 4,243
The "full moon brake light" or Adaptive Braking as BMW calls it, is standard, as far as I know. Every Z4 I've seen at autocrosses displays this behavior. My wife's 335is has this feature. The only way to determine if you have this feature is have someone follow you while you brake hard, or you follow your car while someone else is driving it and brakes hard. The Brake Force Light sounds like an interesting option. I know that people here have discussed aftermarket solutions to add this feature. I saw a Mini at an autocross that had a center brake light that flashed several times whenever the brakes were applied.
02-05-2013, 01:06 PM | #15 | |
///Multiple
2993
Rep 4,243
02-05-2013, 03:12 PM | #16 | |
Pilot
19
Rep 334
Code:
KOMFORTOEFFNUNG_FB aktiv KOMFORTSCHLIESSUNG_FB aktiv KOMFORTOEFFNUNG_VERDECK aktiv KOMFORTSCHLIESSEN_VERDECK aktiv The adaptive braking light was standard activated from 8/04 till end. The E85 before that production had it available but not active. Mine is 1/04 BFL Worked for me but I heard some people had problems with that. Code:
PIN49_37_BFD nicht_aktiv PIN38_20_BFD nicht_aktiv BFD_BLINK_EINZEIT wert_02 BFD_BLINK_AUSZEIT wert_02 BFD_ABS_STUFE3 aktiv BFD_STUFE3_TIMER wert_02 BFD_SW2_STUFE3 aktiv BLST1_BLST3 aktiv PIN5_10_BFD nicht_aktiv BFD_SW1_STUFE3 aktiv BFD_SW2_STUFE2 nicht_aktiv BFD_MINDEST_GESCHW wert_02 BFD_STUFE_2_VERZOEG wert_02 BFD_STUFE_2_MAX_EIN wert_01 BFD_SW1_STUFE2 nicht_aktiv BFD_ABS_STUFE2 nicht_aktiv BFD_STUFE2_TIMER wert_01 PIN29_30_BFD aktiv BFD3_ASC_TIMER wert_01 BEI_NSL_KEIN_BFD nicht_aktiv |
02-05-2013, 05:08 PM | #17 |
Rep 832
Jstic, thanks for the awesome info!! I am going to try that out as soon as I can.
Do you use NCSExpert for Dummies or just the regular version? Is there a "manual" or list of ALL options...specifically the german to english wording explained? Thanks again to both you and Z@T, great info!! |
02-05-2013, 07:23 PM | #18 |
M = Midlife Crisis
66
Rep 2,006
Safari
2006 Z4MC - #LL93158
02-05-2013, 07:38 PM | #19 |
Rep 832
You asking me? If so, no..I go to Africa twice a year...I volunteer running a program in Uganda. I did do a safari in Kenya in 2009 and one in Uganda in 2010 though. As cool as they were, standing 20 feet from a 500lb gorilla in the middle of the Rwandan jungle was MUCH cooler!
02-05-2013, 08:41 PM | #20 | |
Rep 832
Now to just find a German-Engish BMW translator so I can code other stuff! |
02-06-2013, 03:03 AM | #21 |
///Multiple
2993
Rep 4,243
The torrent finished just after midnight, took 14:15. It looks like there aren't any executable files, just a bunch of .appicon and .vm?? files, possibly for VMWare?
I'll try installing everything tomorrow.
