      01-29-2013, 11:03 PM   #1
Gt4
Gt4's Avatar
Drives: E46 M3 ZCP & T4R Limited
My custom OEM section 1 cats with EGT & o2 sensors bungs
Just want to share some pics so you guys know how your OEM cats look like without the sheet metal.
Here is what it look like:
I fabricated the bungs. The o2 sensors bungs are Vibrant 45deg bungs. The EGT sensor bung is a M14X1.5 screws (or a VW wheel bolt) that I drilled in the center to a 7.45mm ID, 25mm long.
http://vibrantperformance.com/catalo...dfb81ec55a927d
Here is the final result:
Hope you enjoy!
      01-29-2013, 11:09 PM   #2
kennyfrc
kennyfrc's Avatar
11
Drives: 2008 Z4MC
Did you replace the heat shield?
Mods: OEM Euro Headers, RPI Scoop
Daily: 2010 Tacoma Double Cab
      01-30-2013, 12:37 AM   #3
onebluemcm
onebluemcm's Avatar
Drives: '07 Z4MC Silbergrau
nice thread, nice pics of the system without the shields. I wonder if the mid pipe could be reworked with these cats and followed up by resonators such as AR20s or the like, all in the rearward section of the midpipe?
Nice welding BTW!
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
      01-30-2013, 01:58 AM   #4
beta
Drives: 2006 M Roadster
Wow great job, that looks oem.
      01-30-2013, 07:14 AM   #5
Gt4
Gt4's Avatar
No I decided to install wihout the heat shield. I put some exhaust wrap instead
      01-30-2013, 07:19 AM   #6
Gt4
Gt4's Avatar
Nice welding BTW!
It's possible to to a custom S pipe with resonators in it. But the exhaust flow will hit those resonators before the cats (cats are near the X pipe flange)
      01-31-2013, 04:25 PM   #7
Jumbosock
Jumbosock's Avatar
43
Drives: 2007 M coupe
Great job! As an FYI to anyone the Euro cats are twice as long as the North American secondary cats. The euro cats extend almost all the way to the flange and fill out the entire area under the heat shields.
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights
      01-31-2013, 07:49 PM   #8
Gt4
Gt4's Avatar
Exact. US cats must be less restrictive than the Euro version in that case.
      02-01-2013, 02:27 AM   #9
johanness
Drives: 2008 Z4MC
Nice job, however I don't think it's wise running around w/o the heat shield. Is the wrap a temporary thing?
      02-01-2013, 06:42 AM   #10
Gt4
Gt4's Avatar
Why? Almost all aftermarket section 1 with cats or not don't have heat shield.
      02-02-2013, 03:01 AM   #11
johanness
Drives: 2008 Z4MC
I'm just thinking about your secondary O2 wires, but it depends how you ran them. Theres not a lot of room and its gonna get HOT, but hope it works out.
      02-02-2013, 11:38 AM   #12
Gt4
Gt4's Avatar
I have an asbestos wire protector on the o2 sensors
      09-15-2013, 10:41 PM   #13
xelerator
Drives: 2003 E46 M3
I'm looking for a OEM cat section 1, who wants to sell it to me?
Dented heat shield is no problem.
Thanks,
Chris
      09-16-2013, 01:07 PM   #14
nekky
Collector of Z4Ms
nekky's Avatar
Drives: '10 E92 M3 Dakar Yellow Ind.
Thanks,
Chris
He is already selling this to me
      09-16-2013, 02:20 PM   #15
itdnwiwbp
Drives: 330iZHP
Where did you get the wire protector. I'd like to go the same route just to make sure everything is ok down below.
      09-16-2013, 02:36 PM   #16
StickMon
StickMon's Avatar
Drives: 2006 MR
I've used "Fire Sleeve" for similar applications.
      09-16-2013, 03:42 PM   #17
Gt4
Gt4's Avatar
You can route the wires like this (took the pics in crfine88 build up thread). You don't need to modify the o2 sensors wires, they are long enough if you reroute them on the driver side of the transmission tunnel.
      09-16-2013, 04:02 PM   #18
itdnwiwbp
Drives: 330iZHP
I was going to do what Jumbosock did in his videos and write up. I noticed he said that due to having just enough wire to reach the post cat locations he was considering a heat shield of some sort since he wasn't able to pin one of the wires up away from the exhaust. I'm just looking for a good product to use. Thanks for the fire sleeve recommendation, StickMon.
      09-16-2013, 04:05 PM   #19
itdnwiwbp
Drives: 330iZHP
I have no experience with the stuff but it says its good for up to 500* continuous. The headers and section 1 will be ceramic coated. Is the fire sleeve adequate for the temps produced by our exhaust, even if ceramic coated?
      09-16-2013, 04:56 PM   #20
Gt4
Gt4's Avatar
The fire sleeve will be able to support the heat of your section 1. But make sure they are not directly in contact with with the pipe. There is long enough of wires if you route them on the driver side of the transmission tunnel.
      09-16-2013, 06:23 PM   #21
itdnwiwbp
Drives: 330iZHP
Ok, thanks. Now, one last question for you guys who have been down under there. What size fire sleeve would you buy? Will it be possible to slip it over the O2 sensor and slide it up to the appropriate place on the wire or would it be necessary to slice it and retape it with fire tape?
      09-16-2013, 07:15 PM   #22
beta
If you route it the OEM way, the cables drop down right to where you need them. Take a look at my mod thread as I have lots of pictures.
