Login
01-29-2013, 11:03 PM | #1 |
![]() ![]() ![]() ![]() ![]() 16
Rep 737
My custom OEM section 1 cats with EGT & o2 sensors bungs
Just want to share some pics so you guys know how your OEM cats look like without the sheet metal.
Here is what it look like: ![]() ![]() ![]() ![]() ![]() ![]() ![]() I fabricated the bungs. The o2 sensors bungs are Vibrant 45deg bungs. The EGT sensor bung is a M14X1.5 screws (or a VW wheel bolt) that I drilled in the center to a 7.45mm ID, 25mm long. http://vibrantperformance.com/catalo...dfb81ec55a927d ![]() Here is the final result: ![]() ![]() Hope you enjoy! ![]() Last edited by Gt4; 10-27-2013 at 02:34 PM. |
01-30-2013, 12:37 AM | #3 |
![]() ![]() ![]() ![]() ![]() 21
Rep 608
nice thread, nice pics of the system without the shields. I wonder if the mid pipe could be reworked with these cats and followed up by resonators such as AR20s or the like, all in the rearward section of the midpipe?
Nice welding BTW!
![]() |=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint Last edited by onebluemcm; 01-30-2013 at 12:45 AM. |
01-30-2013, 01:58 AM | #4 |
![]() 47
Rep 1,659
Wow great job, that looks oem.
01-30-2013, 07:19 AM | #6 |
Rep 737
It's possible to to a custom S pipe with resonators in it. But the exhaust flow will hit those resonators before the cats (cats are near the X pipe flange)
01-31-2013, 04:25 PM | #7 |
![]() ![]() ![]() ![]() 43
Rep 939
Great job! As an FYI to anyone the Euro cats are twice as long as the North American secondary cats. The euro cats extend almost all the way to the flange and fill out the entire area under the heat shields.
![]() CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights |
01-31-2013, 07:49 PM | #8 |
Rep 737
Exact. US cats must be less restrictive than the Euro version in that case.
02-01-2013, 02:27 AM | #9 | |
Rep 1,739
Drives: 2008 Z4MC
02-01-2013, 06:42 AM | #10 |
Rep 737
02-02-2013, 03:01 AM | #11 | |
Rep 1,739
Drives: 2008 Z4MC
09-16-2013, 01:07 PM | #14 |
Collector of Z4Ms
![]() 25
Rep 980
09-16-2013, 02:20 PM | #15 |
![]() 58
Rep 1,440
Where did you get the wire protector. I'd like to go the same route just to make sure everything is ok down below.
09-16-2013, 02:36 PM | #16 |
![]() 438
Rep 2,683
I've used "Fire Sleeve" for similar applications.
09-16-2013, 03:42 PM | #17 | |
Rep 737
09-16-2013, 04:02 PM | #18 |
![]() 58
Rep 1,440
I was going to do what Jumbosock did in his videos and write up. I noticed he said that due to having just enough wire to reach the post cat locations he was considering a heat shield of some sort since he wasn't able to pin one of the wires up away from the exhaust. I'm just looking for a good product to use. Thanks for the fire sleeve recommendation, StickMon.
09-16-2013, 04:05 PM | #19 |
![]() 58
Rep 1,440
I have no experience with the stuff but it says its good for up to 500* continuous. The headers and section 1 will be ceramic coated. Is the fire sleeve adequate for the temps produced by our exhaust, even if ceramic coated?
09-16-2013, 04:56 PM | #20 |
Rep 737
The fire sleeve will be able to support the heat of your section 1. But make sure they are not directly in contact with with the pipe. There is long enough of wires if you route them on the driver side of the transmission tunnel.
09-16-2013, 06:23 PM | #21 |
![]() 58
Rep 1,440
Ok, thanks. Now, one last question for you guys who have been down under there. What size fire sleeve would you buy? Will it be possible to slip it over the O2 sensor and slide it up to the appropriate place on the wire or would it be necessary to slice it and retape it with fire tape?
09-16-2013, 07:15 PM | #22 |
![]() 47
Rep 1,659
If you route it the OEM way, the cables drop down right to where you need them. Take a look at my mod thread as I have lots of pictures.
