      01-24-2013, 08:23 PM   #1
mike519
mike519's Avatar
Drives: 2018 240i on order
Next mod...LED lights
Finally got the last of the LEDs I ordered to finish off the upgrade. I wanted to try blue for the interior and am gad I did...it looks awesome!
Here are the LEDs I bought...
2 LEDs for the map lights (brighter and whiter than stock)...
http://www.ebay.ca/itm/180736827919?...ht_5791wt_1060
1 LED Flat for the trunk (quite a bit brighter than stock)...
http://www.ebay.ca/itm/110934569084?...ht_3789wt_1035
1 Blue LED for dome light (comes in a package of 2)...
http://www.ebay.ca/itm/321045928030?...84.m1497.l2649
2 Blue LED flats for footwells...
http://www.ebay.ca/itm/250723289171?...84.m1497.l2649
Total cost including shipping...$11.30 (the links go to current listings...look around on ebay, you can find them a little cheaper).
A couple of pics...please note that the map light looks blue in this pic but it is very white...much more than the stock bulbs. A lot brighter as well. Please also note that the interior blue pic is the best I could get with the iPhone but it is a lot brighter than it looks, though is still subtle nonetheless.
Now just for a rear license plate LED!
      01-25-2013, 03:54 AM   #2
E85fan
Drives: 2004 Titanium Silver Z4
The blue looks sick
      01-25-2013, 08:54 AM   #3
mike519
mike519's Avatar
I actually bought some extra white ones in case I wasn't happy with the blue but I love the look. Picture doesn't do it justice.
      01-25-2013, 11:31 AM   #4
dubsesd
OEM++
dubsesd's Avatar
No_Country
2185
Drives: F15 X5 MP/ 2016 F80 M3 INDVL
Not bad. I prefer the oem white led better myself
2016 ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE P101 / 20" Brixton WR3 Ultrasport / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / N54tuning C-Flap / EAS Carbon seatbacks / Carbon sideskirt extensions / Pedal Haus Black anodized / M Performance Tri color alcantara / AWE S Flow
instagram: @ dubsesd
      01-26-2013, 12:28 AM   #5
Jony722si
The Wrapgician
Jony722si's Avatar
Drives: z4si
2009 335i  [0.00]
2006 BMW z4  [0.00]
I have fit a 48 smd led 5050 in the centre, bright like boss lol.
      02-17-2013, 11:09 PM   #6
papak
Drives: 2008 Z4 3.0si Coupe
LED lights
I recently came across the perfect bulb for the front reading lights (the outboard ones) on my '08 Z4 Coupe. Order a couple of "WLED-NW6 6 LED" bulbs from "superbrightleds.com" They fit perfectly and are wonderfully bright and pure white. Cost was about $11.50 for two with shipping. I found that there were a couple of tricks to changing out the bulbs. Most of these round "194" base bulbs are 12mm in diameter. The opening in the housing is 11.47mm. After removing the light fixture from the overhead, the clear lense comes off by removing two Philips head screws that hold it on to the base housing. Once removed, the center bulb is replaced by a 5 LED bulb (one on the end and four around the sides). Remove the base and install the new bulb from the reflector side into the base. The same can be done for the outer "spots". Test it before putting the clear lens back on because they may need to be reversed to accommodate the polarity. Once together, it's a very nice improvement.
