      01-19-2013, 06:16 AM   #177
exdos
England
Drives: Z3 M Coupe(S54) and Z4 M Coupe
Originally Posted by GuidoK View Post
I was worried about/my point being the engine jerking around in the engine bay, caused by bumps and turns. Especially the s54 is a relative heavy engine with it's cast iron block.
Just like a very stiff shock absorber can damage the chassis with large bumps wheras a softer shock would have cushend the blow (resulting is less peak force).
Having seen the photos of the OEM engine mounts and visually comparing them with the Vibra Technics mounts, it looks to me that the vertical component (Y axis) of movement in the Vibra Technics mounts remains the same as OEM, but there is lesser movement in the horizontal planes (x and z axes). Surely, this is much the same as suspension components which attempt to limit movement to the one axis, only: i.e. Rear Trailing Arm Bush limiters?
Often, is the excessive movement of suspended parts which causes the repeated flexion cycles that creates metal fatigue, and reducing that movement will lessen the risk of failure.
      01-19-2013, 06:50 AM   #178
Beedub
oh crap.... iv over Tqed mine.... back into the freezing cold garage to Re-Tq, VT ask for 45nm top and bottom :-(
Pristine Bi-colour Ti /Bsm...z4m roadster Ess vt2-500....Perfection on wheels.
      01-19-2013, 06:53 AM   #179
Beedub
pretty much what phil said on the phone in a previous convo.... the compeition mounts are no-where near solid so its a non issue ;-)
I agree however the fast road ones seem to be the complete win win, no NVH and a better control to things.....
again i wanted the comp ones for my own reasons otherwise id have just gone for the road versions....
      01-19-2013, 09:42 AM   #180
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
Originally Posted by beta View Post
I tested it out by purposefully trying to shift as fast as possible 1->2, I was able to shift faster than before but when I slammed it I got some resistance and stopped testing. Because of this, I don't think it's completely solved.
As more people install their mounts and try it out we'll get a better picture (especially those with uprated transmission mounts). I'm still hoping a transmission crossmember provides a complete solution.
I didn't try shifting faster. Just noticed how much smoother it was and the range at which you can now shift. A couple of times, it made it to 2nd gear so smooth that I thought it got denied. The first time, I re-shifted. The second time, I let out the clutch....and WOW!
      01-19-2013, 10:47 AM   #181
22022
22022's Avatar
Drives: VT2-500 ZM4 roadster
This torque # will come in handy later thanks.
      01-19-2013, 11:01 PM   #182
zubydafa
tosser
Isle of Man
15
Drives: '07 Z4MC
Zub what did you Tq the bolts to...... i was thinking,,,maybe we should be guided by VT on the Tq spec for the mounts as they use different fastening hardware....... i.e nylocks.
not sure...i left the car and mounts in the hands of a trusted tech.
'07 MCoupe
lots of mods
      01-19-2013, 11:11 PM   #183
zubydafa
tosser
Isle of Man
15
Drives: '07 Z4MC
my reasons...
'07 MCoupe
lots of mods
      01-20-2013, 12:07 AM   #184
RobMCoupe
RobMCoupe's Avatar
20
Drives: 2007 Z4 M Coupe
Just got it install today. I upgraded to motorsport bolts for engine mount bracket too. The driver side is PIA. Took me most of the day going though underneath the car.
Love this mod. Just like others commented here. I tested 1st>2nd after warming up the car. I didn't get any grind at 6k or 7k. You can definitely shift faster 1sr>2nd. I only drove it for about 15 miles but will update if any changes.
      01-20-2013, 07:50 AM   #185
Beedub
Originally Posted by zubydafa View Post
my reasons...
LOL!!!! hahhahahahaa!!
how you finding these now?? any more downsides??? i cant get out as were under some serious snow!!!!!!
      01-20-2013, 08:53 AM   #186
sabbanick
Drives: 08 SBM M coupe
Nice to hear rave reviews. You guys running stock tranny mounts?
I would prefer to upgrade all three mounts at once, hopefully they build one for us.
      01-20-2013, 10:34 AM   #187
bignosejim
bignosejim's Avatar
I torqued mine to 42nm (31ftlbs) per the TIS. This seemed about right.
Removing the intake definitely is easier to install the Motorsports bolts. I could only get the bottom two from underneath the car when I put mine in last year. I just now got the top two in. After having the intake off about 3 different times, I can install or remove it in about 10 minutes. One thing I did notice is that it is a lot easier to install the hose clamp on cylinder #6 if you put it on wrapping the opposite way compared to the rest of them.
Glad to hear that your enjoying the new motor mounts. Even after hearing all the rave reviews on M3F, I was still shocked by the difference they made. It took me a few minutes to realize the 1st/2nd shift being easier because it just seemed so natural.
I installed RE transmission mount in the middle of December. Definitely another improvement. I wouldn't wait until the Transmission mounts arrive to put in the motor mounts (if you already have them). I think someone on M3Forum said there might another discount in effect right now through the USA reseller and that there might be another discount when they introduce the Tranny mounts (maybe for both motor and tranny also). I'm sure Beedub will keep us up to date on testing!!
      01-20-2013, 11:19 AM   #188
inTgr8r
inTgr8r's Avatar
Drives: E86 Z4MC; E92 M3
^ I agree about the intake removal method.
With the intake off its a piece of cake to get to the bolts.
I was reluctant to remove it at first, but its actually very straight forward.
How to posted here.... http://www.zpost.com/forums/showthread.php?t=730201
      01-20-2013, 04:41 PM   #189
RobMCoupe
RobMCoupe's Avatar
20
I wasn't prepare fir the clamps on the intake. It will definitely make easy access to the top engine mount bracket bolts. I bookmark your DIY for future. Thanks.
      01-20-2013, 05:36 PM   #190
bignosejim
bignosejim's Avatar
Contrary to what TIS says, those intake clamps are not "one time use." At least according to the manufacturer. I've had mine off and replaced 3 different times in the last month, and my clamps are all still in good condition. I know some members think this is wrong and I'm not trying to start a debate.
      01-20-2013, 06:11 PM   #191
RobMCoupe
RobMCoupe's Avatar
20
I'll get some clamps to play with. It is good preparation in case I want to replace my air box.
      01-20-2013, 09:14 PM   #192
bignosejim
bignosejim's Avatar
I use needle nosed pliers and a screwdriver just like in Intgr8r's thread above. I take them off just as in the linked picture. To put them back on, I found it is easier to position the needle nosed pliers like the removal pic. Then I use the screwdriver on top to push the clamp back in place.
      02-07-2013, 10:26 AM   #193
GriffBrew
Drives: 2006 M Roadster
Anybody else installed yet? I've received mine, but won't get them installed for a few more weeks.
      03-12-2013, 10:55 AM   #194
BIMMERGUY91
Drives: 2014 335I M Sport
I wish I hadnt missed out on this
2014 335i M Sport
2010 328i M Sport
2007 Z4MC #1019/1815 (Sold)
1997 M3 (Sold)
1991 325i
      03-12-2013, 11:47 AM   #195
gferil
gferil's Avatar
17
Drives: 06 Z4MC
Just got mine installed yesterday, great mod for sure. Engine seems more responsive in low gears, like beta said, more linear response when getting on and off the gas.
Turns out my mount on the right side was torn, so putting these in actually decreased the vibrations I was having. Very happy with this mod and it's only been one day. I'll update again after a track day or two and a couple months of driving.
      03-12-2013, 01:59 PM   #196
bignosejim
bignosejim's Avatar
After this group buy ended they changed the price of the mounts. Now they are about $300 for a set which is only $40 more than the gb price. They may also have a distributor in the USA (but I'm not sure).
      03-12-2013, 04:39 PM   #197
BIMMERGUY91
Thanks for the info. Yeah I just spoke with Phil and found out about the price change. Im definitely gonna try and get some of these.
2014 335i M Sport
2010 328i M Sport
1997 M3 (Sold)
1991 325i
      03-12-2013, 04:39 PM   #198
inTgr8r
inTgr8r's Avatar
nice price drop.
Search this Thread:
Advanced Search
