Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
      01-05-2013, 05:21 AM   #1
Beedub
ESS VT2-575!!!
its about to drop.......
http://www.m3forum.net/m3forum/showthread.php?t=430966
Pristine Bi-colour Ti /Bsm...z4m roadster Ess vt2-500....Perfection on wheels.
      01-05-2013, 12:59 PM   #2
22022
22022's Avatar
Drives: VT2-500 ZM4 roadster
575!! New pulley and software...sign me up
      01-05-2013, 02:09 PM   #3
ZStig
Drives: sold: VT2-525 M Roadster
minor detail :
FOR E46 M3 GUYS
      01-05-2013, 02:18 PM   #4
ZStig
plus 530whp and you're VERY close to the engine exploding, from what JAWS says
      01-05-2013, 03:13 PM   #5
Beedub
Originally Posted by ZStig
minor detail :
FOR E46 M3 GUYS
S54. Same engine , job done.
I agree tho, think we're taking this too far on stock internals. I feel comfortable at 8lbs, ill work with catless, cams, meth, and evolve custom tune and leave it Thier until I build the motor.
      01-06-2013, 01:51 AM   #6
ZStig
lol, I know its the same engine bro, its the tuning thats always been the question
      01-06-2013, 05:08 AM   #7
Beedub
No it hasn't been a tuning issue. Not with ess, its been a fuelling issue ;-)
Maybe with this kit they will look at supplying a proper fuel upgrade. Then again looking over the system, it's easy to done without a tuners help.
      01-06-2013, 09:32 PM   #8
22022
22022's Avatar
What would we need? Better fuel pump? More volume?
      01-07-2013, 02:02 AM   #9
pandusr
pandusr's Avatar
Italy
Drives: BMW Z4M Roadster ESS CFR 525
M3 E46 also has problems with the fuel pump.
In this kit is a clear need to upgrade the fuel pump.
http://store.activeautowerke.com/act...vel-2-p44.aspx
With the kit CFR525 cold weather i carburation problems.
      01-07-2013, 02:09 AM   #10
pandusr
pandusr's Avatar
Italy
A friend mechanic has tested on the engine test bench S54 engine designed to drift with Vortech V3 Si, Motec M600, decompressed pistons (8,5:1), connecting rods reinforced, camshafts schrick 288/280, 13 psi, 110 octane race fuel .
Result reliability: 650 hp motor at 8000 rev / min.
They bought the kit VT1 450 to use the compressor bracket and Intake Manifold. Obviously the injectors of the kit were small and were replaced.
As used two fuel pumps Walbro 255 and pressure regulator on the return. It goes without saying fuel rail modified.
To maintain its reliability, have been content. They had achieved more than 700 hp at 17 psi.
my mechanic friend is Gozzoli (http://www.gozzoli.it).
Don't get me wrong, I don't want to advertise. Only information.
      01-07-2013, 04:25 AM   #11
Beedub
great info, any pics of this motor??? and yours for that matter!!! CFR kits were awesome!!
      01-07-2013, 04:27 AM   #12
Beedub
fuel pump, injectors-660cc, FPR, mayber large lines.... that would do nicely...
The aeromotive 340lph intank can support 650whp easily... so that would be my choice.
      01-07-2013, 10:22 AM   #13
ZStig
Key point being the low compression build
      01-07-2013, 10:25 AM   #14
ZStig
Hmm those walbro 255 fuel pumps are only $80 on ebay. Thought it would be more
      01-08-2013, 09:11 PM   #15
dubsesd
OEM++
dubsesd's Avatar
No_Country
2274
Drives: F15 X5 MP/ 2016 F80 M3 INDVL
Get a veryron fuel pump. The Audi guys have been using them and solved the problem
2016 ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE P101 / 20" HRE 300 classics / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow
instagram: @ dubsesd
      01-08-2013, 09:19 PM   #16
ZStig
Ure joking, right?
      01-08-2013, 09:27 PM   #17
dubsesd
OEM++
dubsesd's Avatar
No_Country
2274
No.
http://www.audizine.com/forum/showth...-from-a-Veyron!
Search this Thread:
Advanced Search
