      12-31-2012, 05:26 PM   #1
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Anti Roll Bar (ARB) reinforcement without welding -alternate method
This was first discussed in this thread @ post#22
At the time I considered welding the only way; & still do if repairing one that has been ripped out.
I've since given this subject a lot of thought, as I plan to upgrade ARBs on my car this year.
For those of us with our mounts still intact & looking to strengthen the mount as a preemptive measure, here is what I found out.
First
I have a welder & can do my own work, so that wasn't holding me back.
My main issue was doing welding on a perfectly good mount.
I didn't want to deal with corrosion (long term) due to welding.
That lead me to Epoxy!
I started digging around and discovered that the E46 M3 guys started using epoxy for doing rear sub-frame reinforcement about 3 years ago.
Lots of reading for you here.
**Please note the epoxy used in the first post is not the right type for our use.
This comes up later in the thread.
After some digging; 3M makes a structural epoxy that will work for us.
3M™ Scotch-Weld™ Epoxy Adhesive DP420
Spec sheet
This makes it a simple DIY project for those so inclined.
All you need is a steel plate sized & 2 holes drilled to go over the studs.
DP420 is readily available on ebay or online hardware sources (google it)
It is an industrial spec product and not to be found @ Home depot et al.
I will be doing this myself and will gladly post a DIY but it will be spring time before I get to it.
I wanted to get this posted for those of you that may not want to wait that long.
Keep in mind... this method is intended for those that do not have any cracking or damage.
      12-31-2012, 08:08 PM   #2
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Whoa! This is a major development!
Great research/work Ian!
      12-31-2012, 09:09 PM   #3
beta
Drives: 2006 M Roadster
Awesome stuff, thanks for sharing! Can't wait for the DIY.
      12-31-2012, 11:50 PM   #4
Incompatible
Drives: 07 AW Z4C 3.0Si
Absolutely great info, thanks for posting. Waiting for DIY
      01-01-2013, 01:49 AM   #5
Kgolf31
Kgolf31's Avatar
459
Drives: 2007 Z4MC, 2012 128i
This will be awesome!
Final specs of the plate and holes will be requested so I can have a friend cut some up for me. This will be much appreciated!
      01-01-2013, 11:04 AM   #6
kennyfrc
kennyfrc's Avatar
18
Drives: 2008 Z4MC
has anyone with a Z4m experienced this issue?
To my knowledge the only subframe failures in our cars were on the front sway bar mounts when stiffer bars were used.
Daily: 2010 Tacoma Double Cab
      01-01-2013, 12:03 PM   #7
Beedub
wonderful stuff ian, real contribution to the community!! well done!!
      01-01-2013, 12:03 PM   #8
Beedub
yes so far they only seem to fail with the beefed up bars.....
      01-01-2013, 12:44 PM   #9
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks guys, happy to help.
Next chance I get I'll lift the car & get some measurements for the front plate.
AFAIK, no one has experience rear ARB mount issues, but I'll check that out as well.
I'm planning on doing my RTABS this rear & possibly some proper adjustable camber arms.
While I'm in that deep I may just drop the subframe to inspect & look at some plates for that area as well.
I'm curious if anyone familiar with the E46 rear subframe issues knows the history of when the problems started to show.
E.g. Was it later in the cars history when mileage started to add up?
I'm wondering if BMW learned their lesson on the E46, or is this something that may yet be on the horizon for us?
      01-01-2013, 12:50 PM   #10
Beedub
Next chance I get I lift the car & get some measurements for the front plate.
I don't think we have the same issues as the m3 rear subframe mounts, so far not one report of this issue now and these cars are getting on in age :-)
      01-01-2013, 01:16 PM   #11
Kgolf31
Kgolf31's Avatar
459
For the E46 it was mostly the pre-facelift vehicles (1999-2001). It was focus more so towards the sedans IIRC, not the coupes.
AWD E46s were rarely effected, post-facelift models didn't see failure as often as pre-facelifted.
My 02 w/130k miles showed no symptoms of failure (Class action lawsuit was filed for the E46 chassis, free inspection via BMW)
There really is no equation to a subframe failure.
      01-01-2013, 01:40 PM   #12
exdos
England
Drives: Z3 M Coupe(S54) and Z4 M Coupe
Excellent find!
I fitted a set of H&R E46 M3 ARBs a few months ago, and I made and fitted some 5.5mm thick steel shims between the front ARB bracket and the chassis, which I think should prevent chassis flex and metal fatigue causing tearing. I didn't want to weld the shims to the chassis for the same reason that you've mentioned (rust developing around the welding point), but now you've brought this method to everybody's attention I'll definitely use the epoxy glue to stick my shims to the chassis.
I've got a spare shim lying around, so I'll scan it on my photocopier and upload the image in this thread so it can act as a template for anyone who wants to strengthen the chassis.
When I was installing the rear ARB, I had a very good look at the rear subframe and chassis, with the idea of possibly reinforcing the points of attachment. I thought the construction looked fine with no obvious points of weakness, so I left alone.
      01-01-2013, 01:45 PM   #13
Beedub
Originally Posted by exdos View Post
Excellent find!
I fitted a set of H&R E46 M3 ARBs a few months ago, and I made and fitted some 7mm thick steel shims between the front ARB bracket and the chassis, which I think should prevent chassis flex and metal fatigue causing tearing. I didn't want to weld the shims to the chassis for the same reason that you've mentioned (rust developing around the welding point), but now you've brought this method to everybody's attention I'll definitely use the epoxy glue to stick my shims to the chassis.
yesss!!! perfect get on this john and report back, whats your feeling on the Rear subframe mounts on the z4m???? im guessing we shouldnt need to worry ;-)
      01-01-2013, 01:49 PM   #14
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Great, thanks for the info.
Sounds like we should be OK then.
      01-01-2013, 01:51 PM   #15
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Excellent find!
Good stuff, thanks!
      01-01-2013, 02:07 PM   #16
exdos
England
Byron,
I don't think there's anything to worry about with the Z4MC, it was made long after the problem in manufacture became apparent in the E46. BMW tends to learn from it's mistakes.
As you know, I also have a Z3MC, and there is a real problem of boot floor tearing with that car, there are some real horror images of it, and in comparison to the Z3MC, the Z4MC is a MUCH stronger car of an altogether different design and of better engineering integrity. Relax!
      01-01-2013, 02:44 PM   #17
exdos
England
I'm more organised that I thought and I could readily lay my hands on the template.
Here you go! Obviously, it's reversible L <--> R
      01-01-2013, 03:11 PM   #18
Finnegan
Finnegan's Avatar
Wow! Thanks.
What a great thread!
      01-01-2013, 03:18 PM   #19
Beedub
Byron,
Ok ok ok ill relax, tend to get abit worried over things that have affected older models, as a car I plan to keep I'm trying to remedy potential issues ASAP, I will definitely be doing the ARB mounts with this epoxy resin, that stuff sets like concrete , great find Ian.
      01-01-2013, 03:58 PM   #20
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks for the template!
That really helps.
We could use a few more dimensions for the stud holes, if that's possible.
If not I'll add them when I get the car up on the lift again.
The studs are M8 so that will help with hole size.
      01-01-2013, 04:51 PM   #21
exdos
England
That really helps.
When I measured the stud centres with a pair of large dividers, they were 90mm apart. If you can drill with your holes at exactly 90mm apart, then you should be able to use holes in the shim which are 8mm each. If the shim doesn't fit onto the studs, just drill one hole at 8.5mm and test fit, if this is not right, then drill the other hole at 8.5mm, and keep increasing the holes by 0.5mm, and so on, until the shim fits with the smallest holes.
in any event, once you use the resin to attach the shim, some of the resin will fill any space in oversized holes, but I don't think that's critical. It's increassing the thickness in the chassis region, preventing flexion, which is what we're trying to achieve.
The shim which I scanned has been fitted on my car, so if you use the centres of those holes, and use a 8mm drill as your starting point, then stepping up in 0.5mm drill sizes, should soon produce a shim that fits.
If I were to weld the shims in place, I certainly would want to weld the shim to the studs, because that would tend to weaken the studs.
      01-02-2013, 02:16 AM   #22
Beedub
That really helps.
John how thick is the plate???
