      12-27-2012, 12:00 PM   #1
Punko
Drives: 07 Z4 M Coupe
What spacers with OEM wheels
What would be the recommended spacers to push OEM wheels to the outer corners, nice and flush.
OEM springs
245/40/18
265/40/18
-2.5 camber
Thanks.
      12-27-2012, 03:21 PM   #2
Punko
Did some searching.
Looks like 15's all around may be OK but could get some rubbing.
      12-27-2012, 03:28 PM   #3
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I think I used 12.5 with OE.
      12-27-2012, 08:00 PM   #4
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Depends on tires. With 235/265 Dunlops the fronts were good however I had slight rub on the rears with 12.5mm. I was lowered ~ 1/2". With OE tires they are fine. Punko I have 4 - 12.5mm Turner spacers if you want to try them?
2006 Z4MC - #LL93158
      12-27-2012, 09:21 PM   #5
3002 tii
3002 tii's Avatar
2279
For front, rule of thumb is to avoid 10mm spacers since hub lips vary. If it were me, I'd go 5 or smaller, or 12 or bigger on the fronts to avoid any issues. For the rears, any size works
15's would be flush to slight poke. 12's on all 4 corners should be flush without too much risk of curbing. Either way, make sure to get longer bolts.
Follow for latest mods
      12-28-2012, 05:19 PM   #6
Mirko
Mirko's Avatar
Drives: E86 Z4M, E90 328i, E84 X1
I am running 12.5 in the front with the OE sizes. You are welcome to try the set I have on too if we meet up. I have more (less, i dont know) camber. On sharp bumps I rub a little bit. Then again I am lowered slightly as well.
If you want a set of 12.5mm I have brand new from Turner I haven't opened and not sure if I will use. Caddy looks like he has a few sets kicking around too. lol
      12-30-2012, 08:03 AM   #7
drbvac
drbvac's Avatar
Drives: 2006 BMW M COUPE
Do the spacers affect handling or additional stress on the wheel studs. I considered putting the tires "out there" a bit , however with the shit on the roads these days all I would end up doing is sand blasting my paint
2006 M COUPE - 380 total production, 1 of 40Imola Red produced for NA , ESS 455 Supercharger, Speedhut Gauges, VPM CLS wheels, 19" Hancooks, Stromung Exhaust, Carbon fibre accessories and black and white badging,
      12-30-2012, 06:31 PM   #8
BruceJ
6 of Diamonds (ret)
BruceJ's Avatar
Drives: 2011 E93 335is
Mudflaps! Now you have me thinking
2007 Z4Si(gone)
Couple E30 Verts (DD)
2003 330i
2011 E93 335is - current fav
      12-30-2012, 11:09 PM   #9
Ski
Hockey freak
Ski's Avatar
Drives: Bimmer's
I did 10/15's, no issues and fills nicely w/235-40/18 and 265-35/18..
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
Search this Thread:
Advanced Search
