Login
![]() ![]() SUPPORT ZPOST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
12-09-2012, 06:15 PM | #1 |
![]() 5
Rep 165
Power issue
so after doing a bit of a powerslide on the back roads my 2.5i Z4 bogged down and feels like it lost all power. I have the ESS Stage 2 on the beastie and a new LSD that was finally broken in. It was not a massive slide, but a little chirp - this occurred. It almost seems like the ESP is locked up and wants to rob power from the motor. I can drive it but it runs like crap with no power on the way back home the Service Engine Soon came on. I finally have the car how I like it and now its being a PITA.
Any ideas on what to look for or check? |
12-09-2012, 06:45 PM | #2 |
![]() 409
Rep 7,552
Best bet would be run a good scanner on it and see what codes you can find. Culprits, in no particular order, and no promises of this being a full list: 02 sensors, MAF, throttle position sensor, camshaft position sensor. But without guessing, you really need a scanner that can read BMW extended OBDII codes.
12-09-2012, 10:06 PM | #4 |
#buildnotbought
856
Rep 1,847
If you have an engine light, a generic OBD2 reader is probably sufficient. $10 or so on ebay,
Maybe a broken ignition coil or some sensor. Some things just happen at the same time ![]() |
12-14-2012, 06:25 PM | #6 |
#buildnotbought
856
Rep 1,847
It would be a huge coincidence that all 6 ignition coils broke at the same time.
Maybe the camshaft sensor? It might help to post the exact obd2 codes, otherwise its more and more a guessing game. |
12-17-2012, 11:17 PM | #8 |
![]() 5
Rep 165
Diagnostics were out of whack - used a different machine and showed one coil bad. Replaced it and the Z is back to normal. Odd coincidence, but glad its back.
12-18-2012, 03:19 AM | #9 |
![]() 409
Rep 7,552
