12-11-2012, 08:23 PM | #45 |
Rep 1,739
Drives: 2008 Z4MC
Great #'s! Congrats
12-11-2012, 08:53 PM | #46 |
Rep 892
Thanks guys!
Graph with boost: Z4M VF570 DynoBoost by M detaR, on Flickr Video of run: http://youtu.be/V4UZL4scGzU
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i Last edited by Rated M Roadster; 12-11-2012 at 09:30 PM.. |
12-11-2012, 10:57 PM | #49 | |
Rep 892
12-12-2012, 03:06 AM | #51 |
Rep 2,782
Good numbers. Did you have the AA headers in the before dyno?
12-12-2012, 08:07 AM | #52 |
Rep 280
That lean condition scares me...
But the dyno is absolutely awesome. Let us know if you get the tune straight, I am going FI but waiting on all the charts to decide the system, this wins so far, but need to make sure you get things straight first! Thanks for being the guinea pig, and I hope that it all works out. |
12-12-2012, 09:18 AM | #53 | |
Rep 5,329
OP out of interest did you log AFRs??? OP great numbers, you've documented it much better then all of the rest of us, i will be back at the dyno shortly for my revisions...... i promise to document the same, i take video with my d3200. Great great numbers!!!!
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 12-12-2012 at 09:49 AM.. |
12-12-2012, 10:14 AM | #54 |
Rep 280
12-12-2012, 10:33 AM | #55 |
Rep 5,329
you did indeed ;-) what were the AFRs saying at the shut down point rated??
12-12-2012, 01:02 PM | #56 | |
Rep 892
Here's a dyno with AFR (notice change at 6750 rpm): Z4M VF570 DynoAFR by M detaR, on Flickr I have a BavarianTechnic scan tool (another toy to play with ) in the mail to determine if there were any discrepancies in the tail pipe reading since I do still have section 2 cats in place. I will be doing recordings of different aspects along with lambda (then converted to AFR) readings from both banks. Should be an easy fix assuming it wasn't simply a false reading by the dyno. This is what I'll be doing with the BavarianTechnic tool: http://www.m3post.com/forums/showthread.php?t=723927 EDIT: AFRs fixed... Z4MrevAFR by M detaR, on Flickr
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i Last edited by Rated M Roadster; 05-26-2013 at 05:17 PM.. |
12-12-2012, 02:10 PM | #57 |
Rep 5,329
arhhh i see that is a lean spot for sure...... lets hope its inaccurate dyno reading ;-)
12-13-2012, 10:40 AM | #58 |
Rep 280
I keep thinking about these graphs, thanks again for taking the time to put them up. Those are awesome numbers.
Keep us posted on your experience, there are few reviews from other Z4M guys out there, and I really like this kit. |
12-14-2012, 07:47 AM | #60 | |
#buildnotbought
11123
Rep 4,930
I think that's intentional, seeing that both torque and power behave accordingly. I think they adjust the mapping there to get an even torque graph and continous power buildup (lean mixture=more power) I don't know when the lean mixture becomes too lean to cause damage (especially @ high revs), but it's still well below stoichiometric of course. |
12-14-2012, 10:50 AM | #62 |
Rep 2,782
What's a dyno look like when your fuel pump can't keep up with the demand?
ESS could have been right about the fuel system needing to be upgraded. It may not be tuning.
12-14-2012, 01:20 PM | #63 |
#buildnotbought
11123
Rep 4,930
If it wouldn't be tuning you'd get an engine light with some obd2 code like p0171 or so.
But what they can have done is adjust the mixture (in the tuning), so the pumppressure doesn't get too low. If you calculate: @6750rpm the afr is about 11.8, so thats about 572x parts gas (6750/11.8) @7800rpm (the max in this run) the afr is about 13.6, so thats (also) about 573x parts gas. If the afr hadn't changed, the parts gas used (per minute) would be higher of course. It's a big coincidence that in the high revs the engine (with higher afr) uses exactly as much fuel than in the highest rev before the afr start to rise. So it's not because the fuel pump stops suppling fuel (no obd code), but maybe it is the result of careful tuning not to overstress the pump (resulting in fuel pressure too low) and letting the afr rise. But a lean mixture gives more power (that could be the other reason). It's just bad for your engine if it gets too lean (valve temperature too high so they burn). Still, then why have a high afr in the mid revs. If the afr didn't rise above 6800rpm, it sure wouldn't produce so much power I think. Maybe up to 50HP less. Last edited by GuidoK; 12-14-2012 at 01:25 PM.. |
12-14-2012, 01:26 PM | #64 |
Rep 5,329
ok maybe im reading this wrong but doesnt the AFR go superlean after 6.7ishk rpm???
This gradual leaning Looks like a fueling supply issue BUt.... maybe the sniffer backed out the exhaust??? if those are indeed accurate.... the motor wont survive that for long. i see 11.4 at redline.... ^^^ dyno problem?????? it must be???
12-14-2012, 01:38 PM | #66 |
#buildnotbought
11123
Rep 4,930
stoichiometric is 14.7
Everyting below that is theoretically rich. Until 2600 its about 14, so what is 'lean' But it almost can't be a dyno problem, because otherwhise the torque and power curve would gradually fall off, and instead it rises faster than with the rich mixture. If it would be a dyno problem both the afr sensor/calculation (I don't know; do they pick that up directly from the first lambda probe?) and the power sensor/calculation would be at fault. That would be a coincidence... |
