      10-30-2012, 01:31 PM   #89
ApexRaceParts
Drives: M3
Originally Posted by i2ichal2dZ4M View Post
I know the 18x9.5 +22 is recommended for stock suspension setup, but how conservative is this setup? Are the 18x10 +25 that much more aggressive? will camber adjustment be needed. I would like to run 275 in the rear with no rubbing during hard driving.
We would not consider the 18x9.5" ET22 conservative at all. It works and looks great in the rear with a 265/35/18 or a 275/35/18 tire. Here are a couple of cars using our 18x9.5" ET22 wheel with a 265/35/18 tire.
An 18x10" ET25 with a 275/35/18 tire is doable but if you use an extreme performance summer tire like the Hankook RS3 or Dunlop Star Spec than you risk rubbing in the inner fender in the rear. Here are some pictures of an 18x10" ET25 mounted up with a 275/35/18 Michelin Pilot Super Sport tire that runs slightly smaller than an extreme performance summer tire and does not rub.
      10-30-2012, 08:26 PM   #90
mike519
mike519's Avatar
Drives: 2018 240i on order
I'm about to pick up a sepang M roadster and am thinking about the anthracite finish on these. Looking to put PSSs on them.
I am not up to speed on sizing wheels. I do not want to add camber plates and make fitment too complicated but would love as much concave of a profile as I can get.
Can you recommend the best wheel and tire sizes? I'd love as low a profile tire as possible.
Thanks
      10-31-2012, 01:38 PM   #91
ApexRaceParts
Drives: M3
Thanks
You could very easily use our most concave profile 3 wheel in the rear of your car. Either an 18x9.5" ET22 with a 265/35/18 tire or an 18x10" ET25 with a 275/35/18 tire could be used as a direct fitment.
For the front I would recommend our 18x8.5" ET35 wheel with a 235/40/18 tire. This is indeed a profile 1 wheel but in person they do have some concavity compared to pictures on the internet. Unfortunately it is very hard to fit a concave wheel on the front of a Z4M without camber plates. To give a comparison our 18x9" ET31 wheel is narrower than the normal 18x9.5" ET35 front wheel set up that most track guys will run but, the 18x9" ET31 will sit at almost the same point relative to the fender as the 18x9.5" ET35 so camber plates are also necessary for that wheel even with a narrower tire.
      10-31-2012, 02:34 PM   #92
mike519
mike519's Avatar
Excellent info, thanks
      11-03-2012, 10:40 AM   #93
ANUSTART
ANUSTART's Avatar
20
Drives: Z4
Can you suggest proper specs for non-M applications? Completely stock and not lowered.
      11-03-2012, 11:49 AM   #94
The HACK
Roger Murdock
The HACK's Avatar
521
Drives: 2006 MZ4C, 2015 Fiat 500e
Sigh. I was hoping not to spend more $$$on the MZ4 coupe this year, but these wheels just looks so RIGHT on the MZ4 coupe...almost like it ought have come from the factory like this.
Going to have to call in a few favors...
The hell I don't! LISTEN, KID! I've been hearing that crap ever since I was at UCLA. I'm out there busting my buns every night! Tell your old man to drag Walton and Lanier up and down the court for 48 minutes!
-Roger Murdock
      11-05-2012, 02:10 PM   #95
ApexRaceParts
Drives: M3
For a non-m we would recommend our 18x8.5" ET35 wheel in the front and our 18x9.5" ET43 wheel in the rear. You would be able to use a 235/40/18 tire in the front and a 265/35/18 tire in the rear with your stock suspension car and not have problems with rubbing. The rear wheel would use our profile 2 concavity and give a nice staggered look compared to the front wheels.
      11-05-2012, 03:06 PM   #96
ANUSTART
ANUSTART's Avatar
20
Drives: Z4
Thanks for the quick reply! Love these wheels.
      11-05-2012, 07:30 PM   #97
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 2013 335is
2013 335is  [0.00]
8.5X18 - 245/40/18 PSS - 9.5X18 275/35/18 PSS
Love the look, I could not be happier with the Apex Wheel. I have gotten lots of complements at gas stations and when out and about. The 2nd picture was taken at Deals Gap. We got the looks when we pulled into the parking lot. Bikers could not stop checking us out.
2013 335is Vert Black on Black DCT
2008 - Z4MR - Sold
BMWCCA / ZSCCA Member
      11-05-2012, 07:36 PM   #98
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 2013 335is
2013 335is  [0.00]
2008 - Z4MR - Sold
      11-20-2012, 12:45 AM   #99
mike519
mike519's Avatar
OK, coming back to this question. What if I wanted to go with 19" wheels? What size recommendations would you make, if any?
Thanks again
      11-20-2012, 12:12 PM   #100
fairlady_z
Gangsta
fairlady_z's Avatar
Drives: SW20
Is that an aftermarket lip on there? What kind is it?
      11-20-2012, 01:35 PM   #101
ApexRaceParts
Drives: M3
Thanks again
Unfortunately at this time we are not producing 19" wheels but may have something in the works for the near future
      11-20-2012, 01:49 PM   #102
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 2013 335is
2013 335is  [0.00]
FL-Z - PM'ed you.
2008 - Z4MR - Sold
      11-20-2012, 07:40 PM   #103
mike519
mike519's Avatar
No prob, let me know when you do as I won't be doing anything till the spring anyway. Thanks
      11-26-2012, 05:21 PM   #104
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
Mmmmmm
sitting in the garage waiting for a Tuesday install!
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
      11-26-2012, 05:30 PM   #105
Expert@ApexRaceParts
Expert@ApexRaceParts's Avatar
337
Drives: M3
Can't wait to see them mounted TexasZed4MC!
      11-27-2012, 04:20 PM   #106
Sirhan
Drives: Z4 M Coupe
///M sign
There is no place for the ///M sign on the rim ....
      11-27-2012, 05:21 PM   #107
TexasZed4MC
EC-7's are on!
I snapped just a couple crappy iPhone pictures at lunch after the install. Hopefully a photoshoot this weekend.
18 x 8.5 et 35 front with 225/45/18 tires
18 x 9.5 et 22 rear with 255/40/18 tires
I just used the stock tires I had, that were in very good shape anyway.
Side note: The car feels better with these lighter wheels. Far less sluggish
      11-27-2012, 05:34 PM   #108
dubsesd
OEM++
dubsesd's Avatar
No_Country
2265
Drives: F15 X5 MP/ 2016 F80 M3 INDVL
Looks awesome. I like it!
2016 ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE P101 / 20" HRE 300 classics / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow
instagram: @ dubsesd
      11-27-2012, 05:37 PM   #109
ApexRaceParts
Drives: M3
Agreed!^ Thanks for posting up TexasZed4MC
      11-27-2012, 06:16 PM   #110
TexasZed4MC
I really like the Anthracite color on the car. These are the best set of wheels I have had on the car. Now I want a track set in 18x9.5 et35 fronts and 18x10 et22 rears!
Tags
18x10, 18x9, 18x9.5, apex, ec-7
Search this Thread:
Advanced Search
