Login
11-14-2012, 01:21 AM | #1 |
![]() 5
Rep 162
Another euro headers & euro cat install thread
I have a set of euro headers and euro cats in transit.
After "exhausting" the search function (pun intended), I need some help with part #'s: 6 Header to engine gaskets 1 Header to S piping/euro cats gasket 1 S piping/euro cats to X piping gasket 4 heat shield clips for the O2 sensor wiring also, will I need to wrap the O2 sensor wires to protect the from the heat after I unfold them? If so, what kind? If there are any additional parts that I may need please chime in. I plan to install them myself with the help of a buddy. What tools will I need? Any tips or advice will be greatly appreciated. Thanks in advance. |
11-24-2012, 09:44 PM | #3 |
![]() ![]() ![]() ![]() 1174
Rep 10,845
Nothing special aboutvt hose parts, pick them up at your local dealer or order online.
You'll find what you need here..... http://www.realoem.com/bmw/select.do
11-24-2012, 10:08 PM | #4 | |
![]() 47
Rep 1,659
You're in luck, typed this up for a friend. This is all the hardware involved.
Copper Collar Nut x 18 11 72 1 437 202 Header to the engine, 3 per pipe hence 18 Exhaust Manifold Gasket x 6 11 62 7 830 667 Gasket between header and engine Exhaust Stud x 18 07 12 9 900 298 Studs on the engine for the headers Exhaust Seal Ring x 2 11 62 7 830 668 Ring between headers and cats Hex Nut (M10) x 4 18 30 1 317 898 Copper nuts between headers and cats Exhaust Gasket x 2 18 30 7 830 674 Gasket between cats and x-pipe Hex Nut (M8) x 6 11 62 1 744 323 Nut between cats and x-pipe Quote:
You will need clips to fix the O2 wiring to the heat shield. I don't have a part number but check my mod thread for pictures of them.
11-24-2012, 11:07 PM | #5 |
Dark Sider
![]() 80
Rep 1,761
Drives: 2008 Space Gray Z4MC
Studs are a plus. Backed one out and fucked it up. Had to run to HF and get a die kit. Not fun
11-25-2012, 12:35 AM | #6 |
![]() 5
Rep 162
Sweet! Thanks for the help guys!
I want to order all the parts at once. You will need clips to fix the O2 wiring to the heat shield. I don't have a part number but check my mod thread for pictures of them.[/quote] Where can I search for this p/n? Also, What part #'s do I need to make the extensions? |
11-25-2012, 09:16 AM | #7 |
![]() ![]() ![]() ![]() ![]() 16
Rep 737
If someone else is looking for a set of Euro headers, there is one for sale right now on m3forum.net for $650shipped
http://www.m3forum.net/m3forum/showthread.php?t=426573 |
11-25-2012, 03:35 PM | #8 |
![]() 31
Rep 1,097
