Reply
      11-23-2012, 10:41 AM   #1
autoque
Drives: '08 X5 3.0si
Exclamation A three year old on-going issue. Please help.
My vehicle is a '08 X5 3.0si with 13,000 miles.
I've got a warm start rough idle which lasts one to two minutes after the ignition. If I put the gear in D and brake only enough to slowly crawl forward(or back) when the engine is running rough, the power delivery feels erratic, as if the engine is pulsating or oscillating. When the engine's cold (like in the morning) it starts and drives fine.
This started right after replacing the cylinder head under warranty for a tapping noise, a well known issue in the N52 engine. The dealer changed the spark plugs, coils, MAF, coolant temperature sensor and cleaned various parts, tuned up the timing of the valves, disassembled and reassembled, the symptom got a little better, but never disappeared. The diagnostic device tells nothing's wrong and no code is stored.
The dealer says they've never seen a similar case and pretty much given up.
Does anyone know what might be happening with the engine?
autoque is offline
      11-23-2012, 12:04 PM   #2
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
Maybe the intake solenoid need to be cleaned out (also a wide known "issue" on these motors)? Originally dealer fix was to replace the piece but turns out you can use shop air to clean it out. Just remember to buy new o-ring seals.
Recaro | AST | Vorshlag | Quaife | Stoptech | Volks | Autosolutions | BMW Performance
Click here for my track videos
DSC_OFF is offline   United_States
      11-23-2012, 03:47 PM   #3
SD Z4MR
(formerly SD 335is)
SD Z4MR's Avatar
Drives: '06 Z4 M Rdstr | '11 335is E92
Do you realize that you posted your problem with your X5 in an E85 Z4 forum? You might find better results posting in an X5 forum.
Mine: 2006 Z4 Roadster | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Premium | Navigation | Heated Seats | iPod Adapter | Purchased 7/19/12
Hers: 2011 335is Coupe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | Premium | Convenience | Heated Seats | Navigation | Harmon Kardon | iPod/USB | European Delivery 5/12/11
SD Z4MR is online now   United_States
      11-23-2012, 05:19 PM   #4
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
I figured after 3 years OP was so desperate he posted on any platform that was linked to the n52
      11-23-2012, 09:23 PM   #5
Endless619
DHS
Endless619's Avatar
Drives: bmw x5, m3, Acura TL
Never heard of this at all.
Endless619 is offline   Spain
      11-24-2012, 01:16 AM   #6
Alexander
Mad tyte EuR0 style boooi <--- Joke
Alexander's Avatar
Drives: E30, E85, MKVI
Agreed.
Clean all intake plumbing. Replace fuel filter.
Alexander is offline   United_States
      11-24-2012, 03:12 AM   #7
autoque
Thank you Z members!
Yeah, I thought the issue was engine specific and N52 was used across the BMW lineup so I created a thread here in a final desperate move.
DSC_OFF,
actually the vehicle threw an error code a month ago indicating a one time misbehavior of the Vanos solenoid valve, which was replaced rather than cleaned and used again in hopes of fixing the original issue, but to no avail.
Alexander,
the vehicle drives normally when it's cold or after the two minute period from a warm start. If the intake/fuel filter were bad, wouldn't the vehicle behave the same in all situations?
autoque is offline   Reply With Quote
      11-24-2012, 06:48 AM   #8
BDO
Drives: Z4M Roadster /E92 335i
Change the injectors.
BDO is offline   Reply With Quote
      11-24-2012, 10:41 AM   #9
autoque
I thought about it but then again, the symptom is only shown under the specific circumstances I described above, so I'm not sure if the injectors are the culprit here.
Reply
Forum Jump
