      11-17-2012, 03:13 PM   #1
papak
Drives: 2008 Z4 3.0si Coupe
2008 diff fluid change
Anyone have a picture of the location of the drain plug on a 2008 diff (3.0si)? The fill plug is obvious but I want to be sure of the drain before I go removing n incorrect bolt. I know it's not the same as that on the 2.5.
TIA
      11-17-2012, 03:50 PM   #2
aerobod
Car Geek
aerobod's Avatar
Drives: Caterham R400, M240i, Golf 7 R
TIA
According to the TIS, if you have a differential with "Lifetime Fill" sticker on it (which is highly likely), there is no drain plug, you will have to unbolt the cover and replace the gasket if that is the case. If you have a cover with a drain plug, it is on the lower right of the cover, seen from the back of the car.
      11-19-2012, 02:43 PM   #3
mbetoni
Drives: 2014 Z435is
As the proud owner of an '08 si roadie, and also the previous owner of an '05 3.0, I can confirm the face lifted car does NOT have a drain plug on the diff, it was deleted with the 'upgrade' to lifetime fill.
Coincidentally, my diff fluid is being changed as I type this. Without the drain, it's simply a matter of sucking the old fluid out with an evacuator and then refilling it to the top.
      11-19-2012, 03:11 PM   #4
inTgr8r
inTgr8r's Avatar
Drives: E86 Z4MC; E92 M3
Lifetime fluids..... what a joke!
      11-22-2012, 03:41 AM   #5
santov
santov's Avatar
34
Drives: 2007 Z4 3.0si White over Beige
I couldn't believe that BMW eliminated drain plugs. I would suggest you do NOT remove the cover. It's easier and safer to suck the fluid out like mbetoni suggests.
Search this Thread:
Advanced Search
