      11-11-2012, 03:15 PM   #1
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
Windshield Washers Problem
Hey guys, just noticed that my nozzles on the hood stopped working. Headlight cleaning ones still spray its just the ones on the hood that aren't operating. Anybody have any experience with this?
      11-11-2012, 04:41 PM   #2
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Have you traced the lines back to the washer pump? All of them are attached to the same pump, so sounds like a kink or obstruction in the line to me.
      11-11-2012, 04:43 PM   #3
Drives: E86 Z4MC; E92 M3
^whs
.....or plugged nozzles.
      11-12-2012, 12:55 AM   #4
Loogey Clapp
Loogey Clapp's Avatar
Drives: 2006 Z4 3.0si
^whs
I was thinking perhaps dried wax in the nozzles.
      11-12-2012, 01:30 AM   #5
i2ichal2dZ4M
so today i took checked the nozzles and lines everything look clogg free and clear, i then decided to check the pumps. it looks like windshield nozzle pump went out, it showed rust on the outside of the unit. Since i had the tank out, i went ahead and checked to see if the grommets were clogged on both pumps, NOPE. Well now I happened to make the headlight washer not work as well -_-*. The pump is fine, i still hear it buzz, but no fluid is being channeled to them, i may have missed something. Got too cold and dark so i will attempt to fix this another day. Any ideas where I can get another pump cheap?
      11-14-2012, 07:06 PM   #6
hays0023
Drives: 2007 Z4MR
Interesting! This exact same thing happened to me....I ordered a new pump and was going to change it out.
Here is hoping it works.
      11-16-2012, 12:54 PM   #7
davesz4mc
Drives: 2007 z4mc
The headlight washers and winshield washers are two sperate pumps and line systems. My windshield washer pump (closest to firewall) recently went out as well, while it was at the body shop. I got a replament from a local auto parts shop that was cheap and I am running that!
      11-20-2012, 06:54 PM   #8
i2ichal2dZ4M
The culprit!!
Ebay + $10 later, car is spraying fluid like a super soaker once again!
      06-20-2013, 09:51 PM   #9
Master Apex
Drives: '07 Z4M & '06 E60M5
2007 Z4MCoupe  [0.00]
Thank You for sharing ...this saves me $$.
      06-22-2013, 02:30 AM   #10
StickMon
StickMon's Avatar
Drives: 2006 MR
First thing that went out on my car after I bought it used.
I saw the puddle on the driveway and thought "What's that? Oil? Coolant? Wait, this is washer fluid!"
$26.
      06-22-2013, 04:22 AM   #11
Vanne
Vanne's Avatar
United Arab Emirates
700
Drives: 2007 Z4MC
Send a message via Skype™ to Vanne
yep, both Bimmers i bought used here had this.. loved the fact its bloody cheap to diy.
2007 EuroSpec Z4///MC DIY Arial. Carma FF race exhaust. Cust. D///MK 6 Speed ultra SSK. CDV X. CSL 19" Rims. Apex 75mm kit. Stoptech brake lines. APR Aero. CSL intake. Epic Alpha-N. KW CS. SS sec1. 288/280. ECS power pulleys. Tillet B6Fxl. Sabelt.Varis. Brembo GT. ME STB .
      10-07-2013, 09:39 AM   #12
rmonte4
Drives: 2007 BMW Z4 3.0si Roadster
Thanks to this thread, this Fix cost me <$8 on ebay.
2007 Z4 3.0si Roadster
H&R Springs
Plasti-dipped Blueberry
      10-07-2013, 08:54 PM   #13
i2ichal2dZ4M
      10-18-2013, 09:57 AM   #14
just2talented
just2talented's Avatar
Drives: Alpine ///M roadster
Mine just went, anybody know the part number?
      10-18-2013, 01:11 PM   #15
StickMon
StickMon's Avatar
Drives: 2006 MR
Either #4 or #6 here, depending on which one's leaking.
      10-18-2013, 08:51 PM   #16
i2ichal2dZ4M
http://www.ebay.com/itm/BMW-3-M-X-Z-...8c9762&vxp=mtr
$6.88 + free shipping.
      10-19-2013, 01:55 AM   #17
StickMon
StickMon's Avatar
Drives: 2006 MR
^WHS
"2,194 sold"
I would classify this as a common problem.
      10-21-2013, 07:16 PM   #18
chickdr
Drives: 2006 M Roadster
Mine started leaking a day or so ago. Ordered the new pump but can't find a DIY anywhere. I assume you have to empty the reservoir first? The one leaking for me is the windshield washer pump. Do you just unclip the electrics and pull it out or does the entire reservoir need to come out to do it?
      10-21-2013, 08:56 PM   #19
StickMon
StickMon's Avatar
Drives: 2006 MR
I seem to remember I took the whole thing out so I could dump the juice into a bucket and save it.
Pretty sure there was only 1 bolt holding it on.
If it's already empty, or nearly so, you can skip that step.
The pump just pokes into the grommet/filter.
      10-21-2013, 11:24 PM   #20
KevinC
your average JAMF
KevinC's Avatar
Drives: '05 330Ci ZHP, '16 Golf R
Mine just crapped out, then I stumble into this thread.. amazing. How simple is this thing to swap out? I figure I'll score one of those 3rd world jobs @ $6.88 from Ebay - how wrong can you go at THAT price??
'05 330Ci ZHP Coupé
'16 Golf R
      10-21-2013, 11:33 PM   #21
i2ichal2dZ4M
very easy, id say no instructions even needed.
      10-22-2013, 02:09 AM   #22
Vanne
Vanne's Avatar
700
Drives: 2007 Z4MC
Really? Save the washer water that's in there? Come on, some water and a spot of windex and your done.
