FORUMS
- 5
| 09-15-2012, 09:58 PM | #23 |
be sure to check out *********** as well. they will have plenty of people better able to decipher your data
![]() W463, f30, 640i gc , m6 Recent past: z4m, x5 lci, boss 302, c6 z06 |
| 09-15-2012, 09:59 PM | #25 |
oh snap, you're in trouble with DA LAW with links like that. hahaha
I'm gonna go to the drag strip again October 12th. Meth kit will be working by then
| 09-16-2012, 09:42 PM | #26 |
I would definetely go with some stickier radials... with some better tires you should be able to launch higher without much wheel spin, I don't think a 2k - 2.5k launch is unreasonable. You could also launch higher on your street tires with proper clutch slippage. It also comes with experience, my times went up alot from when i started drag racing in my last car.
2007 TiAg ///MCoupe
{} Dinan strut bars {} ZHP knob {} RPI scoop {} Ultimate Pedals {} RE Diablo {} 9500ix {} 3.91 TMS gears {} Forgestar F14 {} Gruppe-M {} Nitto NT05 {} TMS pullies {} Zeck CDV {} RE tranny mounts {} Tekarbon {} |
| 09-16-2012, 09:47 PM | #27 |
I'm not as concerned with a low ET as I am with a good speed at the end. If I was hitting 118mph all day, I'd know I'm making the proper power, and then I could work on the launch and worry about getting into the 11s.
If I can get consistent 2.0 launches on street tires, that should be good enough for decent runs. With lower tire pressures I might be able to go under 2.0 on my next time out. I have no room to store a set of dedicated track wheels in my new place ![]()
| 09-17-2012, 09:00 PM | #28 | |
| 11-10-2012, 08:53 PM | #29 |
Well, I figured it out. A little bit of meth injection, 22psi in the rear, 66* ambient air temperature (vs 85 before), some more clutch slippage with a higher RPM launch, 500rpm shortshift on the 1-2 change, and a good combination of everything working together allowed me to launch like a beast in just 1.863 seconds for the first 60 feet
| Bookmarks |
