      08-07-2012, 12:44 PM   #1
dsgrillot
dsgrillot's Avatar
Drives: 2008 Z4M Roadster
What ramps work on these cars
I bought a set of rhino ramps yesterday so I can do oil changes, etc.
Well the ramp angle is way too steep so there is no way to drive the car up the ramps without taking the front bumper off.
Bottom line, does anyone know of a brand or type of ramp that will work on these cars?
M School
      08-07-2012, 01:23 PM   #2
Shipkiller
Shipkiller's Avatar
Drives: Me
RaceRamps
      08-07-2012, 02:12 PM   #3
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
If it's a stock suspension, a section of 2x8 about 3 feet long as a lead up to the Rhino ramps will work in a pinch.
      08-07-2012, 02:25 PM   #4
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
This. I built my own ramps using 2x4 pieces of wood I had laying around. I use the ramps to just get the car off the ground 2-3 inches for my floor jack to fit underneath it
The Raspinator
      08-07-2012, 02:45 PM   #5
bucko521
More of this than that!
bucko521's Avatar
Drives: BMW Z4 3.0i, Z3 2.5i
Finnegan is right on the money! I have the ramps and use a 2x8 about 2 feet long....works great on my Z4. If you are lowered, maybe need a rise above the 2x8 before the ramp as well.
'06 Z4 3.0i Jet Black/ Biege/Black
Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill
Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector
      08-07-2012, 03:20 PM   #6
dsgrillot
dsgrillot's Avatar
Thanks guys...this forum is addictive. It is truly the best source of info for our cars.
M School
      08-07-2012, 03:22 PM   #7
JasonH
Aspiring Track Rat
JasonH's Avatar
Drives: 2007 M Coupe, 2003 M3 Vert
I haven't built them yet, but something like these should work with the Rhino Ramps even on lowered cars.
      08-11-2012, 01:54 AM   #8
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
149
Drives: '01 911 Turbo
Or you could just use a low-profile floor jack to lift each side of the car using the rear side jacking pad and put the ramp under the tire, then lower the respective side and repeat for the other side.
When you're done, just do everything in reverse order pretty much.
      08-11-2012, 02:02 AM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
Contrary to popular wisdom, you can jack the car by the pinch weld right under the side view mirror and put jack stands under the jacking points.
I replaced my jack's pad with a 1' slice of 2x4 to spread the weight, and I slip a 1/8" think piece of wood between the door sill cover and the pinch weld to take up the gap and not slice the sill cover with the pinch weld.
I use standard jack stands with 2" pieces of 1x2 to adapt to the jack pads.
Now that I've written it out it sounds more complicated than it really is. I can throw it up on 4 stands safely in about 5 minutes.
      08-11-2012, 10:04 AM   #10
Incompatible
Drives: 07 AW Z4C 3.0Si
Once upon a time someone posted about using hockey pucks with a channel / groove cut down the center to use on the pinch welds with favorable results. Inexpensive, easy to use, and gentle on the car.
      08-11-2012, 11:39 AM   #11
bucko521
bucko521's Avatar
Yep...I found it... here it is. I think depending on your car and jack setup...you might need to adapt this for your use.
Bought a few pucks myself, but have not made the setup yet for my own use.
http://www.bimmerfest.com/forums/sho...d.php?t=481910
      08-11-2012, 12:51 PM   #12
Shipkiller
Shipkiller's Avatar
Drives: Me
To do this (hockey pucks), you need a very sharp wood chisel. Works like a charm...
      08-11-2012, 11:30 PM   #13
StickMon
StickMon's Avatar
Drives: 2006 MR
My original intent was to use hockey pucks. I went to the local sporting goods mega-mart, that has everything from lacrosse to fish hooks. Forgot that I'm in SoCal now, and not Chicago. When I asked if they had hockey pucks they laughed at me.
      10-29-2012, 12:13 PM   #14
Alexander
Mad tyte EuR0 style boooi <--- Joke
Alexander's Avatar
Drives: E30, E85, MKVI
I use 2x8s to get it high enough to either drive on the ramps or fit the jack.
Now I invested in some nice low profile jacks, so I don't need to do this anymore.
      10-29-2012, 07:46 PM   #15
RADRACR
RADRACR's Avatar
Originally Posted by Shipkiller View Post
RaceRamps
Ludicrously expensive but worth avoiding the annoyance of jimmy-rigged solutions. I don't like driving up the stepped 2x8s nor the weight, and low-profile jacks are annoying if you want to get the front of the car on jack stands -- 99% of them can't reach the center jack point from the front, unless you want to spend $500-600 on a super long one.
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14
      11-02-2012, 04:21 PM   #16
JFleming
Drives: '10 328i xdrive, '07 Z4 3.0si
My two cents
I use wood ramps I slapped together from some 2 x 8's and 1/2 OSB. Total cost about $14 as I remember. They are a little heavy, but for as often as they are used, they work like a charm. That 14 degrees is about the max angle my Z will take as an angle of approach (see drawing). You may need to go slightly less if your car is lowered.
      11-03-2012, 11:00 AM   #17
bosstones
Drives: o_0
I have some 2-3' long 2x8s laying around. I just drive up on them (just one per wheel). My humble Craftsman 2.25 ton jack fits under the the front bumper. Once it's under, I put a hockey puck on top of it and position it under the front jack point. Until the jack makes contact and starts putting pressure on the jack point, I have to limit the throws for the jack, though. A bit of a pain to get started due to the initial short throws, but this has worked perfectly fine for oil changes. It doesn't list the car high enough to get my jack stands higher than the first detente or two, though......makes it kind of tight trying to get to the trans but it's doable. Until I need to do more, I haven't been able to justify picking up another jack (or ramps).
Edit: I'm the stock suspension.
      12-06-2012, 03:00 PM   #18
dbcat1
Drives: BMW 335i
Ok, so rhino ramps lift height is 6 and 1/2 inches, and Race ramps lift height is 10 inches. Well, 10 inches sounds better to me than less, but I guess my question would be if I lift to 10 inches will I scrape my exhaust pipes?
2007 335i stock
      01-08-2013, 05:42 PM   #19
liamket
Drives: '06 Z43.0si-Black, Red Leather
I cheated. Instead of buying new ramps (because mine are too steep as well), I used the side jack point with my floor jack and lifted it until I could slide the ramp under the wheel. Then I did the same, slowly on the other side. I also have jack stands as well, but since I wasn't taking any wheels off, the ramps seemed like a much more sturdy and safe alternative. Plus in a worst case scenario (even though it was in gear with e-brake applied), the ramps have roll-lips to keep the tires on the upper/flat section.
      03-20-2013, 04:58 AM   #20
pokeybritches
pokeybritches's Avatar
Bahrain
185
Drives: ESS/G-Power Z4M, VF Z4, 987.2
2006 BMW Z4M  [5.00]
2006 BMW Z4M  [4.25]
2003 BMW Z4 3.0i  [4.50]
Bumping this thread. Anyone try the 56" two piece Race Ramps? Is 8" enough , or do I need the 10" high ramps? I like the concept of the two piece ramps.
VF Engineering Z4 3.0i, ESS Z4M, G-Power Z4M, 987.2 Cayman S
      03-20-2013, 03:35 PM   #21
Steenos
2007 M Coupe  [0.00]
Originally Posted by pokeybritches View Post
Is 8" enough
Thats what she said...
      03-20-2013, 11:47 PM   #22
XMetal
XMetal's Avatar
Drives: '04 X5, '08 Z4MC
2008 Z4M Coupe  [0.00]
2004 X5  [3.50]
I have the single piece version (RR-56). Here's a picture...judge for yourself
