      10-18-2012, 09:33 PM   #1
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Modifying Euro Headers - Install Options
After reviewing way too many threads and posts on this topic, I still find myself torn on how to proceed with installing my Euro headers. I'm aware that a few folks haven't had the best success with the relocation (messed up secondary cats) and that's not something I really want to risk.
Typical options
Find a Euro Cat (almost as rare as a unicorn).
Modify the stock US secondary cats. Irreversible, and no guarantee that it will turn out like Pal's install some shop isn't going to do a hack up the cat and leave you with a expensive mess. Seems like if you find a great shop, and do not cut into the wires (expand wires) this seems seems to work fine (but still irreversibly modifies the cat).
What about other options such as:
Add O2 and EGT to the Euro headers themselves in exactly the same spot as the US stock headers. This would leave a set of unmodified stock headers if needed plus a stock secondary cat. Fabspeed and others have both O2s and EGT on the headers themselves (just like stock). With a tune, CEL can be eliminated. (Seems there's a debate on whether the Evolve tune returns a "readiness" code or not though.)
Disconnect the secondary O2s (and keep as spares), and use a tune to eliminate the CEL and provide a "readiness" code. I'm not sure if this is doable. If it were, this would require no modification of the Euro headers, and use a tune to avoid the CEL.
Thoughts? Comments?
      10-18-2012, 09:49 PM   #2
Drives: E86 Z4MC; E92 M3
I went through the same questions Ron.
Ultimately I decided to NOT modify section one.
I sold the Euro headers & now have a set of Fabspeed waiting to be installed.
I'm still undecided about the tune. .....most likely Evolve.
& some days I wonder if its more trouble than its worth
      10-19-2012, 08:19 AM   #3
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
Its half the fun to rip out your hair. Seriously tho I am learning the hard way but do not under any circumstances cut in your o2 sensors. I relocated but still short. Take your time with relocation its doable.
The Raspinator
      10-19-2012, 11:16 AM   #4
Geauxkart
Geauxkart's Avatar
Drives: 2007 Z4 M Coupe Sepang
I put euro headers on mine, did all the welding myself, and unfolded without cutting o2 sensors.
No codes in 1000 miles.
If you do it right, it works.
      10-19-2012, 11:18 AM   #5
johanness
Drives: 2008 Z4MC
^^^absolutely.
'Irreversible' shouldn't be any kind of a deciding factor if you're relocating sensors. Once your set of Euro's are in, there's not a chance you'll ever revert back to stock. Not for resale, nothing.
You can run them fine with/without a tune and no CEL.
It's a different story with the Fabspeed headers & their bung location - using a tune (Evolve) to turn down the sensors. It's a more permanent decision because you'll need to keep the tune with the car for things to run properly.
My $0.02
      10-19-2012, 12:27 PM   #6
beta
Drives: 2006 M Roadster
Agree with the above, just get a very reputable shop to weld bungs onto your cats and you'll be golden. Also check your email, sent you an email there and I just figured out it might have landed in your spam folder.
      10-19-2012, 01:25 PM   #7
davesz4mc
Drives: 2007 z4mc
I have zero cats and no codes Evolve FTW !!!
      10-19-2012, 01:40 PM   #8
mousitch
Dark Sider
mousitch's Avatar
Drives: 2008 Space Gray Z4MC
Send a message via Yahoo to mousitch
It's worth it IMHO. I remember O-cha telling me that the Fabspeeds did not fit real well and they had to bent(dented) in to clear some areas. Maybe they have been redesigned since then. Supposedly fit the M3 real well but not so much the Z4M. But this was two plus years ago.
2008 Space Grey M Coupe-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Escort 9500ix-Alarm module added-stereo amp recoded to vert settings
      10-19-2012, 02:05 PM   #9
They say that they fit now, they actually list them for the Z4M now.
....Confirmed with another member.
      10-19-2012, 02:51 PM   #10
marinb
marinb's Avatar
Drives: 2017 911 GTS
Fabspeeds fit fine. I did the install myself.
      10-19-2012, 03:00 PM   #11
SCHMOUPE
SCHMOUPE's Avatar
Can I pick your brain about the tune?
The Raspinator
      10-19-2012, 03:07 PM   #12
Finnegan
Finnegan's Avatar
Thanks guys! Great input and information!
Looks like finding a good shop to do it right with the O2 relocation is key. And that's the dilemma here in CA--places with good skills aren't willing to do the work. I have a great muffler shop (guys with 40 years custom exhaust experience with muscle cars, real craftsmen), but they're not willing to do the work because it involves modifying a cat. If you're a DIY welding kind of guy, you've got it made.
I'm leaning towards Fabspeed and an Evolve tune as of the moment (subject to change), and maybe working on a longer term solution with the Euro headers for Krissi's Z. (Most mods end up on one car, then the other, due to "mod envy" .)
      10-19-2012, 04:25 PM   #13
kennyfrc
kennyfrc's Avatar
11
Drives: 2008 Z4MC
Typical options
Thoughts? Comments?
The OEM Euro headers are the easiest to tune for and provide consistent, solid gains. In order to be CEL free, which I was for 5K miles prior to getting the evolve catless o2 ready tune requires welding the bung so there are NO LEAKS. I chased a CEL for a month because of a pin hole in weld that I could not even see. To make sure there are no leaks you have to pressurize the pipe and spray soapy water on the welds, leaks blow bubbles, make sure there are none. Unfolding the harness is easy, you just have to take your time and work the wires back the point where you split them off and head down the transmission tunnel. It's not a hard job but, requires attention to detail. I own a welder repair shop and am a decent welder, I can modify the pipe if you like.
PM ME for details.
Mods: OEM Euro Headers, RPI Scoop
Daily: 2010 Tacoma Double Cab
      10-19-2012, 04:32 PM   #14
OG_M3
Drives: ae86; z4mc
2011 BMW M3  [0.00]
2007 BMW Z4MC  [0.00]
1985 AE86  [0.00]
semi-solution:
http://www.zpost.com/forums/showthread.php?t=753853
said to have already been tried and tested.
      10-21-2012, 04:08 PM   #15
beta
And just to give all the options, if you don't mind throwing money at the problem there's always buying new euro cats
      10-21-2012, 04:35 PM   #16
Finnegan
Finnegan's Avatar
Thanks. What coating is that? Do you notice a marked difference in radiant heat?
      03-03-2013, 11:12 PM   #17
GriffBrew
What did you end up doing? Your sig says euro headers and cats, but I found no posts from you about it. I'm in the same boat now too. And leaning towards a tune, either with euro or fabspeed headers. Tune just so I avoid the headaches, and because its cheaper than euro cats.
      03-03-2013, 11:35 PM   #18
DKF is coming out with an OE section 1 replacement
http://www.zpost.com/forums/showpost...&postcount=191
      03-04-2013, 12:27 AM   #19
JeffchaPz
JeffchaPz's Avatar
Drives: 2007 Z4M
Question for all of you... if a tune takes care of the CEL with cats or no cats at all... then it shouldn't matter where you weld your or put your post-O2 sensors..... true?
All they need is a little heat to trick the computer.... right?
The straight pipes spirits are calling me
      03-04-2013, 12:30 AM   #20
zubydafa
tosser
Isle of Man
18
Drives: '07 Z4MC
yea but have you dyno'ed.
'07 MCoupe
lots of mods
      03-04-2013, 08:07 AM   #21
elwesso
elwesso's Avatar
13
Drives: Z4 M Coupe
Has anyone tried those little gizmos that trick the o2 sensors? I have heard of other cars (mustangs come to mind) that use something that plugs into the harness for the o2 sensors...
As long as the cats are there, you should have no issues passing emissions, so really all you're trying to is prevent the CEL so that you can pass emissions.
I read some people on the M3 forums that had varying degrees of success using those "o2 sensor trickery devices".. Some people claimed they worked, others claimed they didnt... I know they can be obtained pretty cheaply, so perhaps it'd be worth trying before having the exhaust modified.
- Wes
2007 BMW M Coupe
2016 VW GTI
      03-04-2013, 10:45 AM   #22
pokeybritches
pokeybritches's Avatar
Bahrain
185
Drives: ESS/G-Power Z4M, VF Z4, 987.2
2006 BMW Z4M  [5.00]
2006 BMW Z4M  [4.25]
2003 BMW Z4 3.0i  [4.50]
Has nobody built an O2 simulator?? If I can trace the sensor wires back to the ECU box (or as far as they go), I can fab one up. It isn't that hard to put a couple of resistors in parallel, one being a variable resistor.
I assume the primary O2's output a 0-5V square wave, with the amplitude varying based on the AFR. I don't know the duty cycle or frequency, or how the primary and secondary O2 sensor banks relate. I don't know if the ECU controls the signal, or if it's something that's generated by the O2 sensor. But if it's as simple as reducing the amplitude by soldering in a couple of resistors, why hasn't anyone done it?
Excuse the quick work in Powerpoint. I haven't looked at EE in years, and I don't remember the symbol for a variable resistor and am too lazy to look it up (I think it's a resistor symbol with a perpendicular line through it).
VF Engineering Z4 3.0i, ESS Z4M, G-Power Z4M, 987.2 Cayman S
