10-03-2012, 05:34 PM | #1 |
Rep 384
Roof slams down hard. Any adjustments I can make?
My roof started slamming down when it gets within 5 or so inches of the windshield. It used to close smooth all the way into the latches, now it gets within a few inches, then SLAM's home. I'm afraid its going to get worse and crack the windshield or bend something. I don't know if its the motor or some strut in the folding roof itself. Has anyone seen this before? Would it be covered by warranty?
The Internet said it. I believe it. That settles it!
10-03-2012, 05:53 PM | #2 |
Rep 4,060
Unless you removed your power top assembly to replace the motor recently, and perhaps inadvertently misaligned it upon reinstallation,i would say it's just an adjustment made necessary after a period of normal use. just my guess!!
I dunno if I would trust that to an Indy shop. I would want someone who really knows what he is doing to make that kind of adjustment.
Huz-Z
10-03-2012, 06:41 PM | #3 |
Rep 2,138
Drives: Me
It's not the motor. The motor is just an electro-hydraulic unit that just pumps hydraulic fluid.
The simplest is that the top is binding somewhere close to the end of it's travel and releases quickly. Try lubricating all the joints. As for a mechanical failure.... It could be the Gas Pressurized springs, no. 13 http://www.realoem.com/bmw/showparts...12&hg=54&fg=10 or one of the tensioning ropes, no. 5 or 7 http://www.realoem.com/bmw/showparts...11&hg=54&fg=10 |
10-03-2012, 08:09 PM | #4 |
Recalc that...
Rep 34
There is a BMW bulletin on this...go to the stealership and get the ten dollar part...it's a strap that installs in the forward facing plastic compartment in the the softtop.
10-03-2012, 11:34 PM | #5 |
636
Rep 3,124
Mine's done that since I bought it used nearly 2 years ago.
I thought it was supposed to do that, but I reach up and ease it down by hand. I don't like things to slam. Looks like they made a change in the TENSION ROPE 07/2007. If anyone figures out the details, and applicable years, please post. |
10-03-2012, 11:56 PM | #6 |
Rep 1,663
Any more details?
10-04-2012, 12:38 AM | #7 |
Rep 384
Thanks forum. Good info. Ill be checking out that tension rope issue at the stealer next oil change.
10-09-2012, 01:35 PM | #8 |
Mechanical Engineer
96
Rep 1,025
Can anyone shed any more light on this issue? I have the same five inch drop, never realized it was something I could fix.
10-09-2012, 01:51 PM | #9 |
Rep 233
There are elastic straips called bow straps that loose their elasticity over time (at least on Z3s and most probably on all convertable tops). There is no adjustment but they need to be replaced. This is just a predicatble wear item when one has a ragtop. Your Z4 is over eight years old so the bow straps probably have little or no elasticity left in them. These straps, I learned, play a big role in both preventing the top from closing too quickly and in helping the top open.
I discovered it is good practice to replace these straps whenever the top canvas is replaced. Not all trim shops will tell you this and reinstall the old worn straps. I learned about this three years ago when I took my Z3 with a top that operated perfectly to a local trim shop to have the worn canvas replaced. I got the car back with good canvass but a top that no longer worked properly. It slammed shut and needed a manual push to break the "knuckle" when opening. The much stiffer new canvas just overwhelmed the no longer elastic bow straps. It would have been relatively cheap to replace them when the top was replaced but I did not know about them at the time. |
10-09-2012, 03:16 PM | #10 |
Rep 1,663
Is it part 17 tension rope? Or 15 tension belt?
http://realoem.com/bmw/showparts.do?...10&hg=54&fg=10 Has anyone replaced it? Mine slams a bit, also thought it was normal.
10-10-2012, 11:34 PM | #11 | |
636
Rep 3,124
How can one tell if you have Folding top or EH Folding top? Part 17 shows a change as of 07/2007: Up to 07/2007: Left: 54347123027 Right: 54347123028 After 07/2007: Left: 54347079587 Right: 54347079588 (I had to use BMW of South Atlanta to get this straight. Their diagrams are more accurate and up to date then RealOEM, but harder to navigate.) I wonder if the post 2007 part will fit on a 2006? Maybe it's been improved, and is backward compatible? ECS says the old parts are superseded by the new, so I think the answer is Yes. Last edited by StickMon; 10-10-2012 at 11:40 PM.. |
10-11-2012, 12:17 AM | #13 |
636
Rep 3,124
Fiddna find out. After about an hour of research on RealOEM and BMW of South Atlanta, I'm about to pull the trigger on this set:
Left Tension Belt 54317043909 Right Tension Belt 54317043910 Tension Belt Mounting Parts 54347119643 Left Tension Rope 54347079587 Right Tension Rope 54347079588 Tension Rope Mounting Parts 54347119628 Fastening Kit 61 (aka 66) 54347110761 Fastening Kit 62 (aka 22) 54347110762 Front Fastening Set 54317127044 If anybody has been in there before, maybe you can suggest other things to replace while at it, or other spare hardware to get. |
10-11-2012, 08:00 AM | #14 |
Rep 452
Yes, very interested to hear answers to this post.
10-11-2012, 11:55 PM | #17 |
636
Rep 3,124
I'm glad for once that I'm not the only one that thought it was supposed to do that.
Like "I thought the vanos was supposed to make that noise." No, 3 of your bolts are sheared off. |
10-12-2012, 12:18 AM | #18 | |
Rep 273
10-13-2012, 05:33 AM | #20 |
Rep 135
Drives: 2008 BMW Z4 3.0si
Location: Fort Mcmurray, Alberta/ Hare Bay, Newfoundland
10-13-2012, 12:03 PM | #21 |
Save the Manuals
1718
Rep 2,940
I think the hard drop is also from fabric shrinkage, with age of the canvas, UV exposure, etc.
I had this effect on an e36 vert.
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
03-23-2013, 01:45 PM | #22 |
Rep 1,663
Bump. We really need a resolution for this thread, which is the important "ten dollar part" that needs to get replaced, did anyone do it already, etc. etc.
